Loading...
Pages: 1 [2]   Go Down
Author Topic: Freezer code error help  (Read 595 times)
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Lets start with a review of the global variables.
Code:
int tempReading;
int tempPin = 1;
int photocellReading;
int photocellPin = 2;
int relayPin = 6;
float temperatureC;
The setup() function references relayPin. All the others are used only in loop() or functions called by loop(). Therefore, they should not be global in scope.
Code:
    if (relayPin = HIGH)
    if (relayPin = LOW)
Bzzzt. Wrong. You just assigned a new value to relayPin. This illustrates why pin variables (relayPin, tempPin, etc.) should be either #define or const. In this case, #define would not have help, but making relayPin const would have. The compiler would have told you that you were trying to overwrite a const variable, and that that is not allowed.
Logged
Offline Offline
Newbie
View Profile
Paul my good man, you are a champ haha. Let me explain - Running one program as a tester in which i change the code and see if it works or not, and then if it works, put it back into my main code. The code i last posted was the testing one in which i was attempting to display the status of the relay pin. Regardless After a bit more research I see the error in how I was trying to do it.
I also understand Global and Local scope better altho one question as a side not - you said
Quote
so does that mean that i can even move my " float temperatureC into the void loop? In other words even though temperatureC is called in the subroutine, it only needs to be declared locally?
Back to the problems that I am having - I measured the output voltage from the Digital I/O pin and it is 5 volts, and I rebuilt the circuit again, so there is no problem with the freezer. Ive gone over the code and over it and still don't understand what I am doing wrong. I changed the DAYHIGH, DAYLOW ect. to floating variable to give them decimal places like the temperature but even still it doesnt follow the routine. It just outputs a HIGH and doesn't change. Also when I change any of those parameters to a positive temperature (eg DAYHIGH 15.0 ) the arduino will not output anything at all. Could the delay be an issue?
Once again, thanks for your help - and here is the code
Code:
#include <Wire.h>
#include "RTClib.h"
#define NIGHTHIGH -19.0
#define NIGHTLOW -21.0
#define DAYHIGH 3.0
#define DAYLOW 2.0
#define aref_voltage 3.3
RTC_DS1307 RTC;
int relayPin = 6;
float temperatureC;
  Wire.begin();
  pinMode(relayPin, OUTPUT);      // sets relay pin as output
  analogReference(EXTERNAL);
  int tempReading;
  int tempPin = 1;
  photocellReading = analogRead(photocellPin);
  if (photocellReading < 10)
    Serial.println("Dark");
  else if (photocellReading < 200)
    Serial.println("Dim");
  else if (photocellReading < 500)
    Serial.println("Light");
  else if (photocellReading < 800)
    Serial.println("Bright");
    Serial.println("Very bright");
  tempReading = analogRead(tempPin);
  // converting that reading to voltage, which is based off the reference voltage
  float voltage = tempReading * aref_voltage / 1024;
  // now print out the temperature
  float temperatureC = (voltage - 0.5) * 100 ;  //converting from 10 mv per degree wit 500 mV offset
  //to degrees ((volatge - 500mV) times 100)
  Serial.print(temperatureC);
  Serial.println(" degrees C");
  DateTime now = RTC.now();                   // Get time from the RTC chip
  Serial.print("Time:");
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  if (now.hour() >= 7 && now.hour() <= 18)   //If time is between 7am and 7pm print Day time setting)
    Daytime();
    Serial.println("Temp set to -5'C");        // Display what Setting we are currently in
  else                                     //Else set to Night time setting
    Nighttime();
    Serial.println("Temp set to -20'C");      // Display what Setting we are currently in
void Nighttime()
  if (temperatureC > (float)NIGHTHIGH)  //Check temp and compare with setting and set the output accordingly
    digitalWrite(relayPin, HIGH);
  else if (temperatureC < (float)NIGHTLOW)
    digitalWrite(relayPin, LOW);
void Daytime()
  if (temperatureC > (float)DAYHIGH)  //Check temp and compare with setting and set the output accordingly
  else if (temperatureC < (float)DAYLOW)
Logged
New Jersey
Offline Offline
Edison Member
View Profile
Try putting your print statements back in the daytime and nighttime functions. If that doesn't help solve it, post the new code and the serial output again. Also, do you have a simpler sketch that proves you have control of the freezer using this relay? i.e. can you actually get it to run and stop?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
A global variable:
Code:
float temperatureC;
(initial value is 0)
A local variable containing the value read from the sensor:
Code:
A statement in a different function:
Code:
Cat you guess which temperatureC this refers to? Hint: It's not the one in loop().
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
