Chennai, TN, India
« Reply #45 on: March 11, 2012, 03:00:57 am » |
My current code void readatinq() { while(mySerial.available() > 0) { char inChar = mySerial.read(); if(inChar == SOP) { Serial.println("SOP MARKER READ"); index = 0; inData[index] = '\0'; started = true; ended = false; } else if(inChar == EOP && started) { Serial.println("EOP MARKER READ"); count=count+1; Serial.print("count: "); Serial.println(count); if (count>=3) { ended = true; break; } } else { if(index < 199) { inData[index] = inChar; index++; inData[index] = '\0'; } } }
Serial.println('\n');
// We are here either because all pending serial // data has been read OR because an end of // packet marker arrived. Which is it? if(started && ended) { // The end of packet marker arrived. Process the packet Serial.println(inData); // Reset for the next packet started = false; ended = false; index = 0; count=0; inData[index] = '\0'; } and its output Initializing === OK
LLL OK
AT+INQ
OK
SOP MARKER READ EOP MARKER READ count: 1
Initializing === OK
LLL OK
AT+INQ
OK
EOP MARKER READ count: 2 SOP MARKER READ EOP MARKER READ count: 3
INQ:00:1C:A4:14:7D:AA,"Sony Ericsson" Initializing === D4:C1:FC:3A:56:7C,"C1 OK
LLL OK
AT+INQ
OK
and so on... Multiple id's are separated by a \r\n . I need to print the MAC ID once the EOP is detected and again check the receive buffer and print the next ID..that logic is missing in my code!
Seattle, WA USA
Seattle, WA USA
« Reply #46 on: March 11, 2012, 06:33:16 am » |
My current code Is missing a whole lot of stuff, like setup() and loop().
Chennai, TN, India
« Reply #47 on: March 11, 2012, 07:08:38 am » |
Is missing a whole lot of stuff, like setup() and loop(). I just posted the part of my code that had changes. Anyways, I removed the "count" part from the program and my current code is this one #define rxPin 2 #define txPin 3 #define SOP '+' #define EOP '\r' #include <SoftwareSerial.h> #include <avr/wdt.h> #include <SD.h> int CS_pin=10; int pow_pin=8; int count=0; SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin);
int i;
bool started = false; bool ended = false;
char inData[200]; char inData1[200]; byte index;
void setup() { // define pin modes for tx, rx, led pins: pinMode(rxPin, INPUT); pinMode(txPin, OUTPUT); pinMode(CS_pin, OUTPUT); pinMode(pow_pin, OUTPUT); mySerial.begin(9600); Serial.begin(9600); if (!SD.begin(CS_pin)) { Serial.println("Card Failure"); return; } Serial.println("Card Ready");
// Other stuff... } void readprocess() { while(mySerial.available() > 0) { char inChar = mySerial.read(); if(inChar == SOP) { index = 0; inData[index] = '\0'; started = true; ended = false; } else if(inChar == EOP) { ended = true; break; } else { if(index < 199) { inData[index] = inChar; Serial.print(inData[index]); index++; inData[index] = '\0'; } } }
// Reset for the next packet started = false; ended = false; index = 0; inData[index] = '\0'; } } void readatinq() { while(mySerial.available() > 0) { char inChar = mySerial.read(); if(inChar == SOP) { Serial.println("SOP MARKER READ"); index = 0; inData1[index] = '\0'; started = true; ended = false; } else if(inChar == EOP && started) { Serial.println("EOP MARKER READ"); ended = true; break; } else { if(index < 199) { inData1[index] = inChar; index++; inData1[index] = '\0'; } } }
store(); // Reset for the next packet started = false; ended = false; index = 0; count=0; inData[index] = '\0'; } }
void store() { File dataFile = SD.open("log.txt", FILE_WRITE); if (dataFile) { dataFile.println(inData1); dataFile.close(); Serial.println(inData1); } else { Serial.println("Couldn't open log file"); } } void loop() { Serial.println("Initializing"); Serial.print("==="); mySerial.print("==="); delay(100); readprocess(); delay(2000); Serial.print("LLL"); mySerial.print("LLL"); delay(100); readprocess(); delay(2000); Serial.print("\r\nAT+INQ\r\n"); mySerial.print("\r\nAT+INQ\r\n"); delay(100); readprocess(); delay(25000); readatinq(); delay(2000); }
And my output is Card Ready Initializing === OK
LLL OK
AT+INQ
OK
INQ:D4:C1:FC:3A:56:7C,"C1-01" Initializing === 00:1C:A4:14:7D:AA,"Sony Ericsson"
OK
LLL00:25:48:7B:55:2F,"Nokia 5130c-2" DONE
OK
All the devices are getting detected and being printed. But they should be printed in one go. Further, only INQ:D4:C1:FC:3A:56:7C,"C1-01" gets stored on the SD card. The remaining two ID's aren't stored.
Seattle, WA USA
Seattle, WA USA
« Reply #48 on: March 11, 2012, 07:21:14 am » |
Serial.println('\n'); Useful. Not! All the devices are getting detected and being printed. But they should be printed in one go. Further, only The problem is that the data is not all arriving at once. So, on one pass through loop, you get some data in response to the INQ command, and on the next pass through loop, you get some more data, and on the next pass, you get some more. There is clearly a start of packet marker (+INQ:), and field delimiters (\r\n), but I don't see any kind of end of packet marker, unless that DONE part is the end of the data. What I would try is putting the code to send data to the device in setup, along with the calls to readprocess(). Leave just the call to readatinq() in loop. In readatinq(), PRINT EVERY CHARACTER READ!!! Remove the useless Serial.println('\n') calls. Load the sketch to the Arduino, and show the output. If it turns out that +INQ: and DONE bound the data stream, then you can modify readatinq() to store data until the array ends with DONE.
Chennai, TN, India
« Reply #49 on: March 11, 2012, 09:18:17 am » |
If it turns out that +INQ: and DONE bound the data stream, then you can modify readatinq() to store data until the array ends with DONE. Yes the ID's that are detected begin with +INQ and once all devices are detected and displayed, a DONE followed by an OK are displayed.
Seattle, WA USA
Seattle, WA USA
« Reply #50 on: March 11, 2012, 09:25:08 am » |
So, you need to set started to true when the + arrives. After each character is added (including the \r and \n) to the array, test if the last 4 characters are 'D', 'O', 'N', and 'E'. If so, set ended to true.
Then, in the started and ended section, use strtok() with \n as the delimiter, to extract each token and print/store the token, after making sure that the \n and \r are stripped from the token.
You can then move all the code back to loop, but sending the INQ command should not happen unless there is a trigger event - a switch press or something.
Chennai, TN, India
« Reply #51 on: March 15, 2012, 08:40:59 am » |
So, you need to set started to true when the + arrives. After each character is added (including the \r and \n) to the array, test if the last 4 characters are 'D', 'O', 'N', and 'E'. If so, set ended to true. Before implementing this concept, I have a query. I just set the EOP marker as 'D' so so that the stuff that is read from the module can be displayed once the 'D' from the 'DONE' is detected. So logically the output should be similar to INQ: MAC ID 1,"name 1", \r\n MAC ID 2,"name 2" D I just included a statement to visualize every character that is stored in the array. So the readatinq function and the loop function of my program are, void readatinq() { while(mySerial.available() >0) { char inChar = mySerial.read(); if(inChar == SOP) { Serial.println("SOP MARKER READ"); index = 0; inData1[index] = '\0'; started = true; ended = false; } else if(inChar == EOP && started) { Serial.println("EOP MARKER READ"); ended = true; break; } else { if(index < 199) { inData1[index] = inChar; Serial.print("index["); Serial.print(index); Serial.print("]: "); Serial.println(inData1[index]); index++; inData1[index] = '\0'; } } }
{ i++; Serial.print("Loop executed : "); Serial.println(i); // The end of packet marker arrived. Process the packet Serial.println(inData1); // Reset for the next packet started = false; ended = false; index = 0; count=0; inData[index] = '\0'; } }
void loop() { Serial.println("Initializing"); Serial.println("==="); mySerial.print("==="); delay(100); readprocess(); delay(500); Serial.println("LLL"); mySerial.print("LLL"); delay(100); readprocess(); delay(500); Serial.print("\r\nAT+INQ\r\n"); mySerial.print("\r\nAT+INQ\r\n"); delay(100); readprocess(); delay(25000); readatinq(); delay(1000); } The output that I get is Initializing ===
OK LLL
OK
AT+INQ
OK index[85]:
index[86]:
SOP MARKER READ index[0]: I index[1]: N index[2]: Q index[3]: : index[4]: 0 index[5]: 0 index[6]: : index[7]: 1 index[8]: C index[9]: : index[10]: A index[11]: 4 index[12]: : index[13]: 1 index[14]: 4 index[15]: : index[16]: 7 index[17]: D index[18]: : index[19]: A index[20]: A index[21]: , index[22]: " index[23]: S index[24]: o index[25]: n index[26]: y index[27]: index[28]: E index[29]: r index[30]: i index[31]: c index[32]: s index[33]: s index[34]: o index[35]: n index[36]: " index[37]:
index[38]:
index[39]: D index[40]: 4 index[41]: : index[42]: C index[43]: 1 index[44]: : index[45]: F index[46]: C index[47]: : index[48]: 3 index[49]: A index[50]: : index[51]: 5 index[52]: 6 index[53]: : index[54]: 7 index[55]: C index[56]: , index[57]: " index[58]: C index[59]: 1
The loop has been terminated even without the EOP marker being detected and as the EOP wasn't detected, the elements of the array weren't printed. and there are still a few characters left. the loop has stopped at index[59] abruptly. I guess that for a split second there is no element available at the receive buffer and as the code contains while(mySerial.available() >0) the loop has been terminated. could that be the reason? If yes, how to resolve it?
Seattle, WA USA
Seattle, WA USA
« Reply #52 on: March 15, 2012, 09:10:31 am » |
index[17]: D index[39]: D Clearly, you did NOT set EOP to 'D' correctly.
Chennai, TN, India
« Reply #53 on: March 15, 2012, 09:14:39 am » |
Clearly, you did NOT set EOP to 'D' correctly. Sorry, made a mistake while posting. The EOP was Capital letter 'O' .
Chennai, TN, India
« Reply #54 on: March 15, 2012, 09:20:26 am » |
Sorry, made a mistake while posting. The EOP was Capital letter 'O' . ===
OK LLL
OK
AT+INQ
OK These 'OK' s are a result of a separate read function(readprocess) for which the SOP and EOP are different. I do not have any problem until this. The problem starts only in the "readatinq" function.
Seattle, WA USA
Seattle, WA USA
« Reply #55 on: March 15, 2012, 09:47:31 am » |
I guess that for a split second there is no element available at the receive buffer and as the code contains while(mySerial.available() >0) the loop has been terminated. Yes, this happens sooner or later (later, in your case because of all the serial output you are sending). could that be the reason? Yes. Normally, the read function would be called over and over again, on each pass through loop, so eventually all the data gets read. Then, it can be processed.
Chennai, TN, India
« Reply #56 on: March 15, 2012, 10:14:01 am » |
Normally, the read function would be called over and over again, on each pass through loop, so eventually all the data gets read. Then, it can be processed. So what alterations should I do to the program to make it process only after ensuring that all the data from the receive buffer has been read? Anything like making the function to wait for a moment when the receive buffer is empty so as to read the data that might arrive a bit late?
Seattle, WA USA
Seattle, WA USA
« Reply #57 on: March 15, 2012, 10:49:49 am » |
So what alterations should I do to the program to make it process only after ensuring that all the data from the receive buffer has been read? while(strcmp(lastFourCharacters, "DONE") != 0) { // Keep reading... }
Chennai, TN, India
« Reply #58 on: March 17, 2012, 08:46:27 am » |
test if the last 4 characters are 'D', 'O', 'N', and 'E'. If so, set ended to true. After the "DONE" there is still a \r\n and an OK followed by another \r\n is present. So should I still look out for "DONE" ? If yes, I'm using f(index < 199) { inData1[index] = inChar; for(int i=index ;i>=(index-3);i--) { if(inData1[i]=='E') { if(inData1[i-1]=='N') { if(inData1[i-2]=='O') { if(inData1[i-3]=='D') { Serial.println("DETECTED"); break; } } } } to detect DONE. Is this feasible?
Seattle, WA USA
Seattle, WA USA
« Reply #59 on: March 17, 2012, 08:49:12 am » |
Is this feasible? Why are the if tests in a for loop? The if tests are right, but for only one value of i.
