Chennai, TN, India
Offline
Newbie
« Reply #60 on: March 17, 2012, 10:18:28 am » |
The if tests are right, but for only one value of i I thought that the inData1 array stores character by character. So in order to compare each letter of "DONE" I used the for loop. Can I do it with a single "i" value?
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #61 on: March 17, 2012, 10:41:36 am » |
I thought that the inData1 array stores character by character. It does. So in order to compare each letter of "DONE" I used the for loop. I don't understand why. Can I do it with a single "i" value? Each time you add a character, you need to check whether it is an E, with N in the previous spot, O in the one before that, and and D in the one before that. So, the value for i would be index, and you don't need a for loop.
Logged
Chennai, TN, India
Offline
Newbie
« Reply #62 on: March 20, 2012, 11:10:08 am » |
I have tweaked the program to display all the MAC id's properly and also used the strtok() function with \r as the delimiter to split the result into tokens. I get this output INQ:D4:C1:FC:3A:56:7C,"C1-01"
00:1C:A4:14:7D:AA,"Sony Ericsson"
00:25:48:7B:55:2F,"Nokia 5130c-2"
DONE
OK From this I need to strip the INQ , DONE , OK and also i guess the \n. How do I do that?
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #63 on: March 20, 2012, 11:29:44 am » |
You could use "\r\n" as the delimiters in the strtok() call. Then, determine the length of the token. Discard it if the length is 1. That will take care of the \n.
You can use strcmp() to see if the token is "DONE" or "OK". If so, discard the token.
You can use strncmp() to see if the first 4 letters of the token are "INQ:", if so, simply increment the token (pointer) by 4 to point to the first character after the INQ: as the start of the string.
Logged
Chennai, TN, India
Offline
Newbie
« Reply #64 on: March 22, 2012, 12:07:27 pm » |
My program is #include <avr/wdt.h> #include <SoftwareSerial.h> #include <SD.h> #define rxPin 2 #define txPin 3 #define SOP1 '\r\n' #define EOP1 '\r\n' #define SOP '+' SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin); char * pch; char inData[200]; char inData1[200]; byte index; int CS_pin=10; int count=0; int i; bool started = false; bool ended = false;
void setup() { // define pin modes for tx, rx, led pins: pinMode(CS_pin, OUTPUT); pinMode(rxPin, INPUT); pinMode(txPin, OUTPUT); mySerial.begin(9600); Serial.begin(9600); if (!SD.begin(CS_pin)) { Serial.println("Card Failure"); return; } Serial.println("Card Ready"); // File header File logFile = SD.open("LOG.csv", FILE_WRITE); if (logFile) { logFile.println(", , , ,"); //Just a leading blank line, incase there was previous data String header = "MAC ID, Name"; logFile.println(header); logFile.close(); Serial.println(header); } else { Serial.println("Couldn't open log file"); } }
void readprocess() { while (mySerial.available() > 0) { char inChar = mySerial.read(); if(inChar == SOP1) { index = 0; inData[index] = '\0'; started = true; ended = false; } else if(inChar == EOP1) { ended = true; break; } else { if(index < 199) { inData[index] = inChar; Serial.print(inData[index]); index++; inData[index] = '\0'; } } } if(started && ended) { started = false; ended = false; index = 0; inData[index] = '\0'; } }
void readatinq() { while(ended==false) { while(mySerial.available() > 0 ) { char inChar = mySerial.read(); if(inChar == SOP) { Serial.println("SOP MARKER READ"); index = 0; inData1[index] = '\0'; started = true; } else { if((index < 199)) { inData1[index] = inChar; i=index; if(inData1[i]=='\n') { if(inData1[i-1]=='\r') { if(inData1[i-2]=='K') { if(inData1[i-3]=='O') { if(inData1[i-4]=='\n') { if(inData1[i-5]=='\r') { if(inData1[i-6]=='\n') { if(inData1[i-7]=='\r') { if(inData1[i-8]=='E') { if(inData1[i-9]=='N') { if(inData1[i-10]=='O') { if(inData1[i-11]=='D') { Serial.println("EOP MARKER READ"); ended=true; } } } } } } } } } } } } } index++; inData1[index] = '\0'; } if(started && ended)
{ // The end of packet marker arrived. Process the packet Serial.println(inData1); Serial.println("TOKENS"); pch = strtok (inData1,"\r\n"); while (pch != NULL) { if((strcmp(pch,"DONE")!=0)&&(strcmp(pch,"OK")!=0)) { Serial.println(pch); store(); pch = strtok (NULL, "\r\n"); } else { pch=NULL; } } started = false; index = 0; count=0; inData[index] = '\0'; } } } ended = false; }
void store() { File dataFile = SD.open("log.csv", FILE_WRITE); if (dataFile) { dataFile.println(pch); dataFile.close(); } else { Serial.println("Couldn't open log file"); } }
void loop() { Serial.println("Initializing"); Serial.println("==="); mySerial.print("==="); delay(100); readprocess(); delay(500); Serial.println("LLL"); mySerial.print("LLL"); delay(100); readprocess(); delay(500); Serial.print("\r\nAT+INQ\r\n"); mySerial.print("\r\nAT+INQ\r\n"); delay(100); readprocess(); readatinq(); delay(1000); }
and I get the correct output on the serial monitor. The problem is, on the SD card, in the .csv file I get the header line twice!. I have attached the file too..How to rectify this?
« Last Edit: March 22, 2012, 12:17:13 pm by elan_arr »
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #65 on: March 22, 2012, 12:42:51 pm » |
I'd suggest that you look at the strncmp() function. That mess in readatinq() is silly looking.
I'd also suggest that you add Serial.print() and/or Serial.println() statements to store() to verify that it is getting called and that it is called with the right arguments.
Logged
Chennai, TN, India
Offline
Newbie
« Reply #66 on: March 25, 2012, 06:02:52 am » |
How should I use the strcmp() function to compare four consecutive characters in a character array?
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #67 on: March 25, 2012, 08:30:16 am » |
How should I use the strcmp() function to compare four consecutive characters in a character array? You have data in inData1. At any given time, you want to know if the last 4 characters in inData1 are "DONE", when there are more than 4 characters. So, after the inData1[index] = NULL; statement, add: if(index] >= 4) { char *donePtr = inData[index-4]; // point to the r4th character from the end if(strcmp(donePtr, "DONE" == 0) { // Found "DONE" } }
Logged
Chennai, TN, India
Offline
Newbie
« Reply #68 on: March 25, 2012, 09:12:17 am » |
char *donePtr = inData1[index-4]; I get a compilation error, "invalid conversion from char to char" on this line. inData1 was declared as char inData1[200];
Logged
New Jersey
Offline
Edison Member
« Reply #69 on: March 25, 2012, 09:20:37 am » |
char *donePtr = &inData[index-4];
Logged
Chennai, TN, India
Offline
Newbie
« Reply #70 on: March 25, 2012, 01:38:26 pm » |
Everything is working perfectly. The only prob is the device goes to a non responsive state every two minutes. Only the reset button brings it back to life. Can this be a problem because of the coding? or the hardware? Is the only solution,to reset? if yes how can I reset it automatically every 2 minutes. I also need to reset without affecting the timer that is running in the program.
Logged
