Topic: simple and best way to shift LED on digital pins with a button (Read 834 times) previous topic - next topic
Joy
I am thinking of a simple program where I have 5 LED connected to arduino'd digital pins..
and a button connected to another digital pin of arduino...
Now I would like to press the button to shift the glow of the led
initial state LED 1 = HIGH
press button LED 1 = LOW LED 2 HIGH
press button LED 2 = LOW LED 3 HIGH
Joy
I thought if something like this but unable to put it in form... :P
Code: [Select]
if (buttonState == HIGH)
S++
digitalWrite(s , HIGH);
cutebuddy6
Joy
5 LEDs connected on digital pins 2, 3, 4, 5, 6
pushbutton connected to digital pin 12
now when I power up the arduino
LED 1 is on.
every time I press the button the next LED will glow and the previous LED will shut off
cutebuddy6
CrossRoads
Code: [Select]
void loop(){
if (digitalRead (button == LOW){  // assumes you have pin declared as INPUT with internal pullup enabled
LEDstate= LEDstate +1;  // cycle thru the LED modes
if (LEDstate == 5){  // reset it last LED
LEDstate = 1;
delay (50);  // debounce delay, crude
switch(LEDstate){
case 1:
digitalWrite (LED1, HIGH);  // assumes HIGH output to LED Anode, cathode to resistor to ground
digitalWrite (LED5, LOW);  // assume you also set all outputs LOW during void setup
case 2:
digitalWrite (LED2, HIGH);
digitalWrite (LED1, LOW);
case 3:
digitalWrite (LED3, HIGH);
digitalWrite (LED2, LOW);
case 4:
digitalWrite (LED4, HIGH);
digitalWrite (LED3, LOW);
case 5:
digitalWrite (LED5, HIGH);
digitalWrite (LED4, LOW);
Joy
Joy
@ CrossRoads
I am little confused with both your and my code..
That if the button is kept pressed will the LEDs keep shifting..???
If so then I do not want that.. :(
I want that when the button is pressed once and then until it is been released and pressed once again there should be no shift...
CrossRoads
Yes, press once, the LED state is changed. Same case x: keeps repeating until button is pressed again.
Brad Burleson
Well, the code would just need a minor tweak then to do what you want.  How about this:
Code: [Select]
boolean pressed = false;
  if (digitalRead (button) == LOW){  // assumes you have pin declared as INPUT with internal pullup enabled
    if (!pressed) {
        LEDstate = 1;
      pressed = true;
    pressed = false;
  switch(LEDstate){
  case 1:
  case 2:
  case 3:
  case 4:
  case 5:
Hope this helps,
Brad.
PS I assume that that delay(50) should always be called?  There may have been a slight error in the original code (it only did delay when LEDstate hit 5)
CrossRoads
Joy
#11
Feb 22, 2012, 04:06 am Last Edit: Feb 22, 2012, 04:52 am by Joy Reason: 1
I was saying that I do not want to use delay...
And truly speaking I am writing this program to change display modes on an LCD...
like
when case 1
LCD prints
x
when case 2
LCD print
y
when case 3
LCD prints
z
like this...
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
