Topic: Using GSM_Shield library with WaveCom modem (Read 2198 times) previous topic - next topic
binooetomo
Dear All.
First, Thankyou for the "GSM Shield" Team for the great library.
I tried to use GSM_Shield library with WaveCom modem.
It works as expected, well with some commenting at init part for lines that I "think" not a mandatory.
By default this library use a pooling methode to check for new SMS, using AT+CMGL.
Wavecom modem can send +CMTI if there is a new msg come, without first requested by application (It's simply Modem initiated).
Is there a way to catch this using GSM_Shield library ?.
I tried to add methode to GSM Class, name it as -> IsCMTIPresent
In GSM_Shield.cpp
Code: [Select]
Method checks if there is +CMTI available
It's just adapted from CheckRegistration
return values:
      CMTI_NOT_AVAILABLE  - There is no new msg announced by modem
      CMTI_AVAILABLE      - Modem said there is New Mesg
      CMTI_TIMEOUT        - Timeout
byte GSM::IsCMTIPresent(void)
  byte status;
  byte ret_val = CMTI_NOT_AVAILABLE;
  SetCommLineStatus(CLS_FREE);
  // 1 sec. for initial comm tmout
  // 50 msec. for inter character timeout
  Serial.print("Just Check mySerial ... ");
  status = WaitResp(5000, 50);
  Serial.print("Status is : ");
  Serial.println(status, DEC);
  if (status == RX_FINISHED) {
    Serial.println("Finish Checking");
    // something was received but what was received?
    if(IsStringReceived("+CMTI")){
      // it means There is New Mesg Received
      Serial.println("There is New Msg");
      ret_val = CMTI_AVAILABLE;
    else {
      Serial.println("There is NO NEW Msg");
  else {
    // nothing was received
    Serial.println("Ouuchhh ... mySerial not responding");
    ret_val = CMTI_TIMEOUT;
  return (ret_val);
In GSM_Shield.h (The "enum" Part)
Code: [Select]
enum cmti_ret_val_enum
  CMTI_NOT_AVAILABLE = 0,
  CMTI_AVAILABLE,
  CMTI_TIMEOUT,
  CMTI_LAST_ITEM
In GSM_Shield.h (Inside "GSM class" Part)
Code: [Select]
    byte IsCMTIPresent(void);
I Used this line inside my sketch
Code: [Select]
    if (gsm.IsCMTIPresent()== 1){
      Check_SMS();  //Check if there is SMS
But it didn't work
I think there is something wrong with the way I call
WaitResp(5000, 50)
It always retval with --> RX_TMOUT_ERR,
So , kindly please tell me how to catch that "+CMTI".
Sincerely
-bino-
binooetomo
nugrahaslalu
thanks about your share
and i want ask about if i want to call with wavecom M1306B Q2403A, may you can give the example code
thanks again bevore :D
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
