Author Topic: digital staus pin read  (Read 404 times)
I am reading 4 digital pin status and writing the messages in to the 16x2 display
example : if 0000 ( all 4 pins reads 0 i am writing " NO ALARM" )
  if 0001 i am need to write " Floor 1 leak "
i used switch - case for this but it is not succeeded , can you suggest any method , thanks in advance ,
-ariesprg
Massachusetts, USA
The switch statement should have worked unless you were doing it wrong.  If you show the code you tried we might be able to point out how to get it working,
Seattle, WA USA
Online Online
Seattle, WA USA
On the other hand, bitWrite() is pretty easy to use, to set one bit at a time. Much simpler code, that way.
Boston area, metrowest
Online Online
bitWrite doesn't really help for sending messages to an LCD does it?
I think perhaps bitRead would be more helpful.
messageCode = 0; // clear it out to start
// read the 4 bits and put them in place
messageCode = digitalRead(pinW)<<3 + digitalRead(pinX)<<2 + digitalRead(pinY) <<1 + digitalRead(pinZ);
switch (messageCode){
case 0:
// no alarm
break;
case 1:
// code for 1
break;
case 15:
// final code
break;
Seattle, WA USA
Online Online
Seattle, WA USA
No, but it could e used to set the bits in the byte that the switch statement is based on, where the cases decide what to write.
Thanks to all your suggestions , yes CrossRoads  Robert Ji , i followed your code and finished it ,below my sample
int messageCode = 0; // clear it out to start
  // initialize serial communication:
  pinMode(6,INPUT);
  pinMode(7,INPUT);
  pinMode(8,INPUT);
int bitData1 = digitalRead(6)<<2 ;
int bitData2 = digitalRead(7)<<1 ;
int bitData3 = digitalRead(8) ;
messageCode = bitData1 + bitData2 + bitData3;
    case 0:
    Serial.println("i am case 0");
    break;
    case 1:
    Serial.println("i am case 1");
    break;
    case 2:
    Serial.println("i am case 2");
    break;
    case 3:
    Serial.println("i am case 3");
    break;
    case 4:
    Serial.println("i am case 4");
    break;
Moderator edit: CODE TAGS
God bless..
« Last Edit: February 27, 2012, 06:49:17 am by AWOL » Logged
You do some programming to solve a problem, and some to solve it in a particular language. (CC2)
- When posting code, use the "#" button.
- Three bits give 8 combinations, not 5.
Do you really have to do something different for each of the 16 combinations of 4 pins or do you simply have to react to each pin status separately ?
Austin, TX
CMiYC
Why do your cases only go to 4?
An int is 16 bites wide.  Without resetting messageCode at the end of the loop() (or before combing your 3 dataBits together), you're shifting the previous results into the higher bits.  So you're probably only seeing a valid messageCode on the first loop().  Every iteration after that is a result you don't expect.
If digitalRead(6) is high on the first iteration you'll get messageCode = 4.  If it stays high on the next iteration, messageCode = 20.
Edit:  Thanks Paul.  Crossing out the incorrect explanation.
« Last Edit: February 25, 2012, 01:02:56 pm by James C4S » Logged
www.cmiyc.com - A guide to being an Enginerd
Seattle, WA USA
Online Online
Seattle, WA USA
I'm not following this logic. Each dataBitN is based on a read and a shift. The data bits are then added and assigned as a new value for messageCode. That looks right to me.
Austin, TX
CMiYC
You're right, I put too much though into it.
 smiley-eek-blue Bosses i respect all your responses , i am newbie to programming . basically biomedical guy . yes i need to react to all 16 combinations .thanks to all.  god bless.
South Texas
Are those 4 inputs all related to each other, or 4 seperate events? It would look like you have 4 seperate sensors that each need to send a message?
UK
Your code in reply #5 decodes 3 bits, but only has 5 of the eight possible cases.
It would be trivial to extend this code to four bits and sixteen possible cases.
