Topic: Analog pin reads in different values (Read 1 time) previous topic - next topic
bradj17
I need help.  I am trying to read in a thermocouple that is connected to a wood stove.  I am simply converting the voltage to a temperature (in Fahrenheit) and displaying the temperature to three 7 segment LEDs (that are latched with D FF's).  It rings a piezoelectric buzzer if the temperature gets above a certain value.  My problem is that when I read in voltages on any Analog pin (I've tried pins A5 and A0), it will work fine for awhile then it changes to some other value.  See my serial read below.
0.76
0.75
0.76
0.74
0.74
0.77
0.73
0.79
0.36
0.36
0.36
0.36
0.36
0.36
0.36
0.36
0.36
0.36
0.37
0.36
0.36
0.36
0.36
0.68
0.46
0.74
0.76
0.74
I am hooking my thermocouple to an AD620 instrumentation op amp and my output is connected directly into the arduino A/D pin.  The actual voltage that I read from my voltmeter is around 0.54V and stays constant.  I don't care if it's off a little, but I can't have it going from 0.76V to 0.36.
Here is my code (but I think its a hardware issue) . . .
/*Brad Johnson - 2/12/12
This prgram inputs in an amplified thermocouple signal and outputs the temperature (in Fahrenheit) on three 7Seg LEDs.  It also rings a buzzer if the temperature gets greater than some value.
I could not get an interrupt working that would hush the alarm if the user hits a button.
int temperature = 0;          //Temperature from thermocouple
//int hushPin = 2;              //Shuts up the alarm
int buzzerPin = 10;           //Alarm
int hiLEDpin = 11;            //Hi 7 Seg Enable
int midLEDpin = 12;           //Mid 7 Seg Enable
int loLEDpin = 13;            //Lo 7 Seg Enable
//unsigned long time = 0;       //Reads the time for when the alarm has been hushed.
//boolean BuzzerOnFlag = true;  //Allows buzzer to Ring
//boolean readTimeFlag = false;   //Reads the time one time when hush button is pressed.
void setup()          //Sets up pins and interrups
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
//  attachInterrupt(0, delayBuzzer, RISING);
// detachInterrupt(0);
temperature = analogRead(5);              //Read in the thermocouple (amplified value)
      Serial.println((float)temperature/1024*5);
temperature = 1.049*temperature + 65.77;  //Convert A/D reading (0 to 1023) to Fahrenheit
decimalToThree7Segs(temperature);         //Display temperature (F) to Three 7Segs
if(temperature > 550) {
   digitalWrite(buzzerPin,HIGH);           //Sound Alarm!!!
   delay(250);
   digitalWrite(buzzerPin,LOW);            //Turn off alarm momentarily so it's not annoying.
   delay(15000);
   delay(1500);      //Don't want to bog down CPU
// if(BuzzerOnFlag == false) {                //If user presses "hush" button, then BuzzerOnFlag = LOW and readTime = high
// //  detachInterrupt(0);
// //  attachInterrupt(0,delayBuzzer,RISING);
//   if(readTimeFlag == true) {             //Read the current time
//     time = millis();                     //  only once
//     readTimeFlag =
//     false;
//   Serial.println(millis()-time);
//   if(millis()-time > 20000UL) BuzzerOnFlag == true;  //Once 10 min. has passed, return to normal operation
//void delayBuzzer()    //INTERRUPT - Enabled when user hits the hush button.
//    Serial.println("detached interrupt");
//    BuzzerOnFlag = LOW;
//    readTimeFlag = HIGH;
//    Serial.println("attached interrupt");
void write7Seg(int num)          //Writes to one 7Seg LED
  num = convertTo7Seg(num);      //Decodes decimal to 7Seg LED value
  digitalWrite(3,bitRead(num,0));
  digitalWrite(4,bitRead(num,1));
  digitalWrite(5,bitRead(num,2));
  digitalWrite(6,bitRead(num,3));
  digitalWrite(7,bitRead(num,4));
  digitalWrite(8,bitRead(num,5));
  digitalWrite(9,bitRead(num,6));
int convertTo7Seg(int number)    //Decodes decimal to 7SegLED value
  int sevenSeg;
  switch (number)
    case 0:
      sevenSeg = 0x3f;
    case 1:
      sevenSeg = 0x09;
    case 2:
      sevenSeg = 0x5e;
    case 3:
      sevenSeg = 0x5b;
    case 4:
      sevenSeg = 0x69;
    case 5:
      sevenSeg = 0x73;
    case 6:
      sevenSeg = 0x77;
    case 7:
      sevenSeg = 0x19;
    case 8:
      sevenSeg = 0x7f;
    case 9:
      sevenSeg = 0x79;
    default:
      sevenSeg = 0x40;
  return sevenSeg;
void decimalToThree7Segs(int AtoDvalue)  //Takes a 3 digit decimal value(e.g. 143) and writes to the three 7Segs
  int hiValue;    //hi 7Seg
  int midValue;   //mid 7Seg
  int loValue;    //lo 7Seg
  loValue = AtoDvalue % 10;                //Grabs the unit's digit
  AtoDvalue = AtoDvalue - loValue;
  midValue = (AtoDvalue % 100)/10;         //Grabs the ten's digit
  AtoDvalue = AtoDvalue - (10*midValue);
  hiValue = (AtoDvalue % 1000)/100;        //Grabs the hundred's digit
  write7Seg(hiValue);                      //writes out to hi 7Seg
  digitalWrite(hiLEDpin, HIGH);
  digitalWrite(hiLEDpin,LOW);
  write7Seg(midValue);                     //writes out to lo 7Seg
  digitalWrite(midLEDpin,HIGH);
  digitalWrite(midLEDpin,LOW);
  write7Seg(loValue);                      //writes out to lo 7Seg
  digitalWrite(loLEDpin,HIGH);
  digitalWrite(loLEDpin,LOW);
Any help would be greatly appreciated.
-Brad
Leon Heller
Use input from a pot. When you get that working reliably, try the sensor.
Leon Heller
G1HSM
bradj17
Pot input works fine.  Still can't read from an op amp, but my voltmeter works fine.
Suriken
Using LDR I have a similar problem. Sometimes it gives a less value. I fixed it taking 20 values and making the arithmetic mean to get the real value. it works fine for me.
bradj17
After spending hours trying to figure out the problem, I think the oscillations are due to the high gain of the single supply amplifier circuit.  I started with an op amp, then switched to an instrumentation amplifier, and finally gave up and used an AD595 chip.  I can get the single supply amplifier circuit to work with a potentiometer, but I can't seem to get it to work when I connect the thermocouple.  I tried using a decoupling capacitor, which helped, but didn't fix the problem.  I would suggest using an AD595 chip!
-Brad
