Topic: Controlling a DC motor from an arduino (Read 443 times) previous topic - next topic
dylan45pie
Ok, so after buying an uno and thinking what i should do with it for a few days, i decided to make a remote controlled car work with a TV remote. I was wondering why plugging the motor straight to the 5v pin made it work great but when i put it in a digital pin (say 3) and set it to high, it goes very slow.
I thought the digital pins on the arduino outputted 5v but why does the motor work significantly better when used on the other pin? i don't get it.
scottyjr
#1
Mar 14, 2012, 11:45 am Last Edit: Mar 14, 2012, 11:46 am by scottyjr Reason: 1
Ouch! Stop doing that! Pins of the Arduino cannot supply enough power to drive your motor. You may have already damaged any pins that you attempted to use. Go to the Hardware page of this site and read about your Arduino. The motor must be have its power supplied by another device such as a suitable transistor; with proper circuitry, the transistor is controlled by an Arduino pin. - Scotty
AWOL
Quote
It's not about voltage, it's about current, and your output pins can't provide very much of it.
Even a tiny vibra motor from a mobile could draw more than twice the safe amount of current you could draw from an AVR's pin.
The 5V pin supplies current direct from the regulator which has a much higher current rating than the digital pins.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
