Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Need help with RGB rainbow colors  (Read 1590 times)
Netherlands
Online Online
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
found this one in my experiments section. Code goes 360 degrees through hue space converting it to related RGB values.
links to 2 website included
Code:
//    FILE: RGB2HUE.pde
//  AUTHOR: Rob Tillaart
//    DATE: 2011-09-17
// PUPROSE: color-rainbow
// http://www.dipzo.com/wordpress/?p=50
// http://www.easyrgb.com/index.php?X=MATH
int Rpin=10;
int Gpin=9;
int Bpin=11;
float H,S,L, Rval,Gval,Bval;
void HSL(float H, float S, float L, float& Rval, float& Gval, float& Bval);
float Hue_2_RGB( float v1, float v2, float vH );
  pinMode(12, OUTPUT);
  S=1;
  L=.5;
  Rval=0;
  Gval=0;
  Bval=0;
  for (int i = 0; i< 360; i++)
    HSL(i/360.0,S,L,Rval,Gval,Bval);
    //common anode configuration
    //analogWrite(Rpin, 255-Rval);
    //analogWrite(Gpin, 255-Gval);
    //analogWrite(Bpin, 255-Bval);
    //digitalWrite(12,HIGH);
    //common cathode configuration
    analogWrite(Rpin, Rval);
    analogWrite(Gpin, Gval);
    analogWrite(Bpin, Bval);
    digitalWrite(12,LOW);
    //print statements for debug
    Serial.print("position:");
    Serial.print(H);
    Serial.print(" R:");
    Serial.print(Rval);
    Serial.print(" G:");
    Serial.print(Gval);
    Serial.print(" B:");
    Serial.println(Bval);
    delay(100);
  float var_1;
  float var_2;
  float Hu=H+.33;
  float Hd=H-.33;
  if ( S == 0 )                       //HSL from 0 to 1
    Rval = L * 255;                      //RGB results from 0 to 255
    Gval = L * 255;
    Bval = L * 255;
    if ( L < 0.5 )
      var_2 = L * ( 1 + S );
      var_2 = ( L + S ) - ( S * L );
    var_1 = 2 * L - var_2;
    Rval = round(255 * Hue_2_RGB( var_1, var_2, Hu ));
    Serial.print("Rval:");
    Serial.println(Hue_2_RGB( var_1, var_2, Hu ));
    Gval = round(255 * Hue_2_RGB( var_1, var_2, H ));
    Bval = round(255 * Hue_2_RGB( var_1, var_2, Hd ));
float Hue_2_RGB( float v1, float v2, float vH )             //Function Hue_2_RGB
  if ( vH < 0 )
    vH += 1;
  if ( vH > 1 )
    vH -= 1;
  if ( ( 6 * vH ) < 1 )
    return ( v1 + ( v2 - v1 ) * 6 * vH );
  if ( ( 2 * vH ) < 1 )
    return ( v2 );
  if ( ( 3 * vH ) < 2 )
    return ( v1 + ( v2 - v1 ) * (.66-vH) * 6 );
  return ( v1 );
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
West Des Moines, Iowa USA
Offline Offline
Sr. Member
View Profile
WWW
Interesting! I just tossed this version into my "play" directory:
Code:
#define R
#define G      /* Define analog LED pins */
#define B
unsigned char r=~0,g=0,b=0;
void aw(unsigned char p,unsigned char v)
{  analogWrite(p,v);
   delay(50);
void setup(void)
{  analogWrite(R,r);
   analogWrite(G,g);
   analogWrite(B,b);
void loop(void)
{  do aw(G,++g); while (~g);
   do aw(R,--r); while ( r);
   do aw(B,++b); while (~b);
   do aw(G,--g); while ( g);
   do aw(R,++r); while (~r);
   do aw(B,--b); while ( b);
Logged
There's always a better way!
Belgium
Offline Offline
Full Member
I love Arduino!
View Profile
They all work fine, but how can I make a color display with the RGB value that I want, for example the color indigo : 111,0,255(red led is less bright, green led is off, blue led is at full brightness) ?
So not automatic color change.
Should I make an array like this?: Red[] = {111,0,255}
And how do I make the array display the color then?
Logged
Netherlands
Online Online
Tesla Member
View Profile
Quote
Yes, define colors as separate arrays
2) define a function something like this, (not tested)
Code:
byte indigo[] = { 111,0, 255 };
byte red [] = {255, 0, 0 };
void displayColor(byte *color)
{  analogWrite(R, color[0]);
   analogWrite(G, color[1]);
   analogWrite(B, color[2]);
then you can call - displayColor(red);
Logged
Rob Tillaart
Belgium
Offline Offline
Full Member
I love Arduino!
View Profile
That's what I wanted!
With a little modification, it worked.
Thank you!
Now, how can I make a smooth transition between them?
Code:
byte red [] = { 255, 0, 0 };
byte orange [] = { 255,127,0 };
byte yellow [] = { 255,255,0 };
byte green [] = { 0,255,0 };
byte blue [] = { 0,0,255 };
byte indigo[] = { 111,0,255 };
byte violet[] = { 127,0,255 };
int R = 11;
int G = 10;
int B = 9;
#define DELAY 3000
void setup(){
  pinMode(R, OUTPUT);
  pinMode(G, OUTPUT);
  pinMode(B, OUTPUT);
void loop(){
  displayColor(red);
  delay(DELAY);
  displayColor(orange);
  delay(DELAY);
  displayColor(yellow);
  delay(DELAY);
  displayColor(green);
  delay(DELAY);
  displayColor(blue);
  delay(DELAY);
  displayColor(indigo);
  delay(DELAY);
  displayColor(violet);
  delay(DELAY);
Logged
Netherlands
Online Online
Tesla Member
View Profile
Quote
You need an interpolation function, not trivial as it can have many parameters depending on the way you interpolate.
linear interpolation is easiest (see code below, not tested might contain some bugs)
Code:
void interpolate( byte *col1, byte *col2, byte *out, int stepnr, int maxsteps)
  for (int i =0; i<3; i++)
    out[i] = col1[i] + stepnr * (col2[i] - col1[i]) / maxsteps);
.... usage ...
for (int c=0; c<100; c++)
  byte newColor[3];
  interpolate(Red, Green, newColor, c, 100);
  displayColor(newColor);
Give it a try
Logged
Rob Tillaart
Belgium
Offline Offline
Full Member
I love Arduino!
View Profile
Seems to be a bit to difficult for me, because I really don't know where I should place your code into my existing code smiley
Should an easy fade out and fade in between each color be easier?
Logged
Offline Offline
Sr. Member
View Profile
WWW
Every RBG color consists of a red component, a green component, and a blue component. To output a single color, all that's needed is to output its components. If you want indigo with red = 111, green = 0, and blue = 255 then all that's needed is
Code:
   analogWrite(redPin,111);
   analogWrite(greenPin,0);
   analogWrite(bluePin,255);
To produce the rainbow cycle you asked about, you'll find it helpful to take a look at a color wheel like the one I've attached below (click on the thumbnail to see full size). Notice that there are 6 (sixty degree) segments in each of which only one of the three components changes while the other two remain constant.
What that means is than if you want to smoothly transition all the way around the wheel, you can do so by setting up a sequence of six loops, each of which changes only one of the three components - as I did in my previous post.   smiley-mr-green
Logged
Belgium
Offline Offline
Full Member
I love Arduino!
View Profile
Thanks for the tip! smiley-lol
Is it possible to fade out and fade back in to another color between the colors in my code, instead of a delay?
So the colors does not just go out, but fade out, and then fade in to another color.
« Last Edit: March 10, 2012, 12:39:41 pm by TiboJ » Logged
Offline Offline
Sr. Member
View Profile
WWW
Certainly. All you need to do is choose that "another color" and choose which direction around the color wheel you want to go, then write the sequence(s) to show the intermediate values.
Logged
Offline Offline
Sr. Member
View Profile
WWW
I might have misunderstood. If you were asking about fading the current color to dark, then gradually bringing up another color, then you might want to try something like this (untested):
Code:
void write_rgb_components(unsigned char r,unsigned char g,unsigned char b)
{  static unsigned char old_r, old_g, old_b;
   if (r != old_r) analogWrite(R,old_r = r);
   if (g != old_g) analogWrite(G,old_g = g);
   if (b != old_b) analogWrite(B,old_b = b);
   delay(50);
void fade_from(unsigned char r,unsigned char g,unsigned char b)
{  unsigned i;
   for (i = 255; i != 0; i--)
      write_rgb_components((i * r) >> 8,(i * g) >> 8,(i * b) >> 8);
   write_rgb_components(0,0,0);
void fade_to(unsigned char r,unsigned char g,unsigned char b)
{  unsigned i;
   for (i = 0; i < 256; i++)
   write_rgb_components(r,g,b);
Logged
Offline Offline
Newbie
View Profile
Im not so good at this, but I find bitshift and other things like that hard to understand. I think that everybody is giving good advise, but its a bit over my head. Isn't it easier to make an array in the setup and then use it in the code without any calculations?
Code:
arrayPos=0;
stepSize=16
// red to magenta
for (x=0; x<255; x+stepSize){
  arrayRGB[arrayPos]=[255,0,x]
  arrayPos++;
// magenta to blue
for (x=255; x!=0; x-stepSize){
  arrayRGB[arrayPos]=[x,0,255]
  arrayPos++;
// blue to cyan
  arrayRGB[arrayPos]=[0,x,255]
  arrayPos++;
// cyan to green
for (x=255; x!=0; x--){
  arrayRGB[arrayPos]=[0,255,x]
  arrayPos++;
// green to yellow
  arrayRGB[arrayPos]=[x,255,0]
  arrayPos++;
// yellow to red
  arrayRGB[arrayPos]=[255,x,0]
  arrayPos++;
Logged
Offline Offline
Sr. Member
View Profile
WWW
@tiirak - we can't assign three values to a single (scalar) array element, but if calculating the values is sufficiently simple, then it may actually cost less to calculate values as needed than to calculate them and store/fetch them from an array.
Logged
Offline Offline
Newbie
View Profile
Sorry, Im a newbee here. Just tied to write quick and easy to understand. What about this?
Code:
// red to magenta
  arrayRGB[arrayPos][1]=255;
  arrayRGB[arrayPos][2]=0;
  arrayRGB[arrayPos][3]=x;
  arrayPos++;
And isn't it better to take memory (if possible) and not cycles?
Logged
Offline Offline
Sr. Member
View Profile
WWW
Hmm - you just used up all available RAM to store 3-byte red values, and then your program crashed.  ]smiley
It's up to you to decide if this is the best approach for your particular application. If the application were a simple learning exercise with a goal of transitioning smoothly from one displayed color to another, I would not be much inclined to worry about resources - but rather with my understanding of the interface between the standard hardware, my code, and techniques for producing color.
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
