Topic: How to install UNO Rev3 board with Arduino IDE 1.0 (Read 2017 times) previous topic - next topic
jneylon2
How to configure a new UNO Rev 3 board with a new install of IDE 1.0.  The tools>board menu has a Arduino UNO selection but the drivers folder has BOTH ARDUINO UNO.INF and ARDUINO UNO REV 3.INF?  There is no entry in the tools>board menu for REV 3.
retrolefty
The .INF files are just used to set up the proper PC USB driver to support the Uno board revision you are using. The Arduino IDE board selection doesn't care what revision level Uno board is being used, the one Uno selection will support all Uno revision levels equally.
jneylon2
Thanks for clarifying how the IDE functions for all versions of UNO.  How to I install the correct UNO R3.inf?  Do I manually use the control panel>hardware>device manager>update driver to re-install the UNO R3.inf?  And if I do that, how can I get my FTDI driver back to run my Duemilanove on the same computer?
WizenedEE
If you installed it correctly the first time, it should be fine forever. But yes, that sounds like the correct way to reinstall the drivers. As for the FTDI drivers, your computer is smart enough not to try to run your mouse driver on a webcam, so it's smart enough to run your FTDI driver on a duemilanove and the other driver for your uno. It should "just work." If it doesn't, post back.
