Topic: What does this do? (Hall-Effect Current Sensor) (Read 2440 times) previous topic - next topic
CTE_T
No Idea what this does, but I would like to know :)
Also, if you could explain how to connect and use it that would be great!
http://www.sparkfun.com/products/8882
DVDdoug
It senses the presence of a magnetic field.  Sometimes, they are used with a magnet on the shaft of a  motor to detect RPM without making an electrical connection to the moving parts.
hall Effect
MarkT
The Hall effect is always present in conductors, but is only significant enough to make a useful measuring device when current is passing through a semiconductor.  Basically any current in a magnetic field gets "pushed sideways", and the Hall effect is the voltage gradient that develops to balance-out this push in the steady-state.
Hall effect current sensors just place a Hall-effect chip close to a copper strip that carries the current to be measured.  So you have a device that can measure current in a circuit it is insulated from.
Note that these devices will mis-read the current if there is a permanent magnet nearby since they measure the total magnetic field.
jfenwick
Here's some decent looking links:
http://www.electronics-lab.com/blog/?tag=acs712
http://embedded-lab.com/blog/?p=4469
http://embedded-lab.com/blog/?p=4529
The second link gives a good breakdown of how it works.
