Colorado
Reviving dead brain cells with Arduinos.
« Reply #15 on: February 23, 2012, 12:47:27 am » |
01005 (0402 metric): 0.016 × 0.008 in (0.41 × 0.20 mm) Typical power rating for resistors 1/32 watt 0201 (0603 metric): 0.024 × 0.012 in (0.61 × 0.30 mm) Typical power rating for resistors 1/20 watt 0402 (1005 metric): 0.04 × 0.02 in (1.0 × 0.51 mm) Typical power rating for resistors 1/16 watt 0603 (1608 metric): 0.063 × 0.031 in (1.6 × 0.79 mm) Typical power rating for resistors 1/16 watt 0805 (2012 metric): 0.08 × 0.05 in (2.0 × 1.3 mm) Typical power rating for resistors 1/10 watt 1008 (2520 metric): 0.1 × 0.08 in (2.5 × 2.0 mm) 1206 (3216 metric): 0.126 × 0.063 in (3.2 × 1.6 mm) Typical power rating for resistors 1/8 watt 1210 (3225 metric): 0.126 × 0.1 in (3.2 × 2.5 mm) Typical power rating for resistors 1/4 watt 1806 (4516 metric): 0.177 × 0.063 in (4.5 × 1.6 mm) 1812 (4532 metric): 0.18 × 0.12 in (4.6 × 3.0 mm) Typical power rating for resistors 1/2 watt 2010 (5025 metric): 0.2 × 0.1 in (5.1 × 2.5 mm) Typical power rating for resistors 1/2 watt 2512 (6432 metric): 0.25 × 0.12 in (6.3 × 3.0 mm) Typical power rating for resistors 1 watt 2920 (7450 metric): 0.29 × 0.20 in (7.4 × 5.1 mm)
* source: WikipediaI have personally worked with sizes down to 0402, but not smaller.
Austin, TX
I make my own electricity.
« Reply #16 on: February 23, 2012, 10:08:03 pm » |
I've worked down to 0603, but I'm almost 50, wear bifocals, have minor arthritis (do NOT spend decades learning to type ever faster -- it wrecks havoc on the joints. I've since given up on 0603's until I get someone else to do pick-and-place and reflow soldering. Which means, when I change the layout from 1206's to 0603's, I'm gonna have a TON of free space!
SE USA
@ssh0le
« Reply #17 on: February 23, 2012, 10:20:03 pm » |
I can do a 402 by hand (though I really really rather not) and check it under a microscope lol, and I did a few SOT23 6 terminal flip flops today, which is a little bit bigger than a 1008 ... but its got 6 pins
« Last Edit: February 23, 2012, 10:22:47 pm by Osgeld »
Austin, TX
« Reply #18 on: February 23, 2012, 10:28:32 pm » |
I can solder tiny pins. It's moving around the tiny parts. For tweezers, I use a pair I picked up at Fry's that have tips sharp enough to kill. The fine point also seems to prevent heat conduction, so the part and solder get hot, and the heat stays there and doesn't conduct to the tweezers (and make the part cold). Solder =wants= to fill in any gaps it can find, thanks to the miracle that is surface tension. Stay away from the coffee and lots of tiny pins shouldn't be too hard. Though I think I'm gonna buy me a hot air soldering thingy soon.
« Reply #19 on: February 23, 2012, 11:22:54 pm » |
The hot air thing is a substitute for the oven I guess?
Austin, TX
« Reply #20 on: February 23, 2012, 11:29:12 pm » |
Yes and no. A hot air soldering pen can be used on small areas. Whereas an oven can't be used on small areas  Here's a demo. Note how huge his finger is and how small the QFN is -- http://www.youtube.com/embed/c_Qt5CtUlqY
Peoples Republic of Cantabrigia
Arduino happiness
« Reply #21 on: February 24, 2012, 09:29:35 am » |
Correct, hot air systems are great for replacing components or working small sections at a time. But if you have any interest in getting things done quickly, the stencil approach is hard to beat. Plus, there is usually little to no rework after the fact because the solder paste amount is always right (ie no bridges to be removed). I guess it comes down to how much you value your time.
« Reply #22 on: February 24, 2012, 10:45:24 am » |
I value my money more than my free time lol
Colorado
« Reply #23 on: February 24, 2012, 11:01:12 am » |
Heh, I used to think that way too, money before free time. The problem is, I call that penny wise, pound foolish. At least for me it was. I used to think I could do it all by hand and save money, but it was taking forever and on parts that small, I was having more misses than hits. So, I invested in a cheap electric skillet and now I do everything by reflow. I do still cut my stencils by hand, but most of what I have done so far wasn't too crazy. The most pads I had to cut were 288 on one PCB, of which 168 of them were 0.5mm pitch. THAT was fun to cut by hand. Took about an hour. But, the reflow of all 20 boards took about 20 minutes.
Now I'm working on a project where there will be several different PCBs and this time I'm just going to get stencils made. Especially since I have a QFN32 and a MLF32 on one of them.
« Reply #24 on: February 24, 2012, 02:19:08 pm » |
Well that and I don't think my parents would let me get anything like that, they'd kill me if they knew I soldered in the house as often as I do
Arduino happiness
« Reply #25 on: February 24, 2012, 02:26:09 pm » |
Why? Fire risk? The only truly dangerous part IMO is the potential for lead and acid fumes to do their thing unless you use a fume hood to collect that stuff.
« Reply #26 on: February 24, 2012, 02:58:28 pm » |
That's the silly part, my parents don't know or understand what I do, all they know is soldering is dangerous apparently and my parents are not very open to debate or learning something new
