Topic: Error is sizeof code (Read 960 times) previous topic - next topic
quickwhitefox
Mar 03, 2012, 10:23 am Last Edit: Mar 03, 2012, 11:33 pm by AWOL Reason: 1
http://arduino.cc/en/Reference/Sizeof
for (i = 0; i < (sizeof(myInts)/sizeof(int)) - 1; i++) {
  // do something with myInts[i]
The -1 is not needed for an int  array.
johnwasser
#1
Mar 03, 2012, 09:08 pm Last Edit: Mar 03, 2012, 11:34 pm by AWOL Reason: 1
In that same example it should probably be made clear that "sizeof(myStr)" includes the null terminator which is why the -1 is appropriate there.
A slightly more robust way of determinig the number of elements in an arbitrary array:
sizeof myArray / sizeof myArray[0]
That way if the data type of the array is changed the code still works
mromani
I usually put something like this
#define ARY_LEN(a) (sizeof(a)/sizeof(a[0]))
whenever my code has to work wiht arrays... i.e. very often. Would't it be nice to have a similar (better worded, perhaps) macro in Arduino.h and documented in Reference ?
Just my 2 cents, anyway...
