Topic: Number complex (Read 2035 times) previous topic - next topic
taurian
Mar 07, 2012, 06:01 pm Last Edit: Mar 07, 2012, 06:19 pm by taurian Reason: 1
hello
I'm new to working with arduino I wanted to add two complex numbers:
(a + bi) + (a + bi)
how can I do this.
Thanks Gil
PaulS
Just like you would on any other computer.
el_supremo
Here's a simple piece of code which uses complex numbers.
struct complex {
  double r;
  double i;
} a,b,c;
// Set a complex number. Real(p)=cr, Imag(p)=ci
void set_complex(struct complex *p,double cr,double ci)
  p->r = cr;
  p->i = ci;
// Add two complex numbers and place the result in a third
// c = a+b
void add_complex(struct complex *c,struct complex *a,struct complex *b)
  c->r = a->r + b->r;
  c->i = a->i + b->i;
void setup(void)
  // Set a to (1,2)
  set_complex(&a,1,2);
  // set b to (3.2,-4.1)
  set_complex(&b,3.2,-4.1);
  // add a and b and put the result in c
  add_complex(&c,&a,&b);
  // Now print c
  Serial.print("c = ");
  Serial.print(c.r,1);
  if(c.i >= 0)Serial.print("+");
  Serial.print(c.i,1);
  Serial.println("i");
void loop(void)
But assuming you can add the two complex numbers, what are you going to do with the result?
Pete
Don't send me technical questions via Private Message.
taurian
I want to do the DFT definition through the arduino so I use complex numbers.
thank you Gil
PaulS
The what?
el_supremo
Good luck with that.
Have a look at this thread, which has code to do a fixed-point DFT.
http://arduino.cc/forum/index.php/topic,72729.0.html
Pete
PaulS
I looked up DFT - Detroit Fine Theater. I can't imagine how you can do that on the Arduino, or what complex numbers have to do with it.
robtillaart
A nice complex number class, here is a starter - http://www.dreamincode.net/code/snippet75.htm -
Rob Tillaart
taurian
#8
Mar 07, 2012, 11:27 pm Last Edit: Mar 08, 2012, 01:17 pm by taurian Reason: 1
hello
I made this function to calculate the DFT (discrete Fourier transform) but I do not run the arduino has errors the compiler does not interpret the (I> complex number)
X=zeros(1,N);
for k=0:N-1
    a=zeros(1,N);
    for n=0:N-1
        a(n+1)=x(n+1)*exp(-(1i*2*pi*n*k)/N);
    end
     X(k+1)=sum(a);
thank you Gil
PaulS
Perhaps you should try writing the function in C, instead of Basic.
taurian
Hello,
In language C i dont know what the libraries that i have to use. Arduino doesn´t uses C language its a bit diferent, then i have a C function maybe i can develope one for Arduino.
Can you help me?
Thanks Gil
pYro_65
Nope, its C and C++. There is no 'Arduino specific' language, it is just a C style API for use with Arduino boards.
Forum Mod anyone?
https://arduino.land/Moduino/
dxw00d
You should consider merging the threads you have on this subject into one.
taurian
yeah. I making the code in C or C + + how can I convert to the arduino?
thank Gil
taurian
"You should consider merging the threads you have on this subject into one"
I was wrong and I put 2 Posts
sorry I'll join the two
thank Gil
