Loading...
Pages: [1]   Go Down
Author Topic: L298N motor control  (Read 1324 times)
0
Offline Offline
Newbie
View Profile
Hello
I'm trying to control an ordinary 5 V DC Motor with the Arduino Board and the L298N H-Bridge.
I didn't yet figure out how the drive the motor in both directions in different speeds.
This is the way I connected the L298N to the Arduino:
Motor: Pin 2 and 3
Ground: Pin 1,8,15
+5V: 4 and 9
PWN9: Pin 5
PWN10: Pin 6
PWN11: Pin7
Here you can find the datasheet of the L295N:
http://www.datasheetarchive.com/search.php?q=L298N&sType=part&ExactDS=Starts
In programming I just switch PWN9 and PWN10 to high but the motor doesn't move.
Could anyone please tell me if I connected it correctly and what I have to do to make it work?
Thx
So long   trip
Logged
Poitiers (France)
Offline Offline
Full Member
Ca va j'vais le faire !
View Profile
WWW
Hello tripmaster,
  Your wiring seem to be good so I think that is your code that is bad.
  If pins 5 (In1) and 7 (In2) of the l298 are at the same level the motor stop quickly. If they are at different levels, the motor turn in one direction or the other.
  If the pin 6 (Enable) is low the motor don't turn is "free" (I don't know how to say "en roue libre").
  summary :
  Enable : LOW -> Nothing
  Enable : HIGH :
      In1 and In2 : LOW or HIGH -> Quick stop
      In1 : LOW and In2 HIGH -> the motor turn in one direction
      In1 : HIGH and In2 LOW -> the motor turn in the other direction
Logged
Cordialement,
Benoît ROUSSEAU
Pages: [1]   Go Up
Print
Jump to:
