Topic: H-Bridge Help !! for 14V DC Motors. (Read 4314 times) previous topic - next topic
jonny5
Feb 25, 2012, 05:02 am Last Edit: Feb 25, 2012, 05:05 am by jonny5 Reason: 1
Hey I have some DC Motors from two drills that were at the Good-Will. The specs on the drills are *14V DC 11Ah batteries and are geared with really good torque, plus a variable torque selector so you don't damage your motor. They can handle a continuous 12V 10Ah for 1 hour on my power supply, with minimal heat to motor and power supply. So my question is, will the 70L02P N- channel MOSFET work? And if so what type of H-bridge do i build?
I have 8 70L02P N- channel MOSFET's, 4 for each motor.
The labels in the H-bridge picture are wrong the image is just an example.
Thanks for the help.
Runaway Pancake
What's the current demand of one of those motors, not just spinning doing nothing, but under load (doing some work)?
I think that you should source an H-Bridge that's all done up.
Working out such a thing on your own, and with all N-channel FETs, is no mean feat.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
Elijahg
There's a fundamental problem with your schematic using all N FETs. Standard N FETs need Vcc + 12v to turn on properly, and your Arduino can only supply 5 volts. All the FETs will quickly get hot and burn out, as they aren't fully turned on or off. Your schematic also appears to have no delay in sides of the H bridge turning on or off, so you'd get shoot-through blowing up your FETs in short order. You'd need to add a delay in the FET turn on time, but ensure they turn off as quickly as possible.
I expect the current on those motors is moderately high under load or when stalled, probably in the 10 amp range at least. As runaway_pancake says, you'd probably do better to buy a ready made H bridge, as designing for own is no easy feat, especially if you want to use PWM.
If you are however really sure you want to make your own, I have made several successful H bridges based on the HIP4081a, though the PCB design can be a bit daunting at first. The HIP4081a ensures you can't get shoot through, generates the Vcc + 12v that the FETs need, and provides a logic level interface to the H bridge.
jonny5
#3
Feb 26, 2012, 05:15 am Last Edit: Feb 26, 2012, 05:18 am by jonny5 Reason: 1
Yes I have my hart set on making an H-Bridge. and I don't think I understand what your trying to say? Elijahg you said "Standard N FETs need Vcc + 12v to turn on properly"..... so to accomplish this I should have an Arduino friendly transistor to do the work of the on off of the fets. Since the picture I added is being used as a reference, you think you could ether edit or show me something to what I'm trying to accomplish with what I have? I have the 8 mosfets and 10 NPN 2N3904 transistors all types of caps and resistors, plus the motors. I mean, I have what I think to be all that Id need to get a cart up and running. yeah I have wheels, sprockets, chain,and wood. I have also built a tester board for the H-Bridge see picture. The power supply has two out puts, one 5V 2A and 12V 16A.
Runaway Pancake
Consider a "dual N-channel" half-bridge, there's the FET on the high side, the motor, and the FET on the low side.
Say you're using "logic level" FETs (IRL-xxx).
The motor supply is 14V.
The low side turns on with 5V to the gate, easy, but the high side's gate doesn't turn on fully till it's 19V (motor supply + gate threshold.)
Invest your time and $$$ elsewhere.
jonny5
well good news every thing I have so far I have picked up for free the mosfets I got out of power supplies for computers, the wood was free scrap from lowes, the sprockets and chains were from free old bikes on CraigsList, and the only thing paid for was the motors from good-will but they were really cheap like 5 bucks for all four. Instead of discouragement maybe you could help I have built basic H-bridges before with the 2N3904 transistors to make small ESC's for a quad copter that I built from the ground up, with balsa wood and toy helicopter gears and motors. Look I'm going to build this! Its Going to Work!
Is it possible to make this H-Bridge out of the mosfets that I have? (70L02P N- channel MOSFET's)
cr0sh
I don't know why you aren't paying attention to the advice others are posting...
If you want to make an all N-channel mosfet h-bridge, your high-side needs to switch at a higher voltage than the low side. Look into high-side mosfet gate drivers if you want to be able to do it the "simple" way.
Honestly, if you want to succeed at this project (instead of spending a lot of time and maybe money burning out mosfets), you will do good to purchase an h-bridge controller for the current needs of your motor(s). Homebrewing an h-bridge to control anything more than a few amps is not an easy task; yes, it can be done, but you'll probably end up spending more time and money burning up parts before you get a successful implementation, than if you had just purchased a pre-built h-bridge.
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
Runaway Pancake
I asked what kind of current those motors draw under load and I didn't get an answer.
I gave you some solid info on gate voltage in an all N-channel h-bridge and got not so much as an ACK.
3V or so for the lowside gate, 14V for the motor, that's 17V or so for the highside gate (and the VGS maximum is 20V).  Where will you get that?
How about reworking your schematic so that it shows what you actually propose instead of expecting others to imagine what's on your mind?
Rig up a half-bridge and get that going.  What's the worst that could happen?
Elijahg
Not without additional ICs, no. You would at a minimum need P channel MOSFETs in addition to the N channel ones you have. Have a look at http://www.talkingelectronics.com/projects/H-Bridge/H-Bridge-1.html design 6.
But really, as others and I have said, it will be expensive and it will take a long time to design and make your own high current H bridge. I've done it, and it took months and many £££ spent on MOSFETs even when using a reference design + scope to see problems.
jonny5
#9
Feb 27, 2012, 02:52 am Last Edit: Feb 27, 2012, 03:14 am by jonny5 Reason: 1
Thank you for the help I have looked up what all of you had said. With the motors that i have, they can easily be hooked up to the H-bridge thats current picture using FQP50N06 n-channel and FQP47P06 p-channel mosfets. i dont know how to test for current those motors draw under load. and i have no specs besides there brushed, when hooked up to my power supply under 5V 2A there hard to stop by hand and run at a good speed. same result when hooked up to the 12V 16A but at a faster RPM.
Runaway Pancake
#10
Feb 27, 2012, 03:40 am Last Edit: Feb 27, 2012, 03:43 am by runaway_pancake Reason: 1
You need to design in some default-state protection.
You don't want Q1 and Q2 on at the same time, the same for Q3 and Q4 - that's called "shoot-through" (a short circuit through your FETs = Poof!).
The lowside NPN bases should be pulled high, so that if there is no input, or it's disconnected, the N-FETs will be OFF, and there will be no shoot-through.
The highside NPN bases should be pulled low, so that if there is no input, or it's disconnected, the P-FETs will be OFF, and there will be no shoot-through.
*** When you do your initial testing, you'd better have a fuse on the motor supply till you know you're on the right track. ***
jonny5
#11
Feb 27, 2012, 03:53 am Last Edit: Feb 27, 2012, 03:57 am by jonny5 Reason: 1
I Have the 10K resistors in place to be a pull up resistors to keep the mosfets off to prevent a "shoot-through". As for default state protection i though that was for the code, and to have delays in code because it takes about 1/4 of a second to turn off and on. i have found after much research that having both NPN and PNP mosfets is the way to go in my H-Bridge.
On the NPN i should have a pull down resistor instead of a pull up?
jwatte
You _can_ make it work with the N-channels you have. The trick is to find a way to boost voltage of the gate input of the high-side N-channels. This requires either two supply rails (easy, if you are using a multi-voltage bench supply :-), or a voltage booster of some sort. You can build a booster circuit yourself out of a few transistors, two capacitors, and a clock source/timer. Or you can buy one, typically from manufacturers that also make voltage regulators. RECOM has one that goes from 12V to 24V for about 5 dollars from DigiKey. Then you have to figure out how to switch that on/off from an Arduino pin -- using a regular BJT transistor might be one way.
It all depends on what else you have available, and what your cost/time trade-off pain point is :-)
zoomkat
It may be worthwhile to purchase a working h-bridge like below. To use the NPN MOSFETs I think a bootstrap setup like bottom is sometimes used.
http://secure.oatleyelectronics.com//product_info.php?products_id=206&osCsid=30093449b694ae247d94c2bcce5d0560
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
jwatte
Quote
There is no such thing as an NPN MOSFET. There are N-channel MOSFETs (that need a positive voltage on gate compared to source to turn on) and P-channel MOSFETS (that turn on when the gate has a positive voltage compared to the source.)
I imagine you mean N-channel MOSFETs, because those are the ones that need positive booster circuits :-)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
