Israel
Offline
Jr. Member
« on: February 28, 2012, 02:45:17 am » |
Hello, I am using LM335 Temperature sensor. Here is my code: float celsius = 0, kelvin=0;
void setup() { Serial.begin(9600); }
void loop() { kelvin = analogRead(0) * 0.004882812 * 100; celsius = kelvin - 273.15; Serial.print("Celsius: "); Serial.println(celsius); Serial.print("Kelvin: "); Serial.println(kelvin); Serial.println(); delay(1000); } Output: Celsius: 41.30 Kelvin: 314.45
41.30 degrees C is unusual. I am testing inside my room where the temperature is 19 degrees C. Please help me correct readings. Thanks. Z
« Last Edit: February 28, 2012, 02:59:26 am by zeus2kx »
Logged
Offline
Edison Member
Now, More Than Ever
« Reply #1 on: February 28, 2012, 08:13:13 am » |
Insert a Serial.print statement to knock out the analogRead(0) result.
Logged
Don't Be Upset By The Results You Didn't Get With The Work You Didn't Do
Israel
Offline
Jr. Member
« Reply #2 on: February 28, 2012, 10:46:00 am » |
Thanks for reply. I added, here is the output. Celsius: 41.30 Kelvin: 314.45 Analog Read: 644
Celsius: 41.79 Kelvin: 314.94 Analog Read: 644
Celsius: 41.79 Kelvin: 314.94 Analog Read: 645
What can I do to solve this issue? Thanks. Z
Logged
New Jersey
Offline
Edison Member
« Reply #3 on: February 28, 2012, 10:57:21 am » |
How do you have it wired up?
Logged
Offline
Edison Member
Now, More Than Ever
« Reply #4 on: February 28, 2012, 11:02:32 am » |
Well, your analogRead result means there's about 3.1V (645 * 4.888mV = 3152mV == 310K - 273 = 42C). Are the wires to the sensor short? They should be as short as possible. Try a bypass cap at the sensor, 0.1uF from +V to Gnd, too.
5V / 1023 = 4.888mV (per count)
Logged
Israel
Offline
Jr. Member
« Reply #5 on: February 28, 2012, 11:08:55 am » |
Logged
Israel
Offline
Jr. Member
« Reply #6 on: February 28, 2012, 11:15:18 am » |
Thanks. No, wire length is almost like a foot.
Logged
Israel
Offline
Jr. Member
« Reply #7 on: February 28, 2012, 11:25:17 am » |
Kindly confirm the circuit so that I fix sensor on board itself.
Thanks.
Logged
Israel
Offline
Jr. Member
« Reply #8 on: February 28, 2012, 12:01:31 pm » |
I tried connecting 0.1uF between +V and Gnd but no significant changes.
Logged
Offline
Edison Member
Now, More Than Ever
« Reply #9 on: February 28, 2012, 01:02:53 pm » |
You may be coupling noise into the analogRead with those 1 foot wires. Better try as short as possible. Your application likely requires remote placement, but try and find out if this helps first. Your circuit looks like what I've seen recommended.
Logged
Israel
Offline
Jr. Member
« Reply #10 on: February 28, 2012, 01:09:51 pm » |
I soldered on the board but yet no change in readings.
Logged
Offline
Edison Member
Now, More Than Ever
« Reply #11 on: February 28, 2012, 01:17:23 pm » |
Have you put a voltmeter to the LM335 output (right there on the board)? If it's "3V" then maybe it's defective.
Logged
Israel
Offline
Jr. Member
« Reply #12 on: February 28, 2012, 01:55:47 pm » |
Nope, I am home, don't have one now but can check tomorrow.
Logged
Israel
Offline
Jr. Member
« Reply #13 on: February 29, 2012, 10:49:51 am » |
I found the problem that there wasn't any problem just that Arduino was only connected through USB, not with AC adopter.
Thanks all for your support.
Z
Logged
Offline
Edison Member
Now, More Than Ever
« Reply #14 on: February 29, 2012, 01:23:38 pm » |
But,... I... Well, OK then.
Logged
