Topic: Quick linux question: where do libraries go? (Read 669 times) previous topic - next topic
CowJam
Feb 23, 2012, 10:56 pm Last Edit: Feb 23, 2012, 11:28 pm by CowJam Reason: 1
I've just switched to ubuntu and I can't find where to put my libraries (which were in c:\arduino\libraries in windows), where do packages go once installed?
Edit: /usr/share/arduino/libraries
Now to figure out how to run stuff as root...
SurferTim
I'm using Ubuntu v11.10. If you are talking about v0022 installed from the repository, then that is in
usr/share/arduino/libraries/
I would recommend downloading IDE v1.0 from the Arduino site and unpacking it into a local folder. Then run the arduino shell script in that directory. That libraries folder will be in the same folder as the arduino shell script, normally
../arduino-1.0/libraries/
CowJam
SurferTim
If you don't like it, you can always run v0022 just like you do now. Then run the v1.0 shell script to convert your stuff to v1.0 format. I found that comforting in a way. I could upgrade without a total commitment to one version or the other.
