Loading...
Pages: [1]   Go Down
Author Topic: H Bridge Help  (Read 387 times)
Alabama
Offline Offline
Newbie
View Profile
I'm new to Arduino, and would like to use an Uno to power a Tamiya Dual Gearbox. I don't need to control the speed, I would just like to be able to get the motors to turn forward and backward via HIGH or LOW commands. Is there a simple H Bridge schematic that I can use to power each motor separately?
Here's a link to the gearbox if it helps:
http://www.robotshop.com/productinfo.aspx?pc=RB-Tam-32&lang=en-US
Thanks for the help!
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
How about you do this: Go to google, type in "h-bridge schematic" and see what you come up with (maybe throw in a keyword like "L298" and "L293"); seriously - do a bit of research first, then come back here. This is a very common question (you could probably find this kind of question asked and answered 200 times in the past year alone!), and I've already used up way more time typing this than it would take you to find an answer.
Logged
Alabama
Offline Offline
Newbie
View Profile
I've already done that, but I figured there might be a common one used here that was very specific. Thanks for your help.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
That is a good point - the best advice from the forums really ought to be migrating into playground examples in a less haphazard manner perhaps...
Logged
South Texas
Offline Offline
God Member
View Profile
Lok at the various motor shields. there are several out there that have 2 H-Bridges that would allow you to control 2 motors. Most would require 2 Arduino pins for each motor (thats because they can also be used to power 1 stepper).
You need to know the current rating of your motors, and use that to get a unit big enough for your current requirements.
H-Bridge circuits are not simple, unfortunately they require 8 transistors and a few other components...
I know Sparkfun, and others have a Motor Shield for US$25 that is good for 2 amps. Uses an L298 H-Bridge IC. You can get a schematic from them also.
http://www.sparkfun.com/products/9815
Logged
Pages: [1]   Go Up
Print
Jump to:
