Loading...
Pages: [1]   Go Down
Author Topic: ServoDecode Library in Arduino 1.0  (Read 1495 times)
Offline Offline
Newbie
View Profile
Will the ServoDecode library work with Arduino 1.0 on a Uno R3 (on a Windows 7 PC)?  Each time I try to compile I get an error message:
C:\Users\Owner\Desktop\Projects\Solair\arduino-1.0\libraries\ServoDecode\ServoDecode.cpp:3:18: error: wiring.h: No such file or directory
C:\Users\Owner\Desktop\Projects\Solair\arduino-1.0\libraries\ServoDecode\ServoDecode.cpp: In member function 'void ServoDecodeClass::begin()':
ServoDecode.pde:-1: error: 'INPUT' was not declared in this scope
ServoDecode.pde:-1: error: 'pinMode' was not declared in this scope
I'm not sure what modifications to the .cpp or .h file I might need to fix this.  Any help would be appreciated.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
In Arduino 1.0 the "wiring.h" file has been replaced by "Arduino.h".  Often that is the only change needed to get a pre-1.0 library working with 1.0.  Try making that change in ServoDecode.cpp
« Last Edit: October 21, 2012, 09:36:53 am by johnwasser » Logged
Offline Offline
Newbie
View Profile
Hi all,
as I would like to read in a PPM-Signal by using Interrupts I am also trying to work with the ServoDecode class in Arduino 1.0.1, as copied from http://arduino.cc/forum/index.php/topic,22140.0.html . But I (also) get the errors
ServoDecode.cpp:76: error: 'INPUT' was not declared in this scope
ServoDecode.cpp:76: error: 'pinMode' was not declared in this scope
ServoDecode.cpp:81: error: 'TIMSK1' was not declared in this scope
ServoDecode.cpp:81: error: 'ICIE1' was not declared in this scope
Does anyone can help?
Greetings
Jan
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Adding
Code:
#include <Arduino.h>
to the ServoDecode.H file right after
Code:
#include <inttypes.h>
fixes that problem.
Logged
Dubai, UAE
Offline Offline
Edison Member
View Profile
WWW
There is always this -
http://rcarduino.blogspot.com/2012/01/how-to-read-rc-receiver-with.html
and
http://rcarduino.blogspot.com/2012/04/how-to-read-multiple-rc-channels-draft.html
Duane B
Logged
Offline Offline
Newbie
View Profile
I getting the same problem. Did you manage to find the solution?
Logged
Dubai, UAE
Offline Offline
Edison Member
View Profile
WWW
What do you want to read, individual channels or a pulse stream containing all of the channels, I have code for both options which is used by many people and is also compatible with the standard servo library for generating your outputs.
Duane B
Logged
Offline Offline
Newbie
View Profile
thanks a lot. It worked with adding #include <Arduino.h>. The other problems came because i am using a myavr board with an Atmega8.
I want to read the PPM-Stream from a RC-Reciever.
Greetings
Jan
Logged
Pages: [1]   Go Up
Print
Jump to:
