Loading...
Poll
Question: how would basic stamp2 codes converted into arduino codes interfacing with parallax rfid read tags?
pls help - 2 (50%)
needed badly - 2 (50%)
Total Voters: 4
Pages: [1]   Go Down
Author Topic: converting basic stamp2 codes into arduino codes  (Read 905 times)
Offline Offline
Newbie
View Profile
Code:
' File...... rfid_rw_test.bs2
' Purpose... System-level test code for the Parallax RFID Read/Write Module
' Author.... Joe Grand, Grand Idea Studio, Inc. [www.grandideastudio.com]
' E-mail.... support@parallax.com
' Updated... 15 Dec 2009
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[ Program Description ]--------------------------------------------------------
' This program performs a system-level test of the Parallax RFID Read/
' Write Module by:
' 1) Reading tag's unique ID
' 2) Writing and verifying a block of data to the tag
' -----[ I/O Definitions ]------------------------------------------------------------
RFID_TX PIN 0 ' Connects to RFID R/W Module SIN
RFID_RX PIN 1 ' Connects to RFID R/W Module SOUT
' -----[ Constants ]------------------------------------------------------------------
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T9600 CON 84
#CASE BS2SX, BS2P
T9600 CON 240
#ENDSELECT
Baud CON T9600
' RFID R/W Module Commands
' Number of bytes returned in ()
RFID_Read CON $01 ' Read data from specified address,
' valid locations 1 to 33 (5)
RFID_Write CON $02 ' Write data to specified address,
' valid locations 3 to 31 (1)
RFID_Login CON $03 ' Login to tag with password (1)
RFID_SetPass CON $04 ' Change tag's password from old to new (1)
RFID_Protect CON $05 ' Enable/disable password protection (1)
RFID_Reset CON $06 ' Reset tag (1)
RFID_ReadLegacy CON $0F ' Read unique ID from EM4102 read-only tag
' (for backwards compatibility with Parallax
' RFID Card Reader, #28140 and #28340) (12)
' Memory map/address locations for EM4x50 tag
' Each address holds/returns a 32-bit (4 byte) value
ADDR_Password CON 0 ' Password (not readable)
ADDR_Protect CON 1 ' Protection Word
ADDR_Control CON 2 ' Control Word
' ADDR 3-31 are User EEPROM area
ADDR_Serial CON 32 ' Device Serial Number
ADDR_DeviceID CON 33 ' Device Identification
Copyright © Parallax Inc. RFID Read/Write Module, Serial (#28440) v1.0 6/29/2010 Page 10 of 10
' Status/error return codes
ERR_OK CON $01 ' No errors
ERR_LIW CON $02 ' Did not find a listen window
ERR_NAK CON $03 ' Received a NAK, could be invalid command
ERR_NAK_OLDPW CON $04 ' Received a NAK sending old password (RFID_SetPass),
' could be incorrect password
ERR_NAK_NEWPW CON $05 ' Received a NAK sending new password (RFID_SetPass)
ERR_LIW_NEWPW CON $06 ' Did not find a listen window after sending
' old password (RFID_SetPass)
ERR_PARITY CON $07 ' Parity error when reading data
' -----[ Variables ]------------------------------------------------------------------
buf VAR Byte(12) ' data buffer
idx VAR Byte ' index
idy VAR Byte
' -----[ EEPROM Data ]----------------------------------------------------------------
' -----[ Initialization ]-------------------------------------------------------------
Initialize:
PAUSE 250 ' let DEBUG open
DEBUG CLS ' clear the screen
DEBUG "Parallax RFID Read/Write Module Test Application", CR,
"------------------------------------------------", CR, CR
' -----[ Program Code ]---------------------------------------------------------------
Main:
DEBUG "Reading tag's unique serial number..."
Read_Tag:
SEROUT RFID_TX, Baud, ["!RW", RFID_Read, ADDR_Serial] ' Read tag's serial number
SERIN RFID_RX, Baud, [STR buf\5] ' Get status byte and data bytes
IF buf(0) <> ERR_OK THEN Read_Tag ' If we get an error, keep trying
' until the read is successful
FOR idx = 1 TO 4 ' Print data
DEBUG HEX2 buf(idx)
NEXT
DEBUG CR
DEBUG "Writing and verifying data to tag..."
Write_Tag:
SEROUT RFID_TX, Baud, ["!RW", RFID_Write, 3, $FE, $ED, $BE, $EF] ' Write $FEEDBEEF
' into address 4 (user EEPROM area)
SERIN RFID_RX, Baud, [buf(0)] ' Wait for status byte
IF buf(0) <> ERR_OK THEN Write_Tag ' If we get an error, keep trying
' until the write is successful
DEBUG "Success!", CR
DEBUG "End of test.", CR
END
' -----[ End of File ]----------------------------------------------------
Moderator edit: [code] [/code] tags added.
« Last Edit: February 27, 2012, 01:45:16 am by Coding Badly » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Need help with something?
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
This actually looks fairly straightforward to convert. I'd actually encourage the OP to find a tutorial or such on PBASIC, and sit down and try to convert the code over to Arduino C/C++; you'll learn an absolute ton in the process. Once you have something (even if it doesn't work or seems/feels "wrong"), post it here, and maybe we can help you take it the rest of the way.
Some hints for conversion:
1. Anything at the "top" of this code with "CON" in it, refers to a "constant"; most of the constants have to do with the RFID reader/writer commands, but a few have to do with the serial hookup (those can be mostly ignored; you really just need to set up a SoftwareSerial connection @ 9600 baud, 8n1 - I believe)
2. The section marked "variables" is simply defining a few global variables for use in the code; including one byte array
3. Anything with a single quote is mainly a comment (so heed them!)
4. Things like "Initialize:" and "Main:" are "labels"; they are something like functions in C/C++ (much more limited, though - this is BASIC after all)
5. A lot of the things inside and outside of the "Initialize:" section should be done in setup() in your Arduino code
6. The rest could also be called as functions from setup(); leaving loop() blank
7. If you use loop(), just make sure to have an infinite loop at the very end to "halt" execution
8. SEROUT/SERIN would be serial input/output commands; do similar things with the software serial library
9. DEBUG is the same as a Serial.println() command
So - in effect, choose a couple of pins for TX/RX for the software serial, set it up for 9600 baud, 8n1 to communicate to the RFID hardware, then write the code converted from the PBASIC example; use Serial.println() to output data back to the Arduino terminal via the virtual USB serial port...
Logged
Offline Offline
Newbie
View Profile
tnx for the hints, i'll try to convert these codes into arduino....if i ever encountered errors or probs i'll post em ryt away...
Logged
Offline Offline
Newbie
View Profile
@Coding Badly.... hey sir...could you please take a look in our codings....the
 5 volts dc to VCC
Pin 6 to SIN
Pin 8 to SOUT
0 volts to GROUND
Here is the sample code.....
Code:
#include <NewSoftSerial.h>
#define RFID_WRITE 0x02
#define txPin 6
#define rxPin 8
#define mem 7
#define first 3
#define second 12
#define third 4
#define fourth 16
NewSoftSerial mySerial(rxPin, txPin);
Serial.println("RFID Write Test");
mySerial.begin(9600);
pinMode(txPin, OUTPUT);
pinMode(rxPin, INPUT);
int val;
mySerial.print("!RW");
mySerial.print(RFID_WRITE, BYTE);
mySerial.print(mem, BYTE);
mySerial.print(first, BYTE);
mySerial.print(second, BYTE);
mySerial.print(third, BYTE);
mySerial.print(fourth, BYTE);
if(mySerial.available() > 0) {
val = mySerial.read();
if (val == 1) //If data was written successfully
{ Serial.println("Data written succesfully!");
else Serial.println("Error Code: ");
//If an error occured during writing, discard all data recieved from the RFID writer
delay(250);
the following code generates and output of
Erro Code: 2
Erro Code: 2
Erro Code: 2
Erro Code: 2
Erro Code: 2
and according to the datasheet of the parallax 28440
Error Checking
Value Name Description
0x01 ERR_OK No Errors
0x02 ERR_LIW Could not find a Listen Window (LIW) from the tag
0x03 ERR_NAK Received a No Acknowledge (NAK), possible communication error or
invalid command/data
0x04 ERR_NAK_OLDPW Received a No Acknowledge (NAK) sending the current password during
the RFID SetPass command, possible incorrect password
0x05 ERR_NAK_NEWPW Received a No Acknowledge (NAK) sending the new password during the
0x06 ERR_LIW_NEWPW Could not find a Listen Window (LIW) from the tag after setting the new
password during the RFID SetPass command
0x07 ERR_PARITY Parity error when reading data from the tag
the error above correspond to the error 0x02 which is the ERR_LIW could not find a listen Window(LIW) from the tag...
i don't know what is the meaning of this..can somebody give me an advice how to solved it.... thank you in advance.....
« Last Edit: February 27, 2012, 01:45:41 am by Coding Badly » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
Erro Code: 2
The code you presented cannot possibly output "Erro Code:" nor can it output " 2".
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Quote
* pls help
* needed badly
I want to vote for both of those. How do I do that?
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
I'll vote for one, and you vote for the other.
Logged
Pages: [1]   Go Up
Print
Jump to:
