Topic: [SOLVED] IDE crashes without notice (Read 7860 times) previous topic - next topic
setaseta
Feb 27, 2012, 09:25 pm Last Edit: Mar 08, 2012, 12:12 am by setaseta Reason: 1
Solution: Just deactivate ClearType in Windows7 control panel...    ]:D
Hi all,
I ask for your help on IDE crashing.
These are my hints. Any help will be appreciated.
1.- No problems at all with my Duelmilanove. It's working great. It's an issue related to IDE itself.
2.- Suddenly, after months of working, IDE won't load anymore. It shuts down after splash screen without notice nor error.
3.- I'm using Windows 7 ultimate, IDE 1.0, no other com but arduino usb com. It doesn't run, nomatter the arduino is plugged in or not.
4.- Tried with java 7, 6, no java at all. None of these worked. Removal included arduino references on regedit. No luck.
5.- Removed preferences.txt from Users/myuser/...
6.- Renamed java folder on Arduino folder.
7.- Downloaded and tried with IDE from 022 to 1.0.
8.- Removed every C++ runtime from my system (this is the only thing installed after the IDE was working)
9.- Executed arduino from cmd with trace on. Exit code=1. No more data.
Any clues?
How can I find out the error that causes the shutdown?
I really appreciate your help. My new ethernet shield just arrived I can't play with it!!!
I'm thinking about reinstalling windows 7. It seems a drastic solution for a java simple IDE. Doesn't it?
Thanks in advance!
Sergio.
zoomkat
I'd remove any trace of the old IDE, do a new IDE install in a new folder and maybe going back to a previous instance of windows that was working before the issues started.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Louis Davis
The IDE creates a lot of temp files and folders in the folder <user name>\AppData\Local\Temp
Maybe something has been corrupted in this location and preventing the IDE from launching.
It would be safe to delete all files and folders in this location to see if this may help with your problem.
KevinBL
Hello my friends !!
I'm very new at almost everything about Arduino but I had the same problem which now seems to have solved. I did what Louis said in addition to what I inadvertently did afterwards!! I just copied the folder containing the arduino 1.0 stuff (which was originally on my desktop for some reason) and pasted it in my programfiles  folder(and not even in the programfiles x86 !! ) and then I ran it from that location and it miraculously came up !!! I'm not even sure whether it's gonna work on your device or weather it can be a long term solution but I hope It can help you figure out the root of the problem. Good luck  XD
zoomkat
The below is a previously posted batch file to clear out the orphaned arduino temporary files. I think that having a lot of the orphaned files can under some circumstances cause the IDE to try to use a lot of memory. Below is the location on my pc of the arduino temp files. Put the batch file in the Temp folder and make a short cut to the batch file for routine cleaning.
C:\Documents and Settings\zoomkat\Local Settings\Temp\deletetemp.bat
deletetemp.bat
Code: [Select]
del jna*.tmp
::del console*.tmp
::del untitled*.tmp
del fla*.tmp
for /d %%a in (console*.tmp) do rmdir /s /q %%a
for /d %%a in (untitled*.tmp) do rmdir /s /q %%a
for /d %%a in (build*.tmp) do rmdir /s /q %%a
setaseta
Thank You very much for your hints zoomkat, Kevin and Louis.
None of these helped.  :(
I'm pretty sure that is has something to do with java installation as JDowloader also behaves the same and this is a very well know java application.
I did remove java using revo unistaller, and installed again with no luck.
After installation, Sun web page says that the installation is fine... but I may be missing somethig.
How can I install a clean copy of java?
Do I have to install both JRE and SDK?
I read out a lot of posts in this forum and found no hints...
Thanks again for you patience...
Sergio.
Louis Davis
In my particular case, I am only using the version of Java that is included with the Arduino IDE package. I do not have another Java installation.
setaseta
Thanks Louis, that shortened my "to do" list a lot.
I will remove java at all and follow that way.
Anyone knows how to activate trace on IDE start up?
oric_dan
Quote
I discovered this business a week or so ago. Turns out, on my old WinXP machine that has Arduino IDE
crash problems, there were 14-GBytes of Temp files, going back for 5-6 years, and that used up fully
35% of my 40GB HD space. [35% !!!! - thank you BillGates for never doing garbage collection].
Everytime I did a compilation using one of a dozen or so development tools, a new folder was created
in Temp, and never removed.
The Arduino IDE does appear to "try to" clean out the current Temp folder when the IDE closes, although
it does not seem to remove any prior folders, so they multiply without limit over time.
Also, what I did find is that, for some reason on the machine where Arduino IDE crashes, the IDE does not
delete file "core.a" when it closes. The file attributes are set to read-only or whatever, and the file cannot even be deleted MANUALLY. When attempting to do so, you get an error msg that says something like
"file in use by another program".
Also, when I try to shut down the machine, it hangs up for minutes, then finally an error popup
occurs that says the Arduino IDE is shutting down, even though I had closed it long before.
IOW, there seems to be a couple of problems with the IDE shutting down, at least on my machine.
None of my other dozen or so dev tools has this probem, so I don't agree that the problem is "a lot
of orphaned files", rather the IDE doesn't remove them all properly.
setaseta
Thanks Oric.
No luck again. I deleted lots of temp files but nothing happended.
After more than 20 hours since saturday I'm giving up. I'm thinking about reinstalling windows.
Thanks for your support.
Sergio.
zoomkat
Quote
thank you BillGates for never doing garbage collection.
It is not a windows problem, it is an IDE issue. I have to use task manager to kill the IDE when the IDE becomes non responsive (usually after my laptop has gone into sleep mode at some point). The IDE never cleans out the huge amount of temp files it makes.
oric_dan
Quote
Quote
It seems to be a problem that ALL windows apps have, not just the Arduino IDE. 100s of programs
seem to leave files in the Temp folder, and they never get cleaned out even after 5-6 years.
To me, Windows should have realized that those 14GB of 5-YO folders and files on my HD
were wasted space and deleted them itself. Alfter all, everybody puts them in the same Temp
directory. If it only had brain like Dorothy, that is. LOL.
OTOH, FWICT, Arduino IDE creates 3 new folders whenever it starts up, and does delete "most"
files in those folders on closing - when it closes properly. I just checked on my netbook, and I
have many dozens of build, console, and untitled folders in Temp, but most are empty or sparsely
populated with files. Mainly stdout.txt and stderr.txt, plus sketch folders.
The build directories are all empty. The untitled directories all have the "empty" sketch in them
that the IDE shows when you start it up. There are ~100 such empty sketch folders in Temp,
never deleted.
OTOH, on my other XP machine where the Arduino IDE crashes, "core.a" never gets deleted
from the build folder, and the IDE never shuts down properly when I close it.
oric_dan
Quote
Thanks Oric.
You have the crash problem on your new Win7 machine, I have it on my 6-YO WinXP notebook
but not on my 2-YO WinXP netbook.
I somehow doubt that reinstalling windows is going to help.
Offhand, are you finding that the IDE leaves the file "core.a" undeleted, as happens on my
machine? It will be located in the buildxxx.tmp fiolder that the IDE creates. On my good machine
this folder is cleaned out when I exit the IDE.
Louis Davis
I figured out a way to launch the IDE from command line and capture some debug information from the Java runtime.
Execute this command line from the folder where the arduino.exe file is installed:
"C:\arduino\arduino-1.0\java\bin\java.exe" -verbose -Xms128m -Xmx128m -classpath "lib;C:\arduino\arduino-1.0\java\lib\tools.jar;lib\pde.jar;lib\core.jar;lib\jna.jar;lib\ecj.jar;lib\RXTXcomm.jar" processing.app.Base
You will see a bunch of information in the console window. Hopefully this will help narrow down the cause of the problem.
setaseta
#14
Feb 29, 2012, 03:08 pm Last Edit: Feb 29, 2012, 03:11 pm by setaseta Reason: 1
Wow!
Louis, you made the difference.
Launching IDE from :
F:\arduino-1.0>.\java\bin\java.exe -verbose -Xms128m -Xmx128m -classpath "lib;C:\arduino\arduino-1.0\java\lib\tools.jar;lib\pde.jar;lib\core.jar;lib\jna.jar;lib\ecj.jar;lib\RXTXcomm.jar" processing.app.Base
worked!  :)
If I try to launch it using the exe file it stills not working.
At least I went back to work.
Thanks dude!
