Topic: Need help for PID controlled line follower. (Read 2935 times) previous topic - next topic
tomriddle
Hello Everyone,
I have a  simple 150rpm line follower. But now I need a PID controlled fast line follower for a local line following competition. I have tried to make the algorithm to use with arduino but i am not getting how to get the current position and how to drive the motor to the accurate position. Please help me  :( my competition gonna start 5th March.
rares_mihai36
Code: [Select]
#include <PololuQTRSensors.h>
#define NUM_SENSORS             6  // number of sensors used
#define NUM_SAMPLES_PER_SENSOR  4  // average 4 analog samples per sensor reading
#define EMITTER_PIN             12  // emitter is controlled by digital pin 2
// sensors 0 through 5 are connected to analog inputs 0 through 5, respectively
PololuQTRSensorsAnalog qtra((unsigned char[]) {0, 1, 2, 3, 4, 5},
  NUM_SENSORS, NUM_SAMPLES_PER_SENSOR, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
int MOTOR1_PIN1 = 5;
int MOTOR1_PIN2 = 6;
int MOTOR2_PIN1 = 11;
int MOTOR2_PIN2 = 10;
int buton = 2;
unsigned int last_proportional = 0;
long integral = 0;
int ok=1;
int center;
  pinMode(MOTOR1_PIN1, OUTPUT);
  pinMode(MOTOR1_PIN2, OUTPUT);
  pinMode(MOTOR2_PIN1, OUTPUT);
  pinMode(MOTOR2_PIN2, OUTPUT);
  pinMode(buton, INPUT);
  pinMode(8,INPUT);
  int i;
  pinMode(13, OUTPUT);
  while(digitalRead(buton)==LOW)
{digitalWrite(13, HIGH);
digitalWrite(13,LOW);
delay(500);}
delay(2000);
digitalWrite(13, HIGH);    // turn on LED to indicate we are in calibration mode
  for (i = 0; i < 400; i++)  // make the calibration take about 10 seconds
    qtra.calibrate();       // reads all sensors 10 times at 2.5 ms per six sensors (i.e. ~25 ms per call)
  digitalWrite(13, LOW);     // turn off LED to indicate we are through with calibration
center = qtra.readLine(sensorValues);
{digitalWrite(13,LOW);}
delay(1500);
unsigned int position = qtra.readLine(sensorValues);
// The "proportional" term should be 0 when we are on the line.
int proportional = ((int)position) - center;
// Compute the derivative (change) and integral (sum) of the
// position.
int derivative = proportional - last_proportional;
integral += proportional;
// Remember the last position.
last_proportional = proportional;
int power_difference = proportional*3.3 + integral/10000 + derivative*7;
// Compute the actual motor settings.  We never set either motor
// to a negative value.
const int max = 180;
if(power_difference > max)
    power_difference = max;
if(power_difference < -max)
    power_difference = -max;
if(power_difference < 0)
  go(max+power_difference, max);
    go(max, max-power_difference);}
void go(int speedLeft, int speedRight) {
  if (speedLeft > 0) {
    analogWrite(MOTOR1_PIN1, speedLeft);
    analogWrite(MOTOR1_PIN2, 0);
  else {
    analogWrite(MOTOR1_PIN1, 0);
    analogWrite(MOTOR1_PIN2, -speedLeft);
  if (speedRight > 0) {
    analogWrite(MOTOR2_PIN1, speedRight);
    analogWrite(MOTOR2_PIN2, 0);
  else {
    analogWrite(MOTOR2_PIN1, 0);
    analogWrite(MOTOR2_PIN2, -speedRight);
Hi i have a problem with my line follower robot. It can t follow the line properly so if you can help me improving pid i will be very grateful. Here is the video which cand explai better the robot's behaviour http://www.youtube.com/watch?v=04i1NqcbhpA&feature=youtu.be
Thank you anticipated!
