Topic: Problem with 3.2" TFT LCD (Read 4160 times) previous topic - next topic
Nuno_Rio
Hey. I bought this  3.2" inch TFT LCD module integrated a Himax HX8347-A TFT LCD controller and ADS7843 compatible touch screen controller as well as a SD card cage. I have an Arduino Mega 2560 and in next image is the connetion between Arduino and TFT.
I'm using Henning Karlsen libraries and when running the calibration program i touch all the 9 cross but in the end the new settings is all 0. I made a program just to get X and Y coordinates and in any point of screen i touch i get (0,0), next is the calibration program i'm running. Any sugestion of has wrong? Thanks.
Nuno Rio
Code: [Select]
// ITDB02_Touch_Calibration (C)2010 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program can be used to calibrate the touchscreen
// of the ITDB02 modules.
// This program requires the ITDB02_Graph library (8bit mode)
// or ITDB02_Graph16 (16bit mode).
// It is assumed that the ITDB02 module is connected to a
// ITDB02 Shield, a ITDB02 Mega Shield or that you know how
// to change the pin numbers in the setup.
// Instructions will be given on the display.
// Remember to change the next line if you are using as 16bit module!
#include <UTFT.h>
#include <ITDB02_Touch.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
// Uncomment the next two lines for the ITDB02 Shield
//ITDB02        myGLCD(19,18,17,16);
//ITDB02_Touch  myTouch(15,10,14,9,8);
// Uncomment the next two lines for the ITDB02 Mega Shield
UTFT        myGLCD(ITDB32S,4,5,6,7);   // Remember to add ASPECT_16x9 if you are using an ITDB02-3.2WC!
ITDB02_Touch  myTouch(12,10,11,9,8);
int cx, cy;
int rx[10], ry[10];
float px, py;
int ox, oy;
  myGLCD.InitLCD(0);
  myGLCD.clrScr();
  myGLCD.setFont(SmallFont);
  myTouch.InitTouch(        );
  myTouch.setPrecision(PREC_LOW);
void drawCrossHair(int x, int y)
  myGLCD.drawRect(x-10, y-10, x+10, y+10);
  myGLCD.drawLine(x-5, y, x+5, y);
  myGLCD.drawLine(x, y-5, x, y+5);
void readCoordinates()
  int iter = 2000;
  int cnt = 0;
  unsigned long tx=0;
  unsigned long ty=0;
  boolean OK = false;
  while (OK == false)
    while (myTouch.dataAvailable() == false) {}
    while ((myTouch.dataAvailable() == true) && (cnt<iter))
      myTouch.read();
      tx += myTouch.TP_X;
      ty += myTouch.TP_Y;
      cnt++;
    if (cnt>=iter)
      OK = true;
      tx = 0;
      ty = 0;
      cnt = 0;
  cx = tx / iter;
  cy = ty / iter;
void calibrate(int x, int y, int i)
  myGLCD.setColor(255, 255, 255);
  drawCrossHair(x,y);
  readCoordinates();
  myGLCD.setColor(80, 80, 80);
  drawCrossHair(x,y);
  rx[i]=cx;
  ry[i]=cy;
  while (myTouch.dataAvailable() == true)
    myTouch.read();
void waitForTouch()
    myTouch.read();
    myTouch.read();
void startup()
  myGLCD.setColor(255, 0, 0);
  myGLCD.fillRect(0, 0, 239, 13);
  myGLCD.setBackColor(255, 0, 0);
  myGLCD.drawLine(0, 14, 239, 14);
  myGLCD.print("ITDB02 TOUCH CALIBRATION", CENTER, 1);
  myGLCD.setBackColor(0, 0, 0);
  myGLCD.print("INSTRUCTIONS", CENTER, 30);
  myGLCD.print("Use a stylus or something", LEFT, 50);
  myGLCD.print("similar to touch as close to", LEFT, 62);
  myGLCD.print("the center of the highlighted", LEFT, 74);
  myGLCD.print("crosshair as possible. Keep as", LEFT, 86);
  myGLCD.print("still as possible and keep", LEFT, 98);
  myGLCD.print("holding until the highlight is", LEFT, 110);
  myGLCD.print("removed. Repeat for all", LEFT, 122);
  myGLCD.print("crosshairs in sequence.", LEFT, 134);
  myGLCD.print("Further instructions will be", LEFT, 158);
  myGLCD.print("displayed when the calibration", LEFT, 170);
  myGLCD.print("is complete.", LEFT, 182);
  myGLCD.print("Do NOT use your finger as a", LEFT, 206);
  myGLCD.print("calibration stylus or the", LEFT, 218);
  myGLCD.print("result WILL BE very imprecise.", LEFT, 230);
  myGLCD.print("Touch screen to continue", CENTER, 305);
  waitForTouch();
  myGLCD.clrScr();
void done()
  myGLCD.clrScr();
  myGLCD.print("CALIBRATION COMPLETE", CENTER, 30);
  myGLCD.print("To use the new calibration", LEFT, 50);
  myGLCD.print("settings you must edit the", LEFT, 62);
  myGLCD.setColor(160, 160, 255);
  myGLCD.print("ITDB02_Touch.cpp", LEFT, 74);
  myGLCD.print("file and", 136, 74);
  myGLCD.print("change the following values.", LEFT, 86);
  myGLCD.print("The values are located right", LEFT, 98);
  myGLCD.print("below the opening comment in", LEFT, 110);
  myGLCD.print("the file.", LEFT, 122);
  myGLCD.print("PixSizeX", LEFT, 158);
  myGLCD.print("PixOffsX", LEFT, 170);
  myGLCD.print("PixSizeY", LEFT, 182);
  myGLCD.print("PixOffsY", LEFT, 194);
  myGLCD.print("Connected module:", LEFT, 250);
  myGLCD.drawLine(0, 155, 239, 155);
  myGLCD.drawLine(0, 209, 239, 209);
  myGLCD.printNumF(px, 2, 100, 158);
  myGLCD.printNumI(ox, 100, 170);
  myGLCD.printNumF(py, 2, 100, 182);
  myGLCD.printNumI(oy, 100, 194);
  if (px>=0)
    myGLCD.print("2.4\"", 144, 250);
    if (py>=0)
      myGLCD.print("3.2\"", 144, 250);
      myGLCD.print("Negative numbers for PixSizeX", LEFT, 270);
      myGLCD.print("is expected :)", LEFT, 282);
      myGLCD.print("3.2\" Wide", 144, 250);
      myGLCD.print("and PixSizeY are expected :)", LEFT, 282);
  startup();
  drawCrossHair(10,10);
  drawCrossHair(10,160);
  drawCrossHair(10,309);
  drawCrossHair(120,10);
  drawCrossHair(120,160);
  drawCrossHair(120,309);
  drawCrossHair(229,10);
  drawCrossHair(229,160);
  drawCrossHair(229,309);
  calibrate(10, 10, 0);
  calibrate(10, 160, 1);
  calibrate(10, 309, 2);
  calibrate(120, 10, 3);
  calibrate(120, 160, 4);
  calibrate(120, 309, 5);
  calibrate(229, 10, 6);
  calibrate(229, 160, 7);
  calibrate(229, 309, 8);
  px = ((float(rx[0]+rx[1]+rx[2])/3)-(float(rx[6]+rx[7]+rx[8])/3))/220;
  if (px>=0)
    ox = (((rx[6]+rx[7]+rx[8])/3))-(px*10);
    ox = (((rx[0]+rx[1]+rx[2])/3))+(px*10);
  py = ((float(ry[0]+ry[3]+ry[6])/3)-(float(ry[2]+ry[5]+ry[8])/3))/300;
  if (py>=0)
    oy = (((ry[2]+ry[5]+ry[8])/3))-(py*10);
    oy = (((ry[0]+ry[3]+ry[6])/3))+(py*10);
  done();
  while(true) {}
Francesco_Noto
Hello, I try the library UTFT on my display TFT_320QVT
but i have these errors:
Arduino:1.5.7 (Windows 8), Scheda:"Arduino Uno"
C:\Program Files (x86)\Arduino\libraries\UTFT\DefaultFonts.c:21:14: error: variable 'SmallFont' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
fontdatatype SmallFont[1144] PROGMEM={
C:\Program Files (x86)\Arduino\libraries\UTFT\DefaultFonts.c:125:14: error: variable 'BigFont' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
fontdatatype BigFont[3044] PROGMEM={
C:\Program Files (x86)\Arduino\libraries\UTFT\DefaultFonts.c:234:14: error: variable 'SevenSegNumFont' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
fontdatatype SevenSegNumFont[2004] PROGMEM={
  Questo report potrebbe essere piĆ¹ ricco
di informazioni con
  "Mostra un output dettagliato durante la compilazione"
  abilitato in "File > Impostazioni"
can you help me
F.N.
Francesco_Noto
Hello, I have one TFT 3.2''.
It works fine.
Do you know the power consumption of this display?
Thanks
F.N.
casemod
#3
Sep 10, 2014, 10:21 pm Last Edit: Sep 11, 2014, 01:36 am by casemod Reason: 1
can you help me
F.N.
Yes. Dont use 1.5.7.
Seriously. Any version up to 1.5.6 should work fine.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
