Author Topic: 8x8x8 LED Cube  (Read 1768 times)
Mumbai
Its Simple Technology, What will you do with It!
I am planning to make an 8x8x8 LED Cube.
This, I guess is gonna be my first big project.
As of now I am practising on an 8x8 dot matrix and now would be starting to build with cube.
Since many of you would have made such cubes, I would want to ask for some advice for a starter.
If any1 can post a link to a good DIY 8x8x8 LED cube or would like to give any personal suggestion or advice from their experience then it would be really appreciated.
Lastly I would like to ask is, Since I am making this project on an Arduino. Will it be possible to get the code permanently written on a Micro controller chip so that I can properly case the cube n make it permanent. (I ask this question because I know you can make a copy of chip using the UNO but I have a Mega ADK having a Mega2560 and would like to know if it is possible to make a copy of the project on a smaller chip ie: ATMega 128, 328 etc. )
Thankx in Advance for the Help
Left Coast, CA (USA)
Measurement changes behavior
The code is compatible, it's just a matter of how much memory (both flash and sram) your program ends up using and how many I/O pins and other hardware features your code uses if it can be compiled and run off a 328p chip. There is also the 644p and 1284p chips that could be candidates if the 328p comes up short on those resources.
Lefty
http://www.instructables.com/pages/search/search.jsp?cx=partner-pub-1783560022203827%3Anpr2q7v5m6t&cof=FORID%3A11&ie=ISO-8859-1&q=LED+CUBE
Plenty of tutorials there mate. Should find some code for a 168 or similar too.
You could always build a bare-bones arduino that can be programmed, then you don't have to worry about converting the code from your mega.
You have loads of options when controlling the cube too, direct driven, multiplexed, shift registers, TLC chips etc etc.
Looks like a fun project though smiley-grin
Seattle, WA
Demonic69 is on the right track (great name btw!lol) this instructible is EXTREMELY informative:
http://www.instructables.com/id/Led-Cube-8x8x8/
i urge you to check it out, i learned so much from it.
it uses a permanent custom built controller that runs off an ATmega32, but i would highly suggest that if you build it like they do to just build your own arduino with a ATmega328. It is possible, they show it using one in one of the last steps, and i think arduino is easier and overall better than the code they use. tell me what you think! hope it helped.
"It's Dr. Evil. I didn't spend six years in Evil Medical School to be called 'mister,' thank you very much."
Mumbai
Thankx guys.
The info was helpful.
smiley
UK
Nobody can go back and start a new beginning, but anyone can start today and make a new ending.
How the cube is made:
The dimensions of the cube will be 8 led by 8 led, by 8 led, for a total of 512 leds. The whole structure will be based on a wood board.
The concept of persistence of vision:
In this project we will exploit the persistence of vision. This phenomenon is a feature of the human eye and is responsible for the illusion that a movie is not composed by individual still images. All the animations are based on this biological dis-functioning of the human eye. If we can switch on and off the leds in a sufficiently quick time, (a few milliseconds) they will appear as if they were simultaneously on.
We use the persistence of vision because simultaneously switching all the cube leds on would require a very high electric current (in ampere). Actually, if we consider that the high brightness leds of this project require about 20 mA, we can calculate that 512 leds would require 10.24 A. This high current is hard to manage. So, what we do? We switch on a cube layer at each time! In this way the current consumption will never exceed 1.28 A (20 mA x 64 leds), which is easily supplied by a good voltage transformer. Let us suppose that we want to make the cube appear as completely switched on. To achieve that we simply have to switch on the different layers one by one at high speed. To a human eye the cube will appear as completely lighted.
How to control each led:
In order to independently control each led, we divide the cube into horizontal layers and vertical columns.
All the leds of a horizontal layer will have the cathodic contact (-) in common.
All the leds of a vertical column will have the anodic contact (+) in common.
Overall, it will be necessary to control 8 cathodic contacts to select the layers and 64 anodic contacts to select the columns. The combination layers by column will select and switch a single led.
The 8-bit shift registers:
The shift registers are composed by 1-bit memory cells connected one each other. At each clock impulse, they allow the bit flowing from a cell to the next-one. The registers used in this project are SIPO (serial input-parallel output) type. The data are charged one by one through the input bits and the output bits are simultaneously collected from the 8 outlets.
Power supply':
To power the cube and the control circuit it is necessary a power supplier with the following specifications:
- voltage: 5 volts (stabilized)
- current: 2 ampere (4 is better)
Needed tools:
- Soldering iron
- Soldering tin alloy
- Hot glue gun
- Jigsaw
Needed materials:
- 512 leds of your favourite colour
- 1 40 pin flat cable (to connect the IDE hard disk to the pc)
- 1 34 pin flat cable (to connect floppy disk to the PC)
- 1 prototype board
- 1 plywood board 20x20 cm, 8 mm thick
- Electric wire suitable for soldering (thin, flexible, and resistant)
Building:
Draw a 7x7 square grid (2.5 cm side) on the the plywood board. At the crossings of the grid lines drill 64 holes with a mesh diameter as the led size, generally 5 mm. This board will be the basis on which all the leds will be soldered. By this solid grid the leds will be evenly spaced and perfectly aligned. As explained in the intro, the cathodic contacts of each layer will be joint together. Insert the 64 leds in the board holes and bend the cathodic (-) terminal to obtain an interconnected grid.
SEE IMG. 02.1 AND 02.2
Let go out the board holes only one led terminal. It will control the layer.
Attention! Each time you finish soldering a layer, test each single led. It is convenient to discover early if a led is burned out or not well soldered.
SEE IMG. 03.1 AND 03.2 AND 03.3
Make 8 identical grids, paying attention that the led terminals going out of the board have a different orientation for each layer.
Mumbai
@Juis Mikly
Thankx smiley
Boston area, metrowest
I have some PCBs made up that would be great for this.
Use 8 TPIC6B595s as current sinks for the column cathodes. Use a 9th to control external PNP transistors (or add a UDN2981) as current sources into the Anodes for the rows.
Will post a pic when I get home if you're interested.
Mumbai
Sure, id like to see d pic.
I was thinking of using 74HC574, but nw ill consider TPIC6B595.
Thankx smiley
'574 is not a shift register tho.
Can be wired to work as one.
