Topic: Cheap/easy/efficient way to switch 5A without a 5A switch? (Read 3711 times) previous topic - next topic
scswift
Hey guys,
The board I'm currently developing has the potential to draw a lot of power, and I need a way to disconnect the battery from the voltage source.  Normally I'd just use a switch, but switches you would mount on the board which can handle >5A are kind of bulky and expensive ($2-$3 is a lot when you're thinking about having 50 boards made), and there's not a whole lot to choose from.
A relay would be an obvious solution, but since this is a battery powered device a relay would be too wasteful.  Also I imagine they're even more expensive than a switch.  And probably too bulky for a tiny SMD board to boot.
I'm probably just going to live with there being only one or two good on-board switch choices, and have a terminal block for mounting an external switch for which the current won't be an issue, but I'd still like to know if there is some really obvious way that everyone handles this problem.
I thought perhaps a mosfet would do the job.  I found this one that can handle 8A:
http://search.digikey.com/us/en/products/ZXGD3004E6TA/ZXGD3004E6CT-ND/1827768
I'm not sure how you use it, I haven't used one before and the circuit diagram is a bit confusing, but it is a transistor and if I'm not mistaken switching large currents is what they're deigned to do.
As I mentioned in other threads though, I am kinda squeezed for space on this board, so if I could avoid using another component entirely that would be nice.  So another thing I've been wondering about is if there isn't some kind of voltage regulator with a built in switch.
CrossRoads
That's not the right part - that one is intended to drive a 2nd transistor that actually controls the current.
http://search.digikey.com/us/en/products/SI5471DC-T1-GE3/SI5471DC-T1-GE3CT-ND/2442004
A part like this would probably be better as a High Side switch -that is, it switches the 5V on and off to the circuit.
You would have the Gate pulled high to turn things off.
A switch would take it low to turn things on, your circuit would then hold it low to keep things on.
Your circuit releasing the gate then lets it get pulled high to turn the MOSFET off.
I'm sure there are applications written up covering that kind of behavior.
scswift
Hm, if I understand you right, what you're suggesting is a setup where I could either use a regular switch or a momentary pushbutton to pull the gate low, and then either the switch could continue to hold it low, or the microcontroller itself would be connected to it via a pin and hold it low after the pushbutton is released, in which case it would work like the power button on many modern electronic devices.
That's a neat idea.  But how would the microcontroller know when to turn the device off again if the pushbutton were only connected to the gate and ground?
So I did some reading on mosfets being used as switches and like you said, high side seems to be the preferred way of doing things.  I still don't have a real good grasp on exactly how that's wired up, but it seems that you need a p-channel mosfet for that, and that's what you've linked to.
Here's another p-channel I found in my search for the least expensive / smallest one:
http://www.vishay.com/docs/68717/si2333cd.pdf
Would that be suitable?  I notice the gate charge voltage is lower on that.  I don't know what that is though.  If it helps, I'm trying to design my circuit to handle at least a little over 12V on the input.  16V would be nice.  That drain-source voltage on the absolute max rating is a concern though.  I'm not sure if that -12v is calculated by subtracting drain from source or if the dash just means "drain to source".  But some other documents indicated Vgs means Vg - Vs, so I'm thinking Vds is the same.  5v - 12v = -7 so I think both Vgs and Vds might be okay?
That one you linked might not be suitable due to to the package.  I'm not sure if the PCB manufacturer will do pads on the bottom like that with their low cost assembly deals.
hardcore
#3
Feb 22, 2012, 01:56 am Last Edit: Feb 22, 2012, 02:02 am by hardcore Reason: 1
Devils advocate
Not cheap or small, but easy:
Bistable or latching relay.
CrossRoads
The part you linked to has a higher Rds
Drain-Source On-State Resistancea RDS(on)
VGS = - 4.5 V, ID = - 5.1 A 0.0285 0.035
VGS = - 2.5 V, ID = - 4.5 A 0.036 0.045 ?
VGS = - 1.8 V, ID = - 2.0 A 0.046 0.059
so it will run warmer at higher current.
The surface mount part I linked is installed like any other surface mount part.
To turn the part off, you will just stop driving the gate low, the pullup resistor will turn it off.
When to turn off is decided in your code - time on, button read, etc.
Latching relay is likely to be a larger part. And you have to be able to pulse current both directions to make it switch.
kf2qd
Can you use the power connector as the switch? Can you switch the power coming to the board instead of having a switch on the board? Adding some transistor device just adds complexity, and probably doesn't help reliability.
scswift
Putting the power switch on the power cord wouldn't solve my problem.  The switch was going to be off the board anyhow, and either way it would still have to be able to handle the current, and that would limit my choice of switches.
The reason I need to do this is because the board I'm designing is for a replica movie prop and the end user will want to be able to select whatever switch looks best.  They also won't know enough about electronics to select a switch capable of handling the kind of current the board might draw in their particular application.  So putting as little current as possible through the power switch is the safest and most flexible setup.
I've decided I'll probably go with a mosfet.  It looks like I can get a tiny one that can handle the current I need.  I just need to understand how to select one and wire it up properly.  The information provided so far has been helpful, but I'm still foggy on the details and I wanna understand this thing well before I stick it in my circuit.
scswift
#7
Feb 22, 2012, 09:31 pm Last Edit: Feb 22, 2012, 09:40 pm by scswift Reason: 1
So I've been reading pages and pages of stuff about mosfets and I'm still confused about a few things:
1) Why is it recommended I use a p-channel mosfet on the high side, rather than an n-channel on the low side?
I understand that a high-side n-channel isn't a good idea.  It seems there is a voltage drop and a need for a bootstrap capacitor.  But there seems to be no such issue with a low side n-channel and most of the tutorials seem to be about n channels, and the cheapest high power mosfets seem to be n-channels as well.
Is it because in a low-side setup with an N-channel mosfet, the gate needs to be pulled high, and that would mean if I had a 24v source, Vg would be 24v, Vs would be 0, and Vgs (which is Vg - Vs) would be 24v, and Vgs = 24v is too much for the mosfet to handle?
But in a high-side setup, isn't Vgs going to just be -24v instead, so there would be no benefit to that setup?
2) Is a resistor needed on the gate to limit the current flow through the switch?  What would be a good value for this?  How would I calculate it?
3) Will the mosfet be drawing power all the time when it is off?  I saw a post on Sparkfun where someone mentioned this in regards to their n-channel mosfets.  I guess they don't turn off completely unless you pull the gate to ground via a 1M resistor?  With a 1M I guess I wouldn't need to worry about draining my battery too much when it's off.  I don't know how fast that would turn off though.  100K and 10K are suggested for faster turn off at the expense of more current.
Oh and just so you know, the circuit won't be running off 24v, I just used that as an extreme example because I don't know what voltage the mosfet might be able to handle at the gate.  The voltage in my circuit should actually be limited to around 12v, though I'd like the option to go up to 16v is possible since the rest of the components can handle that.
scswift
I'm trying to calculate how much power the mosfet will need to dissipate as well.
Is this correct?
Rds (resistance between source and drain) = 35 milliohms = .035 ohms
Id (current at drain) = 5A
P = I^2 * R
So:
5A^2 * 0.035 = .875 watts
It seems a little odd to me that the voltage isn't taken into account there.
CrossRoads
P= I^2 * R
V= I*R, subsititute in:
P = I * V
P = (V^2)/R
take your pick.
Will add something about the rest when I get home
scswift
Quote
P= I^2 * R
P = I * V
P = (V^2)/R
take your pick.
I think I get what you're trying to say... that voltage and current are related.  I still have a hard time wrapping my head around that concept.
If I understand right though, then I think knowing Rds and Id, I can calculate the voltage drop across the mosfet like so:
P / I = V
.875W / 5A = .175V
Is that correct?  Would there be a .175v drop across the mosfet if I'm drawing 5A from it and if Rds were 0.035 at Vgs = -12v?
Or should I perhaps be using Vsd for this calculation, and Vgs just happens to work here cause they're the same?
scswift
#11
Feb 23, 2012, 01:26 am Last Edit: Feb 23, 2012, 01:28 am by scswift Reason: 1
I've also created a schematic for how I think this is all supposed to be wired up:
Is the switch supposed to just go directly to ground like that, or should there be a resistor?
And is 1M a good choice for the pullup on the gate, or would a lower value be fine / better?  Could I use a 10K or would that drain my battery?
CrossRoads
1. P-channel vs N-channel. P-channel, only the MOSFET has power live at its terminal, vs the whole circuit being 'live' waiting for a ground connection to be made.
2. Power: power dissipated by the MOSFET is I^2*R, or 5A * 5A * 0.020ohm with the MOSFET I suggested, or 0.5W.
Voltage loss across the MOSFET Vds will be V=I*R = 5A*.02 = 5*.02 = 0.1V.
CrossRoads
Smaller resistor would be okay, current into the gate will be minimal.
scswift
Quote
I take it this means you think my schematic is okay as is then?
How do I calculate how much current will flow into the gate?
Quote
I don't understand the concept of the circuit being "live" when power isn't applied to it. How does it make a difference if +12v line is attached to the regulator, or 0v?  It's all relative potential, isn't it?
