Topic: Is serail.write() blocking? (Read 2323 times) previous topic - next topic
jimLee
Do I need to worry about over running buffers when calling serial.write()? Or will it block 'till it has room for the data I called it with? I can't find any info on how this works.
Thanks!
-jim lee
PNW Ardiuno & Maker club
1012 9Th Street, Anacortes, WA 98221 (Around the back of building)
Contact jimLee or Naneen for more info
PaulS
Quote
Why not? You have the source code. Look at it.
If there is no room in the buffer, the function blocks until there is room. On 1.0, the buffer size is 64 bytes. On 0023 and earlier, the buffer size was a bit smaller - 1 byte.
jimLee
I have the source code? Really? Where?
-jim lee
nickgammon
On my Windows PC, version 0022:
Code: [Select]
C:\Documents and Settings\Owner\Desktop\arduino-0022\hardware\arduino\cores\arduino\HardwareSerial.h
C:\Documents and Settings\Owner\Desktop\arduino-0022\hardware\arduino\cores\arduino\HardwareSerial.cpp
Depends somewhat on where you installed it. So basically:
Code: [Select]
<install directory>\arduino\hardware\arduino\cores\arduino\HardwareSerial.h
<install directory>\arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
jimLee
nickgammon
On my Mac, version 1.0 it is:
Code: [Select]
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/HardwareSerial.h
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/HardwareSerial.cpp
More info:
jimLee
Found it and it blocks. Was even a note about what it should be doing.
Thanks again, this will be a great help.
-jim lee
