Topic: Need help correcting the error in the code (Read 464 times) previous topic - next topic
yaantey
Given is the code and I am having getting an error "invalid conversion from 'const char' to 'char'. What I want to do is, pass the value to  function.
Quote
// Tx Code
// Wireless Force Sensor
// By Yaameen Faisal
#include <VirtualWire.h>              // Include VirtualWire library for wireless transmission
int fsrPin = 1;       // define pin A0 as FSR pin
int analog[8];        // define array to get multiple analog readings
int voltage[8];       // define array to get multiple voltage readings
int j;
int awakeCount = 0, restlessCount = 0, asleepCount = 0 ;  // define and initialise counters
  Serial.begin(9600);        // setup serial communication with baud rate (bits per second) to diplay on serial monitor
  pinMode(fsrPin, INPUT);    // set pin A0 as input
  for(j=0; j<=7; j++)
    analog[j] = analogRead(fsrPin);                  // read pin A0, 8 times
    Serial.print("Analog Reading = ");
    Serial.print(analog[j],DEC);
    voltage[j] = map(analog[j], 0, 1023, 0, 5000);   // convert analog reading (0-1023) to voltage (0-5V)
    Serial.print(", Voltage in mV = ");
    Serial.print(voltage[j],DEC);
    if (voltage[j] >= 3500)                            //check if voltage >= 3500, if so restless counter = +1
      restlessCount = restlessCount + 1;
    else if (voltage[j] > 1500 && voltage[j] < 3500)  //check if 1500 < voltage < 3500, if so awake counter = +1
      awakeCount = awakeCount + 1;
    else if (voltage[j] > 100 && voltage[j] <= 1500)  //check if 100 < voltage <= 1500, if so asleep counter = +1
      asleepCount = asleepCount + 1;
    Serial.print(", Awake count = ");
    Serial.print(awakeCount, DEC);
    Serial.print(", Restless count = ");
    Serial.print(restlessCount, DEC);
    Serial.print(", Asleep count = ");
    Serial.println(asleepCount, DEC);
    delay (3000);
    int asleepcountLed = asleepCount;      // store asleep counter value in alseepcountLED
    int awakecountLed = awakeCount;        // store awake counter value in awakecountLED
    int restlesscountLed = restlessCount;  // store restless counter value in restlesscountLED
    Serial.println("-----------------------------------------------------------------------");
    if (asleepcountLed > awakecountLed && asleepcountLed > restlesscountLed)         // if asleep > awake & asleep > restless, led = green colour
      const char *data = "g";                                ("ERROR IS HERE, BUT I DONT KNOW HOW TO CORRECT IT)
      msgsend(data);
    asleepCount =0;       // reset asleep counter
    awakeCount = 0;       // reset awake counter
    restlessCount = 0;    // reset restless counter
    delay (500);
void msgsend(char msg)
  vw_send((uint8_t *)msg, strlen(msg));
  vw_wait_tx();
CrossRoads
I can help with part - use single quotes here
Not how to get from the example
Code: [Select]
const char *msg = "hello";
delay(400);
to what you are doing
PaulS
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
