Topic: Arduino Telnet Server (Read 5217 times) previous topic - next topic
stlentz
Mar 06, 2012, 02:14 pm Last Edit: Mar 09, 2012, 06:48 pm by SteveTL Reason: 1
Folks:
There's been some recent interest in the Telnet server sketch I created a couple years back.  The Telnet server allows all Arduino control pins to be read or written using a simple command line protocol.  Once you've loaded the sketch, you should be able to Telnet into the Arduino's IP address, get a prompt, and type ? <cr> for help.
The code on the old forum was developed in Arduino environment 0.23 and no longer compiles without edits.  I'm posting the updated code here:  http://dl.dropbox.com/u/47320696/ArduinoTelnetServer.zip.
I hope this helps; drop me a note if you find it useful.
Best Regards,
stlentz [at] gmail [dot] com
robtillaart
Definetely usefull, it allows one to monitor and manage things over the internet. Web is good for human computer interaction but telnet can also do computer computer very easy.
Thanks for upgrading.
Rob Tillaart
gandalfk7
Hi! I was just writing an email to you!
First of all thank you for sharing your work, it's an excellent base to start my project since I do not know very much of programming.
I am adding code to the telnet server for the support of the DHT11/22/21 humidity/temperature sensors.
Is there anyone who is using this code and has expanded it in any way?
Matteo
robtillaart
this code
what you mean by this - DHT or Telnet?
DHT - http://playground.arduino.cc/Main/DHTLib -
Rob Tillaart
gandalfk7
I meant the Telnet Server code!
Frisky
gandalfk7
#6
Jan 18, 2013, 12:14 pm Last Edit: Jan 18, 2013, 12:17 pm by gandalfk7 Reason: 1
Premise: I'm an improvised coder.
I have added two parts to the server, one for the temperature readings (but I hadn't time to test it) and one for the reading/writing of 6 variables:
Temperature:
library and settings:
#include <DHT.h>
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
#define DHTPIN 2     // what pin we're connected to
DHT dht(DHTPIN, DHTTYPE);
in the void setup:
dht.begin();
in the void parseReceivedText added:
case 'e' : envCommand(); break;
and the rest of the code:
void envCommand()
// if we got here, textBuff[0] = 'e'
switch (textBuff[1]) {
case 't' : envTempCommand(); break;
case 'h' : envHumCommand(); break;
default: printErrorMessage(); break;
void envTempCommand()
// if we got here, textBuff[0] = 'e' and textBuff[1] = 't'
//float h = dht.readHumidity();
 float t = dht.readTemperature();
//  if (isnan(t)) {
   if (isnan(t) && (t) == 0.00) {
  client.println("ERROR reading the sensor ");
       client.print("DEBUG content of t ");
       client.print(t);
       client.println(" "); }
else {
client.print("Temp: ");
client.print(t);
client.print(" *C");
void envHumCommand()
// if we got here, textBuff[0] = 'e' and textBuff[1] = 'h'
 if (isnan(h)) {
       client.print("DEBUG content of h ");
       client.print(h);
else {
client.print("Hum: ");
client.print(h);
client.print(" %\t");
the variables part:
define the variables:
int a = 0;
int b = 0;
int c = 0;
int d = 0;
int e = 0;
int f = 0;
case 'v' : varCommand(); break;
and the variables code:
void varCommand()
// if we got here, textBuff[0] = 'v'
case 's' : varSetCommand(); break;
case 'r' : varReadCommand(); break;
void varSetCommand()
// if we got here, textBuff[0] = 'v' and textBuff[1] = 's'
if (textBuff[3] == '=') {
 int variable = 0;                       // varible to store my command variable
 variable = parseDigit(textBuff[4]);     // reads the fourth char of my command
    if (variable >= 0 && variable <= 9) {   // check if a number have been entered, isnan didn't quite work
      switch (textBuff[2]) {
        case 'a':
          a = variable;
          client.print("'a' is: ");
          client.println(a);
          client.println("OK! ");
          break;
        case 'b':
          b = variable;
          client.print("'b' is: ");
          client.println(b);
          break;
        case 'c':
          c = variable;
          client.print("'c' is: ");
          client.println(c);
          break;
        case 'd':
          d = variable;
          client.print("'d' is: ");
          client.println(d);
          break;
        case 'e':
          e = variable;
          client.print("'e' is: ");
          client.println(e);
          break;
        case 'f':
          f = variable;
          client.print("'f' is: ");
          client.println(f);
          break;
        default:
          client.println("ERROR: wrong variable ");
  else client.println("ERROR: unfortunately we can only process one digit numbers"); }
else client.println("ERROR: wrong command ");  }
void varReadCommand()
// if we got here, textBuff[0] = 'v' and textBuff[1] = 'r'
     case 'a':
       client.println(a);
       break;
     case 'b':
       client.println(b);
       break;
     case 'c':
       client.println(c);
       break;
     case 'd':
       client.println(d);
       break;
     case 'e':
       client.println(e);
       break;
     case 'f':
       client.println(f);
       break;
     default:
obviously I added the needed text to the help ( void printHelpMessage ):
client.println(" et -environmental TEMP read: returns the state of the temp sensor");
client.println(" eh -environmental HUMidity read: returns the state of the humidity sensor");
client.println(" vr -variable read: reads a variable");
client.println(" vs -variable set: sets a variable");
client.println(" allowed variables are: a b c d e f ");
client.println(" allowed variables values are numbers between 0-9 ");
gandalfk7
Tested with a DHT22, the temp/hum part seems to work without problems
Elijahg
