Topic: Arduino compatible development board (Read 467 times) previous topic - next topic
matt_quinn
Hello all,
Hoping I've found the correct area of the forum to post this. I'd like to purchase a board that can serve as a development canvas for arduino projects. I've done some searching around and probably the best looking one I've found is:
http://shop.avrvi.com/goods-362.html
(Translate to english, I think the page is natively Chinese)
My question is, would this board be arduino compatible? I see it utilizes the Atmega1280, that the old Arduino Mega used.
Also, in terms of reliability, should I trust this?
Thanks all for your help.
Coding Badly
Hello,
A what?
Quote
http://enshop.avrvi.com/Easyavr_ATmega1280_board_kit.html
I believe Atmel sells boards similar to that one (lot's of built-in gadgets).  I believe Smiley Micros also has similar stuff.
Quote
You will very likely have to use a separate programmer.  Oh, wait.  Maybe not ... "On-board AVRISPMKII USB interface".
For Serial, it looks like you will need an RS-232 adapter for the PC.
It looks like they are using an "odd" frequency clock.  millis and its ilk will not be accurate.
Quote
You're on your own there.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
