Loading...
Pages: [1] 2 3 ... 5   Go Down
Author Topic: trying to get this to work  (Read 2053 times)
Offline Offline
Newbie
View Profile
I have been trying to get this to work with the pwm of my arduino.
http://uk.farnell.com/jsp/search/productdetail.jsp?CMP=cmwis_email&sku=1936419
It is a triak with proportional control and is controlled with 2-10v dc. I have made a circuit as below but it does not seem to work. The voltage on the input pins is ok as I get 10v when the pwm pin is at 255 and 5v at 120 etc. do I need to look at another method on the electronics side.
be gentle with me as this is my first project.
Any help would be appreciated.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
Your PWM output is either 5V or 0V.
If you want anything in between, you need to smooth it.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
why do I get the correct voltage when I test the  pos neg terminals of the triak. ie analoguewrite 255 I get 10v across the terminal analoguewrite  120 I get 5v . I have tested the triak with a battery and it is working perfect, so the problem has to be my circuit. how can i get the arduino to control 2-10v?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
How are you testing this?
Logged
Offline Offline
Newbie
View Profile
with a multimeter
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Analogue, or digital?
Logged
Offline Offline
Newbie
View Profile
digital
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
I really wasn't expecting that.
The fact remains, that with the circuit you showed, the voltage at the collector of the transistor will be either 0V or 10V.
How your Crydom device responds to this, I have no idea.
Logged
Offline Offline
Newbie
View Profile
do you have any other method to allow me to control 0-10v.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Yes, you could low-pass filter the PWM.
Sorry, I'm not an analogue person.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Take your arduino pin, run it thru a 1K resistor to the base of the transistor, and add a 1 uF cap to ground from the base of the resistor.
This will make a low pass filter, so the transistor will see a DC level and not a hard 0V or 5V level.
See "passive electronic realization" here
http://en.wikipedia.org/wiki/Low-pass_filter
Adust R & C so that the 490 Hz switching of the PWM output is filtered out.
F = 1/(2piRC)
F*2*pi*R = 1/C
C = 1/(F*2*pi*R), so for 300 Hz, 1K resistor, I think that works out to a 53uF cap.
Try different Rs & Cs, see how it works out.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
Is this correct
Logged
South Texas
Offline Offline
God Member
View Profile
How do you have this connected, and to what do you have it connected?
The data sheet says for resistive loads. With No Load it may not show that it is doing anything. And 50Amps is rather exciting...
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I'd say yes.
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
http://arduino.cc/forum/index.php/topic,93735.0.html
I was leaning toward a DAC
An AD558 is still available, but expensive.
A DAC0808 is still available, less expensive, but req's a dual-ended supply and an op-amp.
The low-pass on the input to the base, above, will only result, still, in switching the transistor - it won't effect a variable voltage the way jimjam wants.
Anyway, if you low-pass the pwm and then run that into a buffer, its output would be a variable voltage, likely with some ripple.  An op-amp might not be able to supply the current needed at 10V (20mA?).  So, something like a common-collector amp for the op-amp's out would take care of that.
Logged
Don't Be Upset By The Results You Didn't Get With The Work You Didn't Do
Pages: [1] 2 3 ... 5   Go Up
Print
Jump to:
