Topic: EL wire: separate controllable strands, single inverter, battery powered? (Read 6342 times) previous topic - next topic
spudnackle
I'm making a light display that will respond to music! I want to use only one inverter for a number of EL wire strands (possibly 12 of them) but have them separately controllable using the Arduino. I've seen a number of ways to do this but I had a few questions.
This seems to be the best option:
http://www.instructables.com/id/Programmable-LilyPad-EL-Wire-Dress/?ALLSTEPS
For my project, adding another optocoupler/triac pair for each separate channel would be necessary.
Could I use solid state relays instead? What would be the pros/cons?
The NTE3044 optocoupler is difficult to find. At Mouser it says that the part is not recommended for new designs. What does that mean and how could I find a equivalent part?
I have read that inverters can be damaged if they are turned on while not connected to anything. Why is this?
Also to be considered:
At any point in time while using my device, only 3 of the EL strands would need to be lit at once.
Thanks for helping me out!
johnwasser
You probably don't need the opto-couplers.  This product from sparkfun has  Z0103MN TRIACs connected directly to an ATmega168 (basically an Arduino Lillypad):
http://www.sparkfun.com/products/9203
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
spudnackle
So, you don't think there is any chance that the (relatively) high voltage from the inverter could zap the arduino?
johnwasser
Of course there is a chance that you could hook something up incorrectly or a component could fail and cause damage to your Arduino.  I don't think that adding opto-couplers will prevent stupid mistakes so adding them might just reduce the chances of failure from 0.0001% to 0.00001%.  Of course adding components also provides more opportunity for failure so in the end they might not even increase reliability. :)
