Loading...
Pages: 1 [2]   Go Down
Author Topic: Single pin Port Manipulation  (Read 797 times)
Canada
Offline Offline
Sr. Member
Sometimes teaching, always learning,
View Profile
Results:
Code:
Time for digitalWrite(): 4060
Time for true c command: 348
Time for true c command using #define: 348
Time for portWrite(): 2740
Logged
Canada
Offline Offline
Sr. Member
View Profile
It seems most of the time is going through the switch();. If I take out the pins I'm not using...
Code:
void portWrite(int pin, int state){
  if (state == 1){ //write HIGH
  switch (pin){
    case 13: PORTB = PORTB | 0x20; break;
  } else {// write low
  switch (pin){
    case 13: PORTB = PORTB & 0xDF; break;
...the speed results are impressive:
Code:
Time for portWrite(): 352
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
You might be interested in this work on making a "fastDigitalWrite()"...
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1267553811/all
Logged
www.cmiyc.com - A guide to being an Enginerd
Canada
Offline Offline
Sr. Member
View Profile
Thanks again James. The digitalWriteFast beats all the other options!
Code:
Time for portWrite(): 2744
Time for digitalWriteFast(): 288
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
And, one more...
static void portWrite(int pin, int state){
Logged
Canada
Offline Offline
Sr. Member
View Profile
What exactly does 'static' do? I ran my little test again, and there was no change in the speed.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
Odd.  I expected the optimizer to inline portWrite.  Oh well.
Quote
Informs the compiler that the function is only used within the one compilation unit.  In other words, it gives the compiler permission to be more aggressive when optimizing.
Logged
Canada
Offline Offline
Sr. Member
View Profile
I have just one more semi-related question...
If the internal 8MHz clock is used on a 328, can the crystal pins be used for I/O using port manipulation?
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Yes.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
