Topic: Programmer not responding (Read 2075 times) previous topic - next topic
Coding Badly
#15
May 17, 2012, 08:26 am Last Edit: May 17, 2012, 08:27 am by Coding Badly Reason: 1
The only thing left is to try to reflash the firmware using your friend's Mega configured as a "programmer".  I may be able to help you until you reach the point of actually reflashing the firmware; the avrdude command to execute.  Unless someone else steps in to help, at that point you will be on your own.
I suggest first spending some time with Google; you may be able to locate detailed instructions...
https://www.google.com/search?q=atmega8u2+uno+firmware+avrdude
Bear in mind that your board and/or processor may be toast.  After reflashing the firmware your board may still be unusable.
KelvinLee516
Alright then. I'll see if I can borrow his Mega and I'll come back to this thread then. Anyway, thank you very much for the guidance. :)
