Loading...
Pages: [1]   Go Down
Author Topic: Where do i put the code to alter timers?  (Read 263 times)
Offline Offline
Jr. Member
View Profile
I've found a sketch posted on the old forum that does basically all i want.... i.e. reads data from x-sim, and sends it via the arduino to my real gauges.
Only problem i have is that it is using pwm to vary the voltage to earth to make the needles move in the gauges, and this is causing the coils in the air-core gauges to 'sing' due to the low frequency of the pwm.
i need to run the pwm to those gauges at 31Khz to make them silent (to our ears), i'm using a mega 1280, so think timer 4 is best to alter???
i think i need to add "TCCR4B = TCCR4B 0b11111000 | 0x01", but where do i add it in the sketch? and do i need any other code to make timer 4 run at 31Khz?
The sketch i am using for my gauges is below, originally written my 'herctrap'
Code:
int rpm;
int i;
int leds;
int Speed;
int fuel;
int oil;
int previous_potion = 0;
int rotate;
int water;
char kind_of_data;
void setup(){
  pinMode(22, OUTPUT);
  pinMode(23, OUTPUT);
  //****************************** READ DATA FROM SERIAL ******************************
  while(Serial.available() > 0)
    kind_of_data = Serial.read();
    if (kind_of_data == 'R' ) Read_Rpm();
    if (kind_of_data == 'F' ) Read_Fuel();
    if (kind_of_data == 'W' ) Read_Water();
    if (kind_of_data == 'O' ) Read_Oil();
  //****************************** READ DATA FROM SERIAL END ******************************
void  Read_Rpm(){
  delay(1);
  int Rpm100 = Serial.read()- '0';
  delay(1);
  int Rpm10 = Serial.read()- '0';
  delay(1);
  int Rpm1 = Serial.read()- '0';
  int rpm = 100*Rpm100 + 10*Rpm10 + Rpm1;
  tone(9, map(rpm,127,255,45,433));
void Read_Fuel(){
  delay(1);
  int Fuel100 = Serial.read()- '0';
  delay(1);
  int Fuel10 = Serial.read()- '0';
  delay(1);
  int Fuel1 = Serial.read()- '0';
  fuel = 100*Fuel100 + 10*Fuel10 + Fuel1;
  analogWrite(6,map(fuel,127,255,0,255));
  if (fuel<155) digitalWrite(22,HIGH);
  if (fuel>155) digitalWrite(22,LOW);
void Read_Water(){
  delay(1);
  int Water100 = Serial.read()- '0';
  delay(1);
  int Water10 = Serial.read()- '0';
  delay(1);
  int Water1 = Serial.read()- '0';
  water = 100*Water100 + 10*Water10 + Water1;
  analogWrite(7,map(water,127,255,0,255));
   if (water>200) digitalWrite(23,HIGH);
  if (water<200) digitalWrite(23,LOW);
void Read_Oil(){
  delay(1);
  int Oil100 = Serial.read()- '0';
  delay(1);
  int Oil10 = Serial.read()- '0';
  delay(1);
  int Oil1 = Serial.read()- '0';
  oil = 100*Oil100 + 10*Oil10 + Oil1;
  analogWrite(8,map(oil,127,255,0,255));
Would someone be kind enough to indicate where i need to insert the code in the above sketch to set the timer that runs pins 6, 7 & 8 @ 31Khz please (or any other set of 3 analog pins, as long as the timer being changed dosent throw off other things like the servo lib. as i will be using that nest for some gauges that were mechanical and having servos shoved in them.
« Last Edit: March 02, 2012, 04:08:29 pm by gazz » Logged
Offline Offline
Jr. Member
View Profile
Found it, a post somewhere on the forum eventually led me to figure it out,
i just added 'TCCR4B = (TCCR4B & 0xF8) | 0x01 ;' in the setup, and my gauges are silent.
i can see it's going to be very very hard for me to learn this programming stuff, i'm almost wishing my hands werent hurting so much and i could go back to striping engines into little pieces, replacing all worn parts and re-building it... and not having any 'spare' buts or bolts left over afterwards, as that's what i grew up with, so i know the mechanical stuff and to me it's easy,
Logged
Pages: [1]   Go Up
Print
Jump to:
