Topic: Arduino Motor Shield output Voltage problem (Read 1 time) previous topic - next topic
virgil
Hi, everyone. This is my first Arduino project, I really need your help. I tested the DC motor using in this project by simple code, it can work only one direction. So I measured the motor shield output voltage and found something wierd. The PWM value is the same for both motor working direction. But the out voltage get from is -7v and 0.1V(this should be 7V). What's the problem?
Thanks in advance.
johnwasser
Set the PWM output to 255.  Then the output voltage should switch between + the supply voltage to - the supply voltage as you change direction.  If one of the voltages is still WAY off there is probably a problem in the H-bridge.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
virgil
Thanks a lot John. One more questions, did you see my last post about motor running problem? What's your point about that?
johnwasser
I probably saw it but I don't remember it.  If I saw it and didn't answer I probably had nothing to add.
