Topic: My home-brew Arduino OBD-II connection kit (Read 152750 times) previous topic - next topic
krossk2
Hello,
congratulations for a job well done!
Also I have created a dashboard OBDII but I used another microcontroller, the NXP LPC1768.
I'd like to have your opinion, HERE you can find the video demo! :)
Hello and congratulations again!
"Se una cosa sembra troppo bella per essere vera, semplicemente... non รจ vera!"
Video demonstration of my DIY Dashboard OBDII
rcwang128
I have ordered one. How long it takes for shipping to U.S.?  Thanks.
robtillaart
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
System_Error_117
Really nice product, I think....
I've purchased two of these things thinking the first might be defective as I couldn't get any sort of clear readings out of it even when I connected the UART lines to an oscilloscope.
I'm an electronics engineer and I don't see any issues on my end, I can't even get the simple LED program to work for engine RPM over 2000.
I've tried it on a 1999 and a 2000 Firebird with no results. But cars OBD ports work fine with all other scanners.
Really is a shame, would love to figure it out finally
polymorph
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
penjoseph
#20
Nov 15, 2014, 08:39 am Last Edit: Nov 15, 2014, 08:49 am by penjoseph
I was able to communicate with my car using Stanley Huang's (Freematics) OBD adapter - 2008 Hyundai Accent\Verna CRDi (turbo diesel).
The OBD CAN bus data is displayed on 20x4 LCD using Arduino Mega 2560 &  OBD UART version adapter.
Left side
Engine rpm
Fuel Rail Pressure in kpsi
Boost in psi
Voltage at ECU
Right side
Intake Air temperature in celsius
Coolant water temperature in celsius
Load in %
Commanded EGR in %
Slow Coach
penjoseph
Coded a RPM based dual stage LED shift light. The LED shift light is programmed to 'blink' between 2800-3800rpm, more than 3800rpm it remains 'on'. Its a direct injected turbo diesel hence the rev range is limited unlike gasoline.
Dual Stage RPM Shift Light
Slow Coach
Randcook
The solution is to put your seat belt on
Dave9n3
Sorry to bump an old thread but am i able to use this alongside another OBD2 connection, i require another connection in order for me to log variables on my ecu for home tuning.
catasbox
Hello.
I need necessary hardware to control the Light Module on an 2006 BMW, especially to activate the brake lights.
Can this be done by any of Telematics Kits?
YellowGTM
I don't recommend buying this product as the support is abysmal at best.
I've tried emailing support directly as well as using their dedicated forum and haven't received a reply
in over a month.
If you go to the forum you will see hundreds of questions without replies from the developer.
I had to figure out the problem myself which was a misdirected reference to the folder than contains
the .h and .cpp files.
This was also communicated to other members on the Freematics forum and the designer, without any
acknowledgement.
Electronics/Avionics/Automotive
C/C++, QBASIC, Visual Basic, Assembly
fernandomoriera
Please let me know where it would be possible to download the Arduino source code for obd2 diagnostics and let me know please if it contains also the fault codes
Mail you answer please to my mailbox:  chaikovsky401@gmail.com
Thank you very much for your collaboration
 JEOVANNY VITERI
