Raindrop light. this is a light that i created it is a dimmer light that gets brighter and dimmer. in the shape of a raindrop.
Fade
This example shows how to fade an LED on pin 9
using the analogWrite() function.
This example code is in the public domain.
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
int rPin= 9;
int gPin=10;
int bPin=11;
// declare pin 9 to be an output:
//pinMode(9, OUTPUT);
// set the brightness of pin 9:
analogWrite(rPin, brightness);
analogWrite(gPin, brightness);
analogWrite(bPin, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness == 0 || brightness == 255) {
fadeAmount = -fadeAmount ;
// wait for 30 milliseconds to see the dimming effect
delay(30);
