Topic: USB Absolute Mouse Mode (Read 30614 times) previous topic - next topic
Jardal
Absolute mouse mode for Digispark AtTiny85, range -127/+127
Path to file (on Linux):
.arduino15/packages/digistump/hardware/avr/1.6.7/libraries/DigisparkMouse/DigiMouse.h
(comments are gone due size limitations here)
Code: [Select]
#ifndef __DigiMouse_h__
#define __DigiMouse_h__
#define REPORT_SIZE 4
#include <Arduino.h>
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include <avr/delay.h>
#include <string.h>
#include <avr/io.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
#include "usbdrv.h"
//#include "devdesc.h"
#include "oddebug.h"
#include "usbconfig.h"
static const uchar *rt_usbHidReportDescriptor = NULL;
static uchar rt_usbHidReportDescriptorSize = 0;
static const uchar *rt_usbDeviceDescriptor = NULL;
static uchar rt_usbDeviceDescriptorSize = 0;
#define MOUSEBTN_LEFT_MASK 0x01
#define MOUSEBTN_RIGHT_MASK 0x02
#define MOUSEBTN_MIDDLE_MASK 0x04
typedef uint8_t byte;
static unsigned char last_built_report[REPORT_SIZE];
static unsigned char last_sent_report[REPORT_SIZE];
uchar reportBuffer[REPORT_SIZE];
#define DIGIMOUSE_DEFAULT_REPORT_INTERVAL 20
static unsigned char must_report = 0;
static unsigned char idle_rate = DIGIMOUSE_DEFAULT_REPORT_INTERVAL / 4; // in units of 4ms
static unsigned long last_report_time = 0;
//#define ABSOLUTE_MOUSE_MODE
char usb_hasCommed = 0;
const PROGMEM unsigned char mouse_usbHidReportDescriptor[] = { /* USB report descriptor */
0x05, 0x01,
0x09, 0x02,
0xa1, 0x01,
0x09, 0x01,
0xa1, 0x00,
0x05, 0x09,
0x19, 0x01,
0x29, 0x03,
0x15, 0x00,
0x25, 0x01,
0x95, 0x03,
0x75, 0x01,
0x81, 0x02,
0x95, 0x01,
0x75, 0x05,
0x81, 0x01,
0x05, 0x01,
0x09, 0x30,
0x09, 0x31,
#ifdef ABSOLUTE_MOUSE_MODE
0x15, 0x81,
0x25, 0x7f,
0x75, 0x08,
0x95, 0x03,
0x81, 0x02,
#else
0x15, 0x81,
0x25, 0x7f,
0x75, 0x08,
0x95, 0x02,
0x81, 0x06,
#endif
0x09, 0x38,
0x95, 0x01,
0x81, 0x06,
0xc0,
0xc0
#define USBDESCR_DEVICE 1
const unsigned char usbDescrDevice[] PROGMEM = { /* USB device descriptor */
18, /* sizeof(usbDescrDevice): length of descriptor in bytes */
USBDESCR_DEVICE, /* descriptor type */
0x01, 0x01, /* USB version supported */
USB_CFG_DEVICE_CLASS,
USB_CFG_DEVICE_SUBCLASS,
0, /* protocol */
8, /* max packet size */
USB_CFG_VENDOR_ID, /* 2 bytes */
USB_CFG_DEVICE_ID, /* 2 bytes */
USB_CFG_DEVICE_VERSION, /* 2 bytes */
#if USB_CFG_VENDOR_NAME_LEN
1,
#els
0,
#endif
#if USB_CFG_DEVICE_NAME_LEN
2,
#els
0,
#endif
#if USB_CFG_SERIAL_NUMBER_LENGTH
3,
#els
0,
#end
1,
void buildReport(unsigned char *reportBuf) {
if (reportBuf != NULL) {
memcpy(reportBuf, last_built_report, REPORT_SIZE);
memcpy(last_sent_report, last_built_report, REPORT_SIZE);
void clearMove() {
// because we send deltas in movement, so when we send them, we clear them
last_built_report[1] = 0;
last_built_report[2] = 0;
last_built_report[3] = 0;
last_sent_report[1] = 0;
last_sent_report[2] = 0;
last_sent_report[3] = 0;
class DigiMouseDevice {
public:
DigiMouseDevice () {
rt_usbHidReportDescriptor = mouse_usbHidReportDescriptor;
rt_usbHidReportDescriptorSize = sizeof(mouse_usbHidReportDescriptor);
rt_usbDeviceDescriptor = usbDescrDevice;
rt_usbDeviceDescriptorSize = sizeof(usbDescrDevice);
void begin() {
cli();
usbDeviceDisconnect();
_delay_ms(200);
usbDeviceConnect();
usbInit();
sei();
last_report_time = millis();
void refresh() {
update();
void poll() {
update();
void update() {
usbPoll();
unsigned long time_since_last_report = millis() - last_report_time;
if (time_since_last_report >= (idle_rate * 4 /* in units of 4ms - usb spec stuff */)) {
last_report_time += idle_rate * 4;
must_report = 1;
if (memcmp(last_built_report, last_sent_report, REPORT_SIZE)) {
must_report = 1;
if (must_report) {
if (usbInterruptIsReady()) {
must_report = 0;
buildReport(reportBuffer); // put data into reportBuffer
clearMove(); // clear deltas
usbSetInterrupt(reportBuffer, REPORT_SIZE);
void delay(long milli) {
unsigned long last = millis();
while (milli > 0) {
unsigned long now = millis();
milli -= now - last;
last = now;
update();
void moveX(char deltaX) {
if (deltaX == -128) deltaX = -127;
last_built_report[1] = *(reinterpret_cast<unsigned char *>(&deltaX));
void moveY(char deltaY) {
if (deltaY == -128) deltaY = -127;
last_built_report[2] = *(reinterpret_cast<unsigned char *>(&deltaY));
void scroll(char deltaS) {
if (deltaS == -128) deltaS = -127;
last_built_report[3] = *(reinterpret_cast<unsigned char *>(&deltaS));
void move(char deltaX, char deltaY, char deltaS) {
void move(char deltaX, char deltaY, char deltaS, char buttons) {
last_built_report[0] = buttons;
void rightClick(){
last_built_report[0] = MOUSEBTN_RIGHT_MASK;
void leftClick(){
void middleClick(){
void setButtons(unsigned char buttons) {
void setValues(unsigned char values[]) {
memcpy(last_built_report, values, REPORT_SIZE);
//private: TODO: Make friend?
// what does this even mean? -- Bluebie
// create the global singleton DigiMouse
DigiMouseDevice DigiMouse = DigiMouseDevice();
#ifdef __cplusplus
extern "C"{
#endif
// USB_PUBLIC uchar usbFunctionSetup
uchar usbFunctionSetup(uchar data[8]) {
usbRequest_t *rq = (usbRequest_t *)data;
usbMsgPtr = reportBuffer;
if ((rq->bmRequestType & USBRQ_TYPE_MASK) == USBRQ_TYPE_CLASS) { /* class request type */
return REPORT_SIZE;
} else if (rq->bRequest == USBRQ_HID_GET_IDLE) {
usbMsgPtr = &idle_rate;
return 1;
} else if (rq->bRequest == USBRQ_HID_SET_IDLE) {
idle_rate = rq->wValue.bytes[1];
return 0;
uchar usbFunctionDescriptor(struct usbRequest *rq) {
if ((rq->bmRequestType & USBRQ_TYPE_MASK) != USBRQ_TYPE_STANDARD) {
return 0;
if (rq->bRequest == USBRQ_GET_DESCRIPTOR) {
switch (rq->wValue.bytes[1]) {
case USBDESCR_DEVICE:
usbMsgPtr = rt_usbDeviceDescriptor;
return rt_usbDeviceDescriptorSize;
case USBDESCR_HID_REPORT:
usbMsgPtr = rt_usbHidReportDescriptor;
return rt_usbHidReportDescriptorSize;
return 0;
#ifdef __cplusplus
} // extern "C"
#endif
#endif // __DigiMouse_h__
saibersingh
Hey there,
When i try to upload my code it shows an error...
Arduino: 1.8.1 (Mac OS X), Board: "Arduino Leonardo"
/private/var/folders/hn/flfx2mnd237974bkycxx4cyr0000gn/T/AppTranslocation/F9EEF18B-0923-4A05-BE90-F6FC217A14A7/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/HID/src/HID.cpp:19:22: fatal error: platform.h: No such file or directory
 #include <platform.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Leonardo.
option enabled in File -> Preferences.
Please Help me out ASAP I have a project to submit.
Thank you
JBlevins1996
This is great, however you don't list how to find HID.cpp
I've searched everywhere in all of my Arduino directories and HID.cpp is not listed anywhere at all.
Any help would be greatly appreciated.
gdsports
If using Linux and maybe Mac, use the find command line util.
# Change to top of home directory
$ cd
$ find . -name HID.cpp
./.arduino15/packages/arduino/hardware/samd/1.6.16/libraries/HID/HID.cpp
./arduino-1.8.4/hardware/arduino/avr/libraries/HID/src/HID.cpp
The first is the one for SAMD ARM (Zero) boards. The second is for AVR (Leonardo) boards.
Varunsangwan
