Topic: Speed slow, what to do? (Read 795 times) previous topic - next topic
godo
Hi there,
I built a Sanguino clone (see my other posts). Two boards work fine, I burned the bootloader via usbtinyISP. I could upload sketches with a 2009 and have them running nicely.
Two recently finished boards behave strange: I burned the bootloader as above, but they do not communicate via USB and Duemilanove, and I did a loop test, which passed without problems. I checked the pins for connections to the outbreak pins, no problem.
Then I burned a hex-file from my sketch right via usbtinyISP. Now my program starts, but around 10 times slower than normal.
What happened? Do I have to check the 16MHz crystal?
Any help is apprechiated, thanks in advance
Sebastian
johnwasser
Factory chips run at 1 MHz (8 MHz internal RC clock and prescale defaulting to 8).  Sounds like you didn't set the fuses for the external 16 MHz crystal and default prescale of 1.
godo
#2
Mar 05, 2012, 07:37 pm Last Edit: Mar 05, 2012, 09:17 pm by godo Reason: 1
Thanks John, sounds good. I hope I find some instructions about that. Thanks.
[hours later] Sorry, but shouldn't the bootloader already set the fuses to the correct speed? Or why is the frequency in the boards descriptions?
godo
[Much more frustrating hours later] Allright, it runs fast now after I learned how to set the fuses and after repeating that a couple of times it worked (the hex uploaded via USBtinyISP). I still cannot communicate via serial, so it was no speed issue. Any ideas? Thank you!
godo
Solved.
In the end I used the Arduino IDE 022 with the USBtinyISP. I pretended the board to be a Duino 644P and deleted the .hex extension on a renamed ATmegaBOOT_1284P bootloader (making it "atmega644P"). Now serial communication works. Everything is fine.
So actually I did not change any fuses myself and it does not matter that the chip comes with other defaults. The one board on which I changed the fuses behaves like the others.
That was unpleasant, I hope it spares somebody else one week of grief.
