Offline
Newbie
« on: March 06, 2012, 06:06:15 am » |
In the Ethernet library, DNS, has been inserted in the begin-procedure, which is not updated in the Reference-example.
Reference-example: Ethernet.begin(mac, ip, gateway, subnet);
And in Ethernet.cpp: void EthernetClass::begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server, IPAddress gateway)
So the DNS will get the address of the gateway, and worse, the gateway will try to be written as the netmask, by following the reference-example in Ethernet.
I suggest that the DNS is removed from the header, as it is only a nice to know but not as important as mac, IP, nw-mask and gw.
By the way, if an SD-card has been applied to the sd-reader socket, the server will not get an IP-address if not importing the SD-library, even without the intension of using the sd-card. You can ping the board, but if reading the servers IP-address it is not initialised( IP = 0xffffffff). By removing the SD-card from the reader, server becomes the IP-address as given. The dependency is not so obvious.
Please also state that the default GW is the IP-address with the last digit replaced by a 1, by default in the reference, the same goes for DNS, and default netmask is 255.255.255.0 if none applied.
