Topic: Max photoResistor (Read 1 time) previous topic - next topic
woody_unreal
im controlling a Stepper with a photoResistor set, But if the values run to high it doesnt run the code like there is no difference between the sensors,,,, See if any on can see where my codeing is creatign the failer,, any suggestions would be greatly appreciated :)
Code: [Select]
Thomas Wood
PhotoCell Controlled Stepper Motor Left and Right
Feb 15,2012
#include <Stepper.h>
const int stepsPerRevolution = 200;  // Turns of the motor
int inputPhotoLeft = 0; // photresistors pin
int inputPhotoRight = 1; // photresistors pin
int Left = 0; // Store readings from the photoresistors.
int Right = 0; // Store readings from the photoresistors.
int threshhold = 450;
// this is here from reading the serial monitors valued to get a ruff Idea of value to set A
                      //And how dark you Want your motor to stop moving at
int difSence = 20; // differenace tolarance between sensors
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8,9,10,11);
  myStepper.setSpeed(150);
   pinMode(13, OUTPUT); //led doesnt need to be on
Left = analogRead(inputPhotoLeft); // sets the photcells position left - right
Right = analogRead(inputPhotoRight);
//Lines for debugging ,analog display of sensor values
Serial.print(" Left \t");
Serial.print(Left);
Serial.print("  Right \t");
Serial.println(Right);
(13 == LOW);
if ((Left > threshhold) > (Right + difSence > threshhold ))
  Serial.print("clockwise \t");
  Serial.println(Left);
    myStepper.step(-stepsPerRevolution);
if  ((Right > threshhold) > (Left + difSence > threshhold ))
  Serial.print("counterclockwise \t");
   myStepper.step(stepsPerRevolution);
if ((Left < threshhold) && (Right < threshhold))
  // this is to limit the after dark operation -
  //no need in a plane,train,street light or automobil to make the panel move :)
  Serial.println("Lower threshhold Reached - hopefully we have stopped");
  Serial.print("Left Sensor \t");
  Serial.print(Left);
  Serial.print("   Right Sensor \t");
digitalWrite(8,LOW);
digitalWrite(9,LOW);
digitalWrite(10,LOW);
digitalWrite(11,LOW);
delay(5000);
// these are here to disengage the coils as not to hold ,and in turn over heat the motor
johnwasser
Code: [Select]
(13 == LOW);
Doesn't do anything.  Perhaps you meant "digitalWrite(13, LOW);" to turn the LED off?
Code: [Select]
If Left is greater than threshold) is greater than (Right  plus difSence is greater then threshold) make very little sense.  I think you are trying to do too much in one comparison.  (Left > threshold) results in a value that is 0 (false) or 1 (true). (Right + difSence > threshold ) similarly results in a 0 or 1.  By comparing for the first one being greater then the second you are saying:
If (Left > threshold) is true (1) and (Right + difSence > threshold) is false (0).
I think what you intended was:
Code: [Select]
if (((Left > threshhold) || (Right > threshhold)) && (Left > Right + difSense))
That means: "If either is above the threshold and Left is far enough above Right to make a difference"
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
woody_unreal
awsome more info to work with :) time for new symble research, I'll see how this works and post my results :)
woody_unreal
also would you think with the possable error of syntax , would it make it when the photoresistors are at there max light the the left and right section not operate . or not operate from the threshold section ?
woody_unreal
Code: [Select]
wouldn't that read - if left is greater than threshhold - or - right is greater than threshhold -- AND -- left greater than right plus differance...
would that make the code if eather sensor was above threshhold?
is this better
Code: [Select]
if (((Left > threshhold) && (Right > threshhold)) && (Left > Right + difSense))
wouldn't work smoother with the compairitor of && (and) to make sure both are below tolarance ?
woody_unreal
ok - lol i was mistaken ,, || or works better ,, Thank you :)
