Loading...
Pages: 1 [2]   Go Down
Author Topic: Official Ethernet Shield crashes  (Read 1025 times)
Montemarciano, Ancona, Italia
Offline Offline
Newbie
View Profile
I know that the DHCP can take up to some minutes to respond (fortunately i've done the cisco ccna course around networks bases) and each time I try the sketch I wait 5 minutes. I've also seen that with "ipconfig /renew" new leases are released in a very short time, something like 10 - 15 seconds.
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
Quote
Good. Then it should not be difficult for you to assign a static ip to the Arduino. You should know all about ips, subnets, gateways, and dns. Once you assign a static ip to the shield, can you ping the Arduino ip from a localnet computer?
Logged
Offline Offline
Newbie
View Profile
Yes...
Logged
Offline Offline
Faraday Member
View Profile
OK! Now we are communicating!
It may be a bug in the dhcp routine. Remember, it is brand new.
Does everything you need to work do ok if you use the static ip assignment?
Logged
Offline Offline
Newbie
View Profile
Yes, this is why i think that the problem is the DHCP library!
I think that the only test i could do is to set up a wireshark listener and then check the Arduino DHCP Request packet content, if the arduino sends it. Otherwise the problem isn't the packet but something in preliminar code.
« Last Edit: February 26, 2012, 11:11:09 am by elQuero » Logged
Offline Offline
Faraday Member
View Profile
That, or check the router log. I don't use Cisco. I use Mikrotik. They both perform about the same functions. You might want to check your router's arp table also. How does it see the Arduino?
edit: Might want to check your dhcp leases also while you are in the router. Did the dhcp server lease your mac address an ip?
« Last Edit: February 26, 2012, 11:22:08 am by SurferTim » Logged
Offline Offline
Newbie
View Profile
Well, I have a Dlink SOHO device, and his log is very difficult to understand, so i've setup a test with Wireshark. I've tried to first send an UDP Packet with a fixed IP, and i can see packets in Wireshark. Then i've tryed to test the DHCP procedure and in Wireshark i can't see any DHCP packet.
For be sure i've tryed to listen to another PC and perform a "ipconfig /renew" comand and i've seen some packets.
Logged
Offline Offline
Faraday Member
View Profile
If it helps, I just tried my Mega2560 and ethernet shield on both a network with a dhcp server, and one without. The response was exactly as I expected on both. The dhcp issue was within a couple seconds. The fail took almost a minute.
Logged
Offline Offline
Newbie
View Profile
So i could think that there is a problem in my DHCP server and I should try to set up another server and see if there is a DHCP request?
Logged
Offline Offline
Faraday Member
View Profile
I don't know. I can't check your router from here.
If the router is a SOHO DLink, then you should be able to see the dhcp settings and leases in "Network Settings" in the router setup. See if your mac address is there.
Logged
Offline Offline
Newbie
View Profile
I've already checked that and i've seen that there are all the MAC addresses of my network hosts but not the mac address of Arduino
Logged
Offline Offline
Faraday Member
View Profile
You wrote this in an earlier post:
Quote
I've also experienced a loop in receiving data, because i use the linux compiler (i use lubuntu) for avr. But the ethernet shield begins correctly, that was my problem.
Did you install the "605 Bug" fix for that? I can see where that bug might affect dhcp too.
edit: That bug will affect dhcp and udp. Here is the function that will return the "forever non-zero" value in EthernetUdp.cpp
Code:
int EthernetUDP::available() {
  return W5100.getRXReceivedSize(_sock);
« Last Edit: February 26, 2012, 05:14:46 pm by SurferTim » Logged
Offline Offline
Newbie
View Profile
Hey, you are right!
The problem was that method in W1500.h. Now the DHCP does it's work correctly.
I think that for next problems i should search in google code arduino account issues before post here.
Thank you for helping, goodBye.
Logged
Offline Offline
Faraday Member
View Profile
You're welcome.
It isn't your fault. You could have gone to the Arduino code site, and not found that report. It is already marked as "fixed" and "closed". Does it seem like it is fixed to you?
HEY! ARDUINO CREW!! WAKE UP!!
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
