Loading...
Pages: [1]   Go Down
Author Topic: AVcc low pass filter required?  (Read 728 times)
alabama
Offline Offline
Full Member
View Profile
I just built my first breadboard Arduino (after I smoked my first Uno, 328 was still good). According to the tutorial I followed, to make use of the ADC, I need a low pass filter on pin 20 of the Atmega328 (AVcc)to get rid of power supply noise. Is this necessary? My o-scope shows only a few micro-volts noise even before plugged in to the two caps on the power input cicuit, I can't find anything after them.
 I want to use an analog accelerometer, not that critical as far as noise goes. If I will need it, any links to a schematic? Or just design my own for transient 60hz noise?
Thanks,
TomJ
Logged
Einstein once said you don't really understand anything until you can explain it to your Grandmother
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Very few arduino type boards or clones use a low pass filter to the Avcc pin, they just normally wire it to the Vcc pin with a .1ufd bypass cap to ground for some noise filtering. The AVR datasheet for a 328p chip does show a typical and recommended cap/inductor filter for the Avcc if you require the improved noise filtering method. It's up to you, most normally don't see the benefit in most applications.
Lefty
« Last Edit: March 04, 2012, 07:13:38 pm by retrolefty » Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
If you're not doing audio work, you can probably get by without it.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
alabama
Offline Offline
Full Member
View Profile
Thanks fellas,
Nice of you to reply so fast.
TomJ
Logged
Pages: [1]   Go Up
Print
Jump to:
