Topic: Texas Instruments TMP100 (I2C) 7 bit slave address + 1 bit for READ(1)/write(0) (Read 2885 times) previous topic - next topic
gnusmas
Hey
So I am trying to interface the Arduino Uno with the TMP100 from texas instruments. The tmp100 requires 1 bit (READ  = 1. write = 0) after the 7 bit Address so it knows what I want to do with it. Now my problem is that the arduino Wire.beginTransmission() function only allows to send a 7 bit address, so how must I send the 8th bit that the TMP100 requires from me?
Can I just use Wire.write() after Wire.beginTransmission() to tell the tmp100 if I am going to write to it or read from it?
Thanks in advance.
johnwasser
Wire.beginTransmission() is for WRITE.
Wire.requestFrom() is for READ.
The library takes care of the write/read bit.
gnusmas
ok so if I want to read from the pointer register inside the TMP100 my I2C will go something like this?
     Wire.begin(); // start condition
     Wire.requestFrom(Tmp_add,1);//I send the TMP its address, and tell it I am going to read from it
     int ack_nack_addr = Wire.read(); //to check if TMP ack or NACK my command
     Wire.write(pointer_register); //I write the address to the pointer register to access specific regster
     int ack_nack_pointer = Wire.read(); //to check if TMP ack or NACK my command
     Wire.requestFrom (Tmp_add,1); //Going to receive the information from the TMP100, and it is 1 byte
     int register_value = Wire.read();
     Wire.endTransmission();
johnwasser
Not quite.  You send a command and then receive a reply.
     Wire.begin();
    // Send the register address
     Wire.startTransmission(Tmp_add);
     // Request the data
gnusmas
     Wire.begin();
     // Request the data
Wow thanks alot that did the trick!!! So lets say I want to write to the particular register inside the TMP100 to change the resolution of the temperature readings, and then verify that the register actually changed the resultion by reading it again.
     Wire.begin();
     Wire.write(resolution_value);
     // Request the data
johnwasser
You probably have to set the register address again to get the same register:
    // Send the register address and new value
     // Request the data
gnusmas
Thanks alot for the help! I got it working perfectly as I wanted to, Is there a specific place where I can post my code as example code , so that other people that might be struggling will at least have a reference to work from?
johnwasser
You could write an easy-to-use TMP100 library and post that somewhere. The "Playground" section of the Arduino site (see link at the top of the page) is a place where people publish libraries and examples.
gnusmas
Thanks, how do i make my post solved status?
Final Code Working!:
/* Dudley Tolken
   Temp Sensor
   06-03-2012
   Thanks to the following person(s):
   1. John Wasser, on the Aruindo Forums
  Description:
  This project interfaces at Arduino Uno (SMD) with a TMP100 (Texas Instruments).
  Temperature Reading:
  The TMP100 sends 2 bytes of data for the current sampled temperature. The first byte containts the MSB(Integer) and the second
  byte contains the LSB(Decimal).Although the decimal value is only 4 bits long, the decimal value is stored from bit 4  to bit 7
  in the LSB, while bit 0 to bit 3 is 0.
  To read temperature from the TMP100 the folllowing algorithm is used.
  (1).Wire.beginTransmission(Slave_Address) <-Initiate transmision
  (2).Wire.write(ponter_address_temp)       <-Access temp register in Pointer Register
  (3).Wire.endTransmission()                <-End transmission
  (4).Wire.requestFrom(Slave_Address,2);    <-Request 2 bytes(MSB, LSB) from the TMP100 address
  Convert the MSB and LSB to the actual temperature.
  (1).temp_MSB = Wire.read()   <--Store the MSB value into a integer variable(temp_MSB)
  (2).temp_LSB = Wire.read()   <--Store the LSB value into a integer variable(temp_LSB)
      Note:
      The MSB is the actual integer value of the current temperature that the sensors measures.
      The LSB will look something like this (Remember the actual measurement of the LSB is ONLY 4 bits!!):
      Bit 7  Bit 6  Bit 5  Bit 4  Bit 3  Bit 2  Bit 1  Bit 0
      1/0     1/0    1/0    1/0    0      0      0      0
  (3).int temp_deci = map(temp_LSB >> 4, 0, 15,0,99);       <- temp_LSB >> 4, it shifts the decimal value of the measured temperature right by 4, so that it sits now between Bit 3 to Bit 0, so conversion to integer is easy
                                                            <- 4 Bits goes from 0 to 15 Decimal, so to get an accurate reading, just scale it to be from 0 to 999
  Write to Configuration Register.
  (1).Wire.beginTransmission(temp_address)  <-Initiate transmision
  (2).Wire.write(pointer_address_config)  <-Access config register in Pointer Register
  (3).Wire.write(config); <-Write data to configuration register
  (4).Wire.endTransmission(); <-End transmission
  Arduino UNO (SMD)  -> Master
  TMP100 -> Slave
      MASTER                           SLAVE
  | Arduino Uno  |            |   |    TMP100    |         |
  |           GND|----------------|GND(2) (5)ADD0|---------|
  |       Vcc(5V)|----------------|Vcc(4) (3)ADD1|---------|
  |       (SDA)A4|----------------|SDA(6)        |
  |       (SCL)A5|------------|---|SCL(1)        |
          (pull up) 10K      10K (pull up)
                    VCC      VCC
#include  <Wire.h>  //Include I2C library
int ponter_address_temp = 0; //Pointer address 0 = Temperature output.
int temp_address = 72; //slave address of TMP100
int pointer_address_config = 1; //Pointer address 1 = Configuration Register
byte temp_MSB, temp_LSB; // Because the TMP100 sends 2 bytes
int config = 224;  //Configuration Register - To have 12 bit resolution. Refer to TMP100 for the Configuration Register
  Serial.begin(9600); //serial baud rate
  Wire.begin(); //Start I2C
  Wire.beginTransmission(temp_address); //Sends slave address with Rwite
  Wire.write(pointer_address_config);//Access config register in Pointer Register
  Wire.write(config); //Write data to configuration register
  Wire.endTransmission(); //End Transmission
  Wire.write(ponter_address_temp);  //Access temp register in Pointer Register
  Wire.endTransmission();//End Transmission
  Wire.requestFrom(temp_address,2); //Request 2 bytes(MSB, LSB) from the TMP100 address
  temp_MSB = Wire.read(); //Store first byte from TMP100 (MSB) into a variable
  temp_LSB = Wire.read(); //Store seconds byte from TMP100 (LSB) into a variable
  int temp_deci = map(temp_LSB >> 4, 0, 15,0,999); // Shift LSB 4 bits to the rightm and scale it to range from 0 to 999
  //Prints to the serial window.
  Serial.print("Temp: ");
  Serial.print(temp_MSB);
  Serial.print(".");
  Serial.println(temp_deci);
johnwasser
I don't know but my guess would be a "Modify" link on your original post that might allow you to change the title.
