Topic: Sending multiple variables from Arduino to Labview with serial.write() (Read 8103 times) previous topic - next topic
adamblodz
Hello.
I would like to send multiple variables from Arduino to Labview to plot them in real time. Serial.print command is insufficient (laggy), so I've done some searching and found this example: http://www.stefanocottafavi.com/?p=412&page=2. With this VI and code I can now send one float variable without any lag. I don't know how to send more of them though :)
Here's the Arduino code:
 // 5-byte packet
 Serial.write((byte)0x69); // header
 serialWriteFloat(var/*bmp.readAltitude(103500)*/);
 delay(100);
void serialWriteFloat(float arg) {
 byte * data = (byte *) &arg;
 Serial.write (data, sizeof (arg));
and here's VI:
Is it about adding cases in Labview with different headers and respectively serial.write commands with their names and variable names in Arduino code?
I would be grateful for some help or pointing me in right direction.
Cheers
robtillaart
The trick is to make packets of data, a packet starts with a start byte, then an identifier then the value and then a stop byte, optionally there is a crc code for error detection.
think of it as < P = B B B B >
So sending the altitude becomes :
void writeAltitude(float val)
  writeField('A', val);
void writeTemperature(float val)
  writeField('T', val);
void writeField(char ID, float val)
  Serial.print('<'); // start byte
  Serial.print(ID); ID
  Serial.write (&val, sizeof (val));
  Serial.print(">");   // stop byte
On the receiving site you must unpack the data again of course
Rob Tillaart
adamblodz
Thanks for response!
If anybody wondered - yes, adding different cases for given headers along with corresponding commands in Arduino does the trick ;)
robtillaart
@adamblodz
Can you please post your final code (optionally minimized to the essence) so it can be used for future reference?
Thank you,
Rob Tillaart
