« Reply #45 on: April 14, 2012, 03:37:42 pm » |
No the RFM12BP (and lower power RFM12) uses a completely different RF chip. Although there are probably arduino code for it somewhere on the intarwebs since it's been around for a while.
Ok, will be easier to maintain rfm22 and when everything is operational, use the rf2126 booster mentioned by msev (datasheet says it is compatible with 433MHz).
« Reply #46 on: April 14, 2012, 04:09:36 pm » |
What would I have to modify in the circuit to use it for 433MHz? In regards to that example circuit for 2.4GHz?
« Reply #47 on: April 14, 2012, 04:23:45 pm » |
Take a look in the attached file.
« Reply #48 on: April 15, 2012, 02:46:38 am » |
Thanks, I must have had a "shortened" version of the datasheet... That looks great..hope these chips will still be available once I get to the stage of building a booster...Dfidalgo if you build it be sure to post some pics of it, a tell where you got the chip
« Last Edit: April 15, 2012, 02:56:06 am by msev »
« Reply #49 on: April 16, 2012, 08:56:45 am » |
Today I received the Zitron PCB's, look much better in my hands than here in the pictures !  Now just need to buy the RFM22. Thanks Zitron
« Reply #51 on: April 16, 2012, 09:42:39 am » |
What differences are between RFM22-S1 and RFM22-S2? Only the crystal size?
« Reply #52 on: April 16, 2012, 09:48:02 am » |
Yes, as far as I am aware, plus €0.50 better price !! Nigel.
« Reply #53 on: April 16, 2012, 10:25:52 am » |
Today I received the Zitron PCB's, look much better in my hands than here in the pictures !  Now just need to buy the RFM22. Cool! Let me know how it goes! What differences are between RFM22-S1 and RFM22-S2? Only the crystal size?
I heard someone mention that the bigger crystals have better frequency tolerances, but that could be just a rumour.
« Reply #54 on: April 18, 2012, 12:13:23 pm » |
Hi guys, For those of you building the board, here's a test code to make sure that the ATMEGA is working. It simply blinks the red and green LEDs: #define OUTA 18 #define OUTB 19
unsigned int duration = 500;
void setup() { pinMode(OUTA, OUTPUT); pinMode(OUTB, OUTPUT); }
void loop() { digitalWrite(OUTA,HIGH); digitalWrite(OUTB,LOW); delay(duration); digitalWrite(OUTB,HIGH); digitalWrite(OUTA,LOW); delay(duration); }
« Reply #55 on: April 20, 2012, 12:57:25 pm » |
I got my parts together now for a build of Zitrons latest board.
Works fine with the 'blink' test program.
When trying to compile the specan.pde - I get lots of errors due to missing files... FastSerial.h RF22.h C++.h Menu.h -- and many more.
@ Zitron, I guess you use other library files when making your specan & Tx/Rx firmwares.
Is there some single download I can get the required lib files or do I need to hunt them down individually?
EDIT Tracked down a bunch of missing lib files and now the only remaining compile error is:
C:\Arduino\arduino-0023\libraries\RF22\RF22_Specan.cpp:379: error: prototype for 'boolean RF22::setFrequency(float)' does not match any in class 'RF22' C:\Arduino\arduino-0023\libraries\RF22/RF22.h:813: error: candidate is: boolean RF22::setFrequency(float, float)
What do I need to change/add??
/EDIT
So close and yet so far !!
Nigel.
« Last Edit: April 20, 2012, 03:41:42 pm by Devonian »
« Reply #56 on: April 21, 2012, 07:08:00 am » |
Hi Great Find this Good work !!!!!!!
I downloaded the programs and Pde. but i get compilation errors almost so much that it looks like im missing a library , can some one please confirm this ? i have played with the RF22 modules alot so i have the RF22.h libraries but i cant get this source code to compile
any help would be great
« Reply #57 on: April 21, 2012, 07:55:05 am » |
Hi, I knew there would be problems! Which version of arduino are you using? I'm using 0023, I have not tested it on version 1.0. Try this version of the specscan without the fastserial stuff: // rf22_specan // A simple spectrum analyser for the RF22 // Uses the RSSI measurement to plot signal strength // against frequency // Specify the start and and requencies and the step size below. // The output is suitable for a VT100 terminal emulator // Note the baud rate is set to 115200 for better performance, // but you can change this to suit your needs // // TO DO: add some interactivity // Copyright Mike McCauley
// modified to work with PC program // Zitron
#include <RF22.h> #include <SPI.h> #include<stdlib.h>
#define redLED 18 #define greenLED 19
char temp[51]; uint8_t rssi; // Singleton instance of the radio RF22 rf22;
void setup() { pinMode(redLED, OUTPUT); pinMode(greenLED, OUTPUT); Serial.begin(115200); if (!rf22.init()) Serial.println("RF22 init failed");
rf22.setModemConfig(RF22::GFSK_Rb2Fd5); rf22.setModeRx(); // Defaults after init are 434.0MHz, modulation GFSK_Rb2_4Fd36 digitalWrite(greenLED, HIGH); }
float Start = 430; float End = 460; float Step = 0.1;
float freq;
void loop() { ProcessRx(); for (freq = Start; freq < End; freq += Step) { rf22.setFrequency(freq); digitalWrite(redLED, LOW); delayMicroseconds(6000); // Let the freq settle digitalWrite(redLED, HIGH); rssi = rf22.rssiRead(); Serial.print(rssi, DEC); Serial.print(","); //Serial.println(dtostrf(freq,0,3,temp)); } Serial.println(); //Serial.println(""); }
void ProcessRx() { byte n = 0; byte m = 0; char* sptr1; char* tempstr;
if (Serial.available()) { temp[n] = Serial.read(); while ((temp[n] != '\n')&&(n<50)) { if (Serial.available()) { n++; temp[n] = Serial.read(); } }
//Serial.println(temp);
tempstr = strtok_r(temp,",\n",&sptr1);
do { switch (m) { case 0: // Wheel 1 Start = atof(tempstr); break; case 1: // Wheel 2 End = atof(tempstr); break; case 2: // Wheel 3 Step = atof(tempstr); break; } m++; } while (tempstr = strtok_r(NULL, ",\n",&sptr1)); } } I have also uploaded my modified version of the RF22 lib.
« Reply #58 on: April 21, 2012, 09:02:44 am » |
Hi
I loaded both versions now and they seem to work great . thanx , one question , they PC application seem to very slow updating the graph
« Reply #59 on: April 21, 2012, 09:17:22 am » |
Hi
Update speed depends on how many steps you are scanning. By default it scans from 430-460MHz at 0.1MHz step (300 samples), which is a bit slow. You can make it faster by increasing the step size or reducing frequency range. BTW are you using your own board??
