Loading...
Pages: [1]   Go Down
Author Topic: I2CKeypad with enc28j60  (Read 635 times)
Netherlands
Offline Offline
Full Member
View Profile
Hi People!,
I have a seriously weird problem....
I have set up an arduino with the enc26j60 breakout (etherShield lib), a 16X2 LCD (PCFCrystal lib) and some less relevant
extensions.
The problem i'm facing is that when i trij to use the two together the arduino reboots  smiley-confuse
I have a running website that will have to be interrupted but that's not a big deal and everything runs until i give a input on
the i2c keypad. I've tried a lot of things but the only way is to delete the code from the loop with all the etherShield print and the etherShield respond.
I hope my explanation is clear enough  smiley
Any suggestions?
-Kenny-
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Quote
and some less relevant extensions
might be more relevant than you thought  -  do you provide enough power to drive all those goodies smiley
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Netherlands
Offline Offline
Full Member
View Profile
Thanks for the quick reply,
I have it connected on my usb and than it all works fine, but to be sure i connected an external 450mA wall adapter, so i guess when it runs from usb than this extra should do
« Last Edit: March 04, 2012, 10:54:47 am by kenny_-_ » Logged
Netherlands
Offline Offline
Full Member
View Profile
I just measured and it takes up about 250mA in total
« Last Edit: March 04, 2012, 10:26:23 am by kenny_-_ » Logged
Netherlands
Offline Offline
Full Member
View Profile
I'm really stuck on this and guess that i have to try some different lib's perhaps, it's a shame because i liked these   smiley-sad
I will try some stuff next weekend but add the weirdest part.
I took everything from the loop in the ethershield example and placed it in a separate sub called EtherLoop(),
if i comment out the call of etherloop everything works (by that i mean that i also setup everything for the ethershield loop).
Now i can make a "if(some_bool = true)" and leave some_bool false and uncomment the EtherLoop(), now it's not called for sure
but still rebooting smiley-confuse (like, huh?) but if i comment it out and leave the loop but don't call it than it works....
Anyone have any other ideas?
Logged
Netherlands
Offline Offline
Full Member
View Profile
Is there no one with any ideas at all?
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
Patience is a virtue smiley-wink
What is the voltage of the Wall wart? it should be 7 VOlt at least - see hardware specs.
Logged
Rob Tillaart
Netherlands
Offline Offline
Full Member
View Profile
It's 5 volt but i connected the atmega on a breadboard without my uno pcb, so i guess that 5v is max?
Logged
Netherlands
Offline Offline
Full Member
View Profile
Just for the sake of trying i took a 5v 1000mA power supply home from work yesterday, but the results where the same. There is also no voltage dip anywhere(also tried the 3,3 volt voltage regulator for the enc28j60).
Logged
Lisbon, Portugal
Offline Offline
Full Member
Bow before me for I am root.
View Profile
WWW
Why are you blaming power ?
Arduino reboot loop() usually is bad programming leading to memory corruption or no free SRAM for runtime.
As you mentioned you have a LCD, are you storing all your string into PROGMEM ? If no, you should.
Logged
Creative Commons License
All my contributions on this forum are licensed under a:
Creative Commons Attribution-NonCommercial-ShareAlike 3.0 Unported License.
Netherlands
Offline Offline
Full Member
View Profile
I could try that thanks for the input!
But i've been trying some more and what i found out was that it actually hang at a Serial.print("something key pressed"); so i guess that it could be that i just have to use the progmem
I just had some small things with arduino and this is the first "a little big" so these are the things i run in to i guess  smiley-red
I really wan't to thank you guys for the input and i think i can almost say it's solved, i am going to really through test this one!  smiley
Did not expect this, but the better it feels when you see a solution  smiley
Logged
Netherlands
Offline Offline
Full Member
View Profile
Finally everything is up and running again!
Again thanks!  smiley
Logged
Lisbon, Portugal
Offline Offline
Full Member
View Profile
WWW
So was it really SRAM ?
Logged
Netherlands
Offline Offline
Full Member
View Profile
o sorry didn't come back for some time but yes it was! smiley
I got it working now with declaring all my strings first with progmem
Logged
Pages: [1]   Go Up
Print
Jump to:
