Topic: Adruino Mega / Ethernet Shield (SD Card Slot) (Read 971 times) previous topic - next topic
Mopinion
Feb 21, 2012, 04:27 am Last Edit: Feb 21, 2012, 04:36 am by Mopinion Reason: 1
Hello all.
As part of my project I am trying to store the value obtained from 4 sensors every 30 seconds into individual files on the mini SD card.
I am currently using an Adruino mega attached to the ethernet shield.
How can i set it so that it records the data in the SD card every X seconds?
Any help is greatly appreciated.
Thank you.
This is my function to do so:
Code: [Select]
void LogData()
  // make a string for assembling the data to log:
  // Temperature
  String dataString1 = "";
  dataString1 += String(tempRaw);
  // p.H.
  String dataString2 = "";
  dataString2 += String(pHRaw);
  // Yeast 1
  String dataString3 = "";
  dataString3 += String(yeast1Raw);
  // Yeast 2
  String dataString4 = "";
  dataString4 += String(yeast2Raw);
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("Temp.txt", FILE_WRITE);
    dataFile.print("Temperature = ");
    dataFile.println(dataString1);
    dataFile.close();
  File dataFile1 = SD.open("p.H..txt", FILE_WRITE);
    dataFile1.print("pH = ");
    dataFile1.println(dataString2);
    dataFile1.close();
  File dataFile2 = SD.open("Yeast1.txt", FILE_WRITE);
    dataFile2.print("Yeast1 = ");
    dataFile2.println(dataString3);
    dataFile2.close();
  File dataFile3 = SD.open("Yeast2.txt", FILE_WRITE);
    dataFile2.print("Yeast2 = ");
    dataFile2.println(dataString4);
    dataFile2.close();
And this is my full code:
Code: [Select]
#include <SD.h>
// On the Ethernet Shield, CS is pin 4.
const int chipSelect = 4;
// Variable for reading the pushbutton status
int buttonState1 = 0;
int buttonState2 = 0;
int buttonState3 = 0;
int buttonState4 = 0;
int Button;
// Variables for calculated values to be displayed on LCD
float celcius;
float ph;
float oxygen;
float yeast;
// Variables for raw sensor inputs
int tempRaw = 0;
int pHRaw = 0;
int yeast1Raw = 0;
int yeast2Raw = 0;
// Variables for temperature sensor and calculations
const int analogInPin = 1;  // Analog input pin that the potentiometer is attached to
int i = 0;
int n;
int sample = 30;
float tempRawArray[30];
float averagetempRaw;
float sumtempRaw;
float referenceVoltage;
float volts;
float voltDivisor;
float millivolts;
float kelvin;
int x;
  // initialize serial communications at 9600 bps:
  referenceVoltage = 5000;
  // initialize the pushbutton pins (24,26,28,30) as inputs:
  pinMode(24, INPUT);
  pinMode(26, INPUT);
  pinMode(30, INPUT);
  pinMode(32, INPUT);
  // Ethernet Shield Initialization
  int analogPin = 2;
  clearLCD();
  buttonStateFunction();
  LCDDisplay();
  //phSense();
  TemperatureSense();
  //phSense();
  //x++;
  //if(x>200){
  LogData();
  //TempControl();
  //x=0;
// Temperature Sensor Functions
void TemperatureSense() {
    tempRaw = analogRead(A0);
  //Arduino analogReads in a value 0-1024
  voltDivisor = 1024/referenceVoltage;
  kelvin = millivolts/10;
  volts = millivolts / 1000;
  celcius = kelvin - 273.15;
void TempControl (){
  int TempInput = analogRead(A0);
      if(TempInput > 560){
    digitalWrite(13, HIGH);
    digitalWrite(13, LOW);
// p.H. Sensor Functions
void phSense(){
  pHRaw = analogRead(A1);
// Conductance Functions
void yeast1Sense(){
  yeast1Raw = analogRead(A2);
// Turbidity Sensor Functions
void yeast2Sense(){
  yeast2Raw = analogRead(A3);
// Buttons Functions
void buttonStateFunction() { //Check which button is being pushed
  // Check if buttons have been pushed
  int buttonState1 = digitalRead(24);
  int buttonState2 = digitalRead(26);
  int buttonState3 = digitalRead(30);
  int buttonState4 = digitalRead(32);
  // Check which button has been pushed and assign a variable to it
if (buttonState1 == HIGH) {
  Button = 1;
else if(buttonState2 == HIGH) {
  Button = 2;
else if(buttonState3 == HIGH) {
  Button = 3;
else if(buttonState4 == HIGH) {
  Button = 4;
// Data Logging
void LogData()
  // Temperature
  // p.H.
  // Yeast 1
  // Yeast 2
    dataFile.close();
    dataFile1.close();
    dataFile2.close();
    dataFile2.close();
// SerLCD Functions
void LCDDisplay() { //Decide what to display on the LCD
switch (Button) {
  case 1:
// clearLCD();
  selectLineOne();
    Serial.print("Temperature    ");
  selectLineTwo();
    Serial.print(tempRaw);
    Serial.print(" ");
    Serial.print("Celcius        ");
  case 2:
  //clearLCD();
  selectLineOne();
    Serial.print("p.H.            ");
  selectLineTwo();
    Serial.print(pHRaw);
    Serial.print("                ");
  case 3:
  //clearLCD();
  selectLineOne();
    Serial.print("Volume Fraction");
  selectLineTwo();
    Serial.print("Of Yeast");
    Serial.print(" ");
    Serial.print(yeast1Raw);
    Serial.print("               ");
  case 4:
  selectLineOne();
  selectLineTwo();
    Serial.print(" ");
    Serial.print("               ");
  default:
  selectLineOne();
    Serial.print("Please select");
  selectLineTwo();
    Serial.print("what to display");
    delay(4000);
    clearLCD();
  selectLineOne();
    Serial.print("Button 1 for");
  selectLineTwo();
    Serial.print("Temperature");
    delay(3000);
    clearLCD();
  selectLineOne();
    Serial.print("Button 2 for");
  selectLineTwo();
    Serial.print("p.H. levels");
    delay(3000);
    clearLCD();
  selectLineOne();
    Serial.print("Button 3 for");
  selectLineTwo();
    Serial.print("Oxygen Levels");
    delay(3000);
    clearLCD();
  selectLineOne();
    Serial.print("Button 4 for");
  selectLineTwo();
    Serial.print("Yeast Levels");
  delay(3000);
  //clearLCD();
void selectLineOne(){  //puts the cursor at line 0 char 0.
   Serial.print(0xFE, BYTE);   //command flag
   Serial.print(128, BYTE);    //position
void selectLineTwo(){  //puts the cursor at line 0 char 0.
   Serial.print(192, BYTE);    //position
void goTo(int position) { //position = line 1: 0-15, line 2: 16-31, 31+ defaults back to 0
if (position<16){ Serial.print(0xFE, BYTE);   //command flag
              Serial.print((position+128), BYTE);    //position
}else if (position<32){Serial.print(0xFE, BYTE);   //command flag
              Serial.print((position+48+128), BYTE);    //position
} else { goTo(0); }
void clearLCD(){
   Serial.print(0x01, BYTE);   //clear command.
PaulS
Quote
Note what time (millis()) you last called LogData(). See if now (millis()) minus then (the last time you logged data) is greater than or equal the desired interval.
Mopinion
Thanks! Got it to work using milis() and a very similar algorithm to what you suggested :D
Mopinion
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
