universe
I'm enjoying my Life
« on: March 05, 2012, 08:34:36 pm » |
Here I put my code that I assembly by myself looking at the existing program on many website. And I put it into simulation and it works as I expected. I would like to developed more complex circuit but I can not find the way, because in my programming I use too many void and it has no return value. So when it comes to more complicated circuit, the programming is like a mess. One way I can solve this by use "return", it is just like we go to certain subroutine and after it finish, it will be back to the place which command it to go.
Do you know how I can use "return", surely without void. It will help me so much to have more structured programming. I hope you do not suggest me to learn C++ from "Hello World", I hope you can tell me how to make it in the IDE. Thank you friends!
Best Regards,
Sugianto
universe
« Reply #1 on: March 05, 2012, 08:37:42 pm » |
Here I forgot to post the code: void setup(); void loop(); void increment (); void show(); void sendSerialDatainitial(); int switchPin = 2; int no=1;
// This pin gets sets low when I want the 595s to listen const int g_pinCommLatch = 8;
// This pin is used by ShiftOut to toggle to say there's another bit to shift const int g_pinClock = 12;
// This pin is used to pass the next bit const int g_pinData = 11;
// Definitions of the 7-bit values for displaying digits byte g_digits [10];
// Current number being displayed int g_numberToDisplay = 0;
// Number of shift registers in use const int g_registers = 5;
// Array of numbers to pass to shift registers byte g_registerArray [g_registers];
void setup() { pinMode (g_pinCommLatch, OUTPUT); pinMode (g_pinClock, OUTPUT); pinMode (g_pinData, OUTPUT); // Setup the digits array g_digits [0] = 1 + 2 + 4 + 8 + 16 + 32 + 00; g_digits [1] = 0 + 2 + 4 + 0 + 00 + 00 + 00; g_digits [2] = 1 + 2 + 0 + 8 + 16 + 00 + 64; g_digits [3] = 1 + 2 + 4 + 8 + 00 + 00 + 64; g_digits [4] = 0 + 2 + 4 + 0 + 00 + 32 + 64; g_digits [5] = 1 + 0 + 4 + 8 + 00 + 32 + 64; g_digits [6] = 1 + 0 + 4 + 8 + 16 + 32 + 64; g_digits [7] = 1 + 2 + 4 + 0 + 00 + 00 + 00; g_digits [8] = 1 + 2 + 4 + 8 + 16 + 32 + 64; g_digits [9] = 1 + 2 + 4 + 8 + 00 + 32 + 64; sendSerialDatainitial(g_registers, g_registerArray); randomSeed(analogRead(0)); }
void sendSerialDatainitial( byte registerCount, // How many shift registers? byte *pValueArray) // Array of bytes with LSByte in array [0] { g_registerArray [4] = g_digits [0]; g_registerArray [3] = g_digits [0]; g_registerArray [2] = g_digits [0]; g_registerArray [1] = g_digits [0]; g_registerArray [0] = g_digits [0]; // Signal to the 595s to listen for data digitalWrite (g_pinCommLatch, LOW); for (byte reg = registerCount; reg > 0; reg--) { byte value = pValueArray [reg-1];
for (byte bitMask = 128; bitMask > 0; bitMask >>= 1) { digitalWrite (g_pinClock, LOW); digitalWrite (g_pinData, value & bitMask ? HIGH : LOW); digitalWrite (g_pinClock, HIGH); } } // Signal to the 595s that I'm done sending digitalWrite (g_pinCommLatch, HIGH); } // sendSerialData
// Simple function to send serial data to one or more shift registers by iterating backwards through an array. // Although g_registers exists, they may not all be being used, hence the input parameter. void sendSerialData ( byte registerCount, // How many shift registers? byte *pValueArray) // Array of bytes with LSByte in array [0] { // Signal to the 595s to listen for data digitalWrite (g_pinCommLatch, LOW); for (byte reg = registerCount; reg > 0; reg--) { byte value = pValueArray [reg - 1];
void loop() { if (digitalRead(switchPin)) { blinks(); } delay(100); }
void blinks() { int a = random (1,3); int b = random (1,5); int c = random (3,5); int d = random (1,3); int e = random (2,3); int f = random (1,4); if (a==1) { digitalWrite(9, HIGH); // set the LED on delay(1000); // wait for b times a second digitalWrite(9, LOW); {increment();} } else { digitalWrite(9, LOW); // set the LED off delay(b*1000); // wait for c times one second {blinks();} } if (c==3) { digitalWrite(10, HIGH); // set the LED on delay(1000); // wait for b times a second digitalWrite(10, LOW); {increment();} } else { digitalWrite(10, LOW); // set the LED off delay(b*1000); // wait for c times one second {blinks();} } }
void increment() { g_numberToDisplay = no; no=no+1; show(g_numberToDisplay); delay(500); } void show(int no) { if (g_numberToDisplay < 10) { g_registerArray [4] = g_digits [0]; g_registerArray [3] = g_digits [0]; g_registerArray [2] = g_digits [0]; g_registerArray [1] = g_digits [0]; g_registerArray [0] = g_digits [g_numberToDisplay]; } else if (g_numberToDisplay < 100) { g_registerArray [4] = g_digits [0]; g_registerArray [3] = g_digits [0]; g_registerArray [2] = g_digits [0]; g_registerArray [1] = g_digits [g_numberToDisplay / 10]; g_registerArray [0] = g_digits [g_numberToDisplay % 10]; } else if (g_numberToDisplay < 1000) { g_registerArray [4] = g_digits [0]; g_registerArray [3] = g_digits [0]; g_registerArray [2] = g_digits [g_numberToDisplay / 100]; g_registerArray [1] = g_digits [(g_numberToDisplay % 100) / 10]; g_registerArray [0] = g_digits [g_numberToDisplay % 10]; } else if (g_numberToDisplay < 10000) { g_registerArray [4] = g_digits [0]; g_registerArray [3] = g_digits [g_numberToDisplay / 1000]; g_registerArray [2] = g_digits [(g_numberToDisplay % 1000) / 100]; g_registerArray [1] = g_digits [(g_numberToDisplay % 100) / 10]; g_registerArray [0] = g_digits [g_numberToDisplay % 10]; } else { g_registerArray [4] = g_digits [g_numberToDisplay / 10000]; g_registerArray [3] = g_digits [(g_numberToDisplay % 10000) / 1000]; g_registerArray [2] = g_digits [(g_numberToDisplay % 1000) / 100]; g_registerArray [1] = g_digits [(g_numberToDisplay % 100) / 10]; g_registerArray [0] = g_digits [g_numberToDisplay % 10]; } sendSerialData (g_registers, g_registerArray); delay (1000); } // loop
Monterrey, N.L. México
Model Railroading & Arduino are Fun
« Reply #2 on: March 05, 2012, 08:49:08 pm » |
Just define your function as follows: (assume you need to return an Int from a function) Int myFunction (any arguments) { if (condition is true) { return 1; // or any other value you want } else { return 2; // or any other value you want } }
So if the condition is true you get a 1 returned to the calling Sketch otherwise you get a 2. You may y return as many values as you need by using several return statements or just one return using a variable with the right value.
« Reply #3 on: March 05, 2012, 08:51:34 pm » |
Big assumption; most people will want to return an int.
universe
« Reply #4 on: March 05, 2012, 08:58:09 pm » |
To:WizenedEE
Could you give example by defining one of my function? I much learn by example. Thank you best!
North Queensland, Australia
Online
« Reply #5 on: March 05, 2012, 09:01:31 pm » |
Here is a few ways of returning values from a function void AddNumbers( int a, int b, int &result ) { result = a + b; return; }
void AddNumbers( int a, int b, int *result ) { *result = a + b; return; }
int AddNumbers( int a, int b ) { return a + b; }
void setup() { int a = 4; int b = 5; int result;
//Version 1 AddNumbers( a, b, result );
//Version 2 AddNumbers( a, b, &result );
//Version 3 result = AddNumbers( a, b );
universe
« Reply #6 on: March 05, 2012, 09:17:35 pm » |
what is the different &result and *result? I thought void setup() should be in the beginning void setup() { int a = 4; int b = 5; int result;
int AddNumbers( int a, int b ) { return a + b; } The code execute the version 1 first and return to it again and execute the version 2,etc, am I right?
Online
« Reply #7 on: March 05, 2012, 09:25:00 pm » |
setup can be at the start, the IDE generates the function prototypes at the top of the file when you compile.
in a function paramater list:
& means pass by reference, rather than by value. ( if the function modifies the variable, it modifies the original passed variable, not a copy )
* means the variable is actually a pointer. ( address to variable ), the * in the code has different meanings, it converts/dereferences the address to the variable ( original passed variable )
when the function is called 'AddNumbers( a, b, &result );' the & operator gets the address of result ( pointer ), the compiler will call 'void AddNumbers( int a, int b, int *result )' as the result paramater is a pointer
Each version produces the same result, just different ways of doing it.
« Last Edit: March 05, 2012, 09:28:29 pm by pYro_65 »
« Reply #8 on: March 05, 2012, 09:27:33 pm » |
If you want to know more, you should read up on pointers and references. However, they're more "advanced" topics and are definitely not necessary for what you're trying to do. I thought void setup() should be in the beginning
It doesn't matter where functions are defined. Functions are only executed when they are called. The exception is the main function, which then calls setup and loop int AddNumbers( int a, int b ) { return a + b; } This is the best way to solve your problem. This is technically legal, but not how you should be doing things. Braces ( these: { ) are only needed to constrain a "block" -- usually an if, while or for statement. You should just do this: increment();
universe
« Reply #9 on: March 05, 2012, 09:45:28 pm » |
Hmm, so for example in my code void increment(), so it will be executed when it is called? I thought all the codes will be executed from above all to down? Hmm, how to make it has return value: void show(int no) { if (g_numberToDisplay < 10) { g_registerArray [4] = g_digits [0]; g_registerArray [3] = g_digits [0]; g_registerArray [2] = g_digits [0]; g_registerArray [1] = g_digits [0]; g_registerArray [0] = g_digits [g_numberToDisplay]; } else if (g_numberToDisplay < 100) { g_registerArray [4] = g_digits [0]; g_registerArray [3] = g_digits [0]; g_registerArray [2] = g_digits [0]; g_registerArray [1] = g_digits [g_numberToDisplay / 10]; g_registerArray [0] = g_digits [g_numberToDisplay % 10]; } else if (g_numberToDisplay < 1000) { g_registerArray [4] = g_digits [0]; g_registerArray [3] = g_digits [0]; g_registerArray [2] = g_digits [g_numberToDisplay / 100]; g_registerArray [1] = g_digits [(g_numberToDisplay % 100) / 10]; g_registerArray [0] = g_digits [g_numberToDisplay % 10]; } else if (g_numberToDisplay < 10000) { g_registerArray [4] = g_digits [0]; g_registerArray [3] = g_digits [g_numberToDisplay / 1000]; g_registerArray [2] = g_digits [(g_numberToDisplay % 1000) / 100]; g_registerArray [1] = g_digits [(g_numberToDisplay % 100) / 10]; g_registerArray [0] = g_digits [g_numberToDisplay % 10]; } else { g_registerArray [4] = g_digits [g_numberToDisplay / 10000]; g_registerArray [3] = g_digits [(g_numberToDisplay % 10000) / 1000]; g_registerArray [2] = g_digits [(g_numberToDisplay % 1000) / 100]; g_registerArray [1] = g_digits [(g_numberToDisplay % 100) / 10]; g_registerArray [0] = g_digits [g_numberToDisplay % 10]; } sendSerialData (g_registers, g_registerArray); [color=red]// I would like to replace it by return value, so I can have more structured code[/color] delay (1000); }
Online
« Reply #10 on: March 05, 2012, 09:54:28 pm » |
The code inside a function runs one line at a time from top to bottom. Functions can be called in any order.
What do you want that function to return. It modifies variables that are available elsewhere and sends data. You also don't use the 'int no' passed to the function.
universe
« Reply #11 on: March 05, 2012, 10:08:48 pm » |
could you show me how you modify it?
Online
« Reply #12 on: March 05, 2012, 10:16:59 pm » |
Change your current declaration from void show(int no) { //your code } to something like bool show( void ) //You don't use 'int no' { //your code if( 'success' ){ //Replace 'success' with some real code return true; }else{ return false; } } But like I asked, what do you want to return, an unused return value is a waste. The function modifies data that you can already access, if you can check that the send happened correctly, you could return like my example above. A void function ( method ) is fine.
« Last Edit: March 05, 2012, 10:20:00 pm by pYro_65 »
« Reply #13 on: March 05, 2012, 10:21:31 pm » |
The type before the name of your function is what it returns. "void" means "no type," so saying "void loop()" means "I'm defining a function which takes no arguments and returns nothing" and "char read()" means "I'm defining a function which takes no arguments and returns a char" and "bool isWithinRange(int x)" means "I'm defining a function which takes an integer and returns a bool"
So to make your function return something, change the void to bool. Then, in the body of the function, you have to honor your promise and actually return something. (Say: "return var;" assuming var is an int. You could also say "return 42;" if you wanted to return a constant.)
universe
« Reply #14 on: March 05, 2012, 10:24:44 pm » |
the reason I want to return because I want copy the structure of this program, very neat and structured: mulai: hserout [dec jml] portc 0# = 1 portc 0.1 = 0 portc 0.2 = 0 portc 0.3 = 0 portb=%00000000 porta = dt11 portb=%00000001 portb=%00000000 porta = dt21 portb=%00000010 portb=%00000000 porta = dt31 portb=%00000100 portb=%00000000
portc 0# = 0 portc 0.1 = 1 portc 0.2 = 0 portc 0.3 = 0 portb=%00000000 porta = dt12 portb=%00000001 portb=%00000000 porta = dt22 portb=%00000010 portb=%00000000 porta = dt32 portb=%00000100 portb=%00000000
portc 0# = 0 portc 0.1 = 0 portc 0.2 = 1 portc 0.3 = 0 portb=%00000000 porta = dt13 portb=%00000001 portb=%00000000 porta = dt23 portb=%00000010 portb=%00000000 porta = dt33 portb=%00000100 portb=%00000000
portc 0# = 0 portc 0.1 = 0 portc 0.2 = 0 portc 0.3 = 1 portb=%00000000 porta = dt14 portb=%00000001 portb=%00000000 porta = dt24 portb=%00000010 portb=%00000000 porta = dt34 portb=%00000100 portb=%00000000 porta = dt44 portb=%00001000 portb=%00000000
tombol: if portd.0=1 and t1=0 then GoSub waktu1 t1 = 1 elseif portd.0=0 and t1=1 then t1 = 0 End If
if portd.2=1 and t2=0 then GoSub waktu2 t2 = 1 elseif portd.2=0 and t2=1 then t2 = 0 End If
if portd.4=1 and t3=0 then GoSub waktu3 t3 = 1 elseif portd.4=0 and t3=1 then t3 = 0 End If
if portd.1=1 and t1=0 then dt11 = 0 dt21 = 0 dt31 = 0 End If if portd.3=1 and t1=0 then dt12 = 0 dt22 = 0 dt32 = 0 End If if portd.5=1 and t1=0 then dt13 = 0 dt23 = 0 dt33 = 0 End If
if portd.6=1 and portd.0=0 and portd.2=0 and portd.4=0 then dt11 = 0 dt21 = 0 dt31 = 0 dt12 = 0 dt22 = 0 dt32 = 0 dt13 = 0 dt23 = 0 dt33 = 0 dt14 = 0 dt24 = 0 dt34 = 0 End If
GoSub jumlah GoTo mulai
waktu1: dt11 = dt11 + 1 If dt11 = 10 Then dt11 = 0 dt21 = dt21 + 1 End If If dt21 = 10 Then dt31 = dt31 + 1 dt21 = 0 End If If dt31 = 10 Then dt31 = 0 End If Return
waktu2: dt12 = dt12 + 1 If dt12 = 10 Then dt12 = 0 dt22 = dt22 + 1 End If If dt22 = 10 Then dt32 = dt32 + 1 dt22 = 0 End If If dt32 = 10 Then dt32 = 0 End If Return
waktu3: dt13 = dt13 + 1 If dt13 = 10 Then dt13 = 0 dt23 = dt23 + 1 End If If dt23 = 10 Then dt33 = dt33 + 1 dt23 = 0 End If If dt33 = 10 Then dt33 = 0 End If Return
jumlah: j1 = dt11 + dt12 + dt13 j2 = (dt21 + dt22 + dt23) * 10 j3 = (dt31 + dt32 + dt33) * 100 jml = j1 + j2 + j3 dt4 = jml / 1000 dt44 = dt4 If dt44 > dt4 Then dt44 = dt44 - 1 dtt44 = dt44 * 1000 dttt34 = (jml - dtt44) dt3 = dttt34 / 100 dt34 = dt3 If dt34 > dt3 Then dt34 = dt34 - 1 dtt34 = dt34 * 100 dttt24 = dttt34 - dtt34 dt2 = dttt24 / 10 dt24 = dt2 If dt24 > dt2 Then dt24 = dt24 - 1 dtt24 = dt24 * 10 dt1 = dttt24 - dtt24 dt14 = dt1 If dt14 > dt1 Then dt14 = dt14 - 1 Return
it is in Basic. I hope you can get the idea why I always want return. so you can help me solve my code
